Tape stuck door on player won't open. how can be opened without breaking
  • 168 Answers
The only thing you can do, is to try to open it up very slowly.
The thing keeping the door closed is the tape that is probably wound up around one of the drive pins (silver pins),
Your tape is most likely ruined unless you know how to splice a tape back together.
After getting the door open, I would take a Q-Tip and some rubbing alcohol and clean the silver drive pins and also the pinch rollers.
This should help reduce the jamming problems if there isnt any other problems causing the drive pins to not turn. IF the pins are not turning, then it could be a broken belt problem.
Hope this helps.
Good luck.
Mac
Posted on Feb 16, 2008
Left Deck Door Stuck Shut on Cassette Deck
Hi what has happened is when you pressed play the tape head that reads the tape has come up as normal this locks the door as you cant open it when its playing but instead of the tape head releasing and going back down into start possition it has become jammed in the tape itself.
You have two options turn off at mains and give it a gentle bang a couple of times this might free the tape and let the head go back to start possition its upto you how hard you tap it but doing this usually works and will allow you to get the tape out failing this then its going to be a case of stripping it down till you can get access to the tape head and be able to free it from the tape allowing door to open let me know how you get on ok and if you need further assistance
Feb 07, 2008 | Audio Players & Recorders
My system has swallowed a cassette, the tape is stuck & I can't get the drawer to open. It tries a few times (going 'click/clunk') & then gives up.Any thoughts please?
Hi. Firts of all.. chances are that your unit needs to be cleaned or you used low quality cassettes in thr player. a tape has would itself around the capstan and pinch roller causing everything to jam up. you may need to open up the unit..seperate the cassette mechanism from the main chasis and take it apart delicately in order to get the tape out without breaking the door catch .. Use tweezers but do not mark or scratch the azimuth head...OR.. try it from the front and try to open the door with a fingernail in there..while pressing the eject...good luk. Trace Electronics Repair, Canada
May 06, 2010 | Aiwa XR-EM70 CD Shelf System
JVC Camcorder Tape door stuck
michanical dis arrange inside the tape socket
Mar 20, 2010 | Video Cameras
A VHS tape is stuck in my player. How do I get it out?
the tape might have stuck inside.. you need to open it and remove it on your own.. if you think its risky go to any nearby shop of electronics.. they will do it for few bucks..
Jul 10, 2009 | Zenith Televison & Video
Problem with AIWA TP-M130 micro cassette recorder can't get tape out
Following 2 pics of exploded view will help you to solve problem with Aiwa tape.
Need further help. let me know.
Oct 22, 2008 | Audio Players & Recorders
Stuck tape in camcorder
I had a similar problem with an older panasonic camera. Mybe you have tried this, but opening the door and pushing up on the tape. Push in and use enough force but don't try to break it. Try pressing different spots. Sooner or later the motor might start moving it up. Just a though, it worked for me.
Mar 18, 2008 | Panasonic PV-GS300 Mini DV Digital...
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Feb 04, 2008 | Audio Players & Recorders
RCA 2656 bookshelf music system cd door
I have a similar stereo system and accidentally put two CD's in one tray and it got stuck and could not open. What I did was unplug everything from the unit and took off the side panel. After some careful fiddling I got it to open. You could try something like that.
Dec 30, 2007 | RCA RS2531 CD Shelf System
208 people viewed this question
 Grubhead
Grubhead
