Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Open the case
How do I ope the casing of my maxtor personal storage 3200 without breaking it?  Do you know if it have an ide inside?
Thank you,
Robin
    Problem Solver:
  • 16 Answers
To open the Maxtor 3200 personal storage device you must first remove the two screws at the connector end, and you might as well **** the white paper label located between the power and USB jacks, because this label will hold the cover halves together and fool you into thinking that you haven't unhooked all the hidden latches!
To open the case without scoring the plastic, you must be very gentle. Preferably use a thin rigid piece of plastic to do this, but if you don't have such an object you can substitute a thin, clean, metal putty knife. A flat blade screw driver is too narrow and you'll probably score the case if you attempt to pry it apart with one of those. However, it is possible that if you aim the screwdriver blade carefully and only press down, but do not twist, you may succeed. It is useful to know that the six latches are on each side exacly 2 1/8", 4 3/8" and 6 1/4" inches from the connector end. These latches extend down from the TOP case-half (which is the half that contains the thin Maxtor label), and hook onto tabs protruding inward from the bottom half. Open the cover ****-shell wise from the connector end (i.e., the hinge end would be the indicator light end.)
When you're done, both paper labels will of course be trashed along with any warranty. But warranties on these small appliances are pretty useless anyway because of the labor, shipping costs, delays and inconvenience involved in collecting on them. But you knew that already, which is why you were intent upon opening the box, right?
Sargeek
Posted on Jun 08, 2008
  • Thomas Sargent
    Thomas Sargent Jun 08, 2008
    The censor software on this website asterisked the word s l i c e in my last post. In case it also censors the last sentence also, here is a synonym: cut the lable horizontally!
    Real mindless, that software!
I managed to open the case of my HDD. I kind of forced it, but I know how it works. How can I post pictures?
Posted on May 23, 2008
I'm fixing (hopefully) one for a friend, this one has internal clips both sides. It's quite easy to work it open using x2 flat head screw drivers, just work them along gently and the teeth will ping out before you realise you've come across one.
If you want to access the disk itself; remove two screws and disk light cable, then the whole shielding (rubber wrappers at each corner - not glued/screwed) should pull out. The shielding itself can be prized open and the disk should be pulled from the IDE and molex connectors horizontally.
(side note: this one has a seagate IDE inside, they seem to be different brands from the same company)
Posted on Apr 04, 2008
If it is the same model I worked with, remove the two screws by the interface.  Shine a light through the slits on the side so you can see which side you need to pry down on the latches from.  Start on one end (I started on the interface end, not the power light end - of course you will be tearing the warranty sticker) and use something that will fit through the slits (I used a precision flat head screwdriver) and press down on each latch, one by one.  As a latch releases, pull the halves apart as much as they will give and put something like a flat head screwdriver or clean putty knife in the space to keep the latch from re-engaging.  Once you have the first two latches freed, the halves stay apart rather easily.
Posted on Oct 23, 2007
    Novelist:
    Champion:
  • 382 Answers
The enclosure was not made to disassemble, so you will have to fore the case open gingerly to extract the drive. It should be IDE (which is commonly known as PATA) unless the drive was advertised as SATA.
Posted on Oct 22, 2007
How do you open the enclosure for maxtor 3200
this case was difficult to take apart, remove the two screws at the one end, then the case is held together with plastic clips they are fairly difficult to get open, go around the cracks of the caseing and try to get the plastic clips to release, I think you needed to push inwards with a flat screw driver for example to get one to release, you go around the whole casing, there are alot of them and I recall I broke off most of them myself, I'm not sure if they even ment this case to be ever opened.
Feb 28, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor drive fried after using inorrect adaptor. Have removed from case and tried IDE USB cable still will not start, help!!
The board on the drive is dead, try searching for a drive with the same model number and firmware and switch the boards.
Dec 24, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
I need a complete 3200 Maxtor 200GB Personal External unit -- case and all, not just the HDD according to my friend. Is this right?? I do not have the existing case as this was discarded when it was opened...
Hi bizemail,
Well, I'm not sure why you discarded the old casing. If you recieved a replacment from Maxtor, they would require the drive and case, or your warranty would of been voided. Your not suppose to open those cases. However, now that you have, you can test the drive by just loading it your computer (desktop I'm hoping) as a slave drive. Make sure your pin settings on the other drive is set to master, and add it in. If it works Windows will find it and add it as new hardware. If it doesn't, then their something wrong with the drive. I'd call whomever you purchased it from.
Good Luck,
And don't forget to leave a rating,
Thanks
Mark
Sep 15, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Need to locate a working identical Maxtor 3200 200GB
Well this is not how I like to answer questions on this forum, but here is a place to start looking for your drive. I hope this helps, there are some listed.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=+Maxtor+3200&_sacat=See-All-Categories
Was burnt out can I save files how can I
If the drive works independently of the case then yes you'll be able to recover your info. The drive must be removed from the case and then slaved onto another hard drive either using a USB bridge or connecting as a secondary IDE drive.
Apr 02, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
How can I open the Maxtor Basics 500GB case??
See this link:
http://www.computer-aid.com.au/blog/2009/02/17/how-to-take-apart-a-maxtor-basics-external-35-usb-drive/
Mar 28, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200 backup drive not recognized in my computer to access
http://forums.seagate.com/stx/board/message?board.id=PersonalStorage&message.id=510
Re: whishels
Options Options
eltigre
New Visitor
eltigre
Message 23 of 61
Viewed 3,676 times
My Maxtor 3200 died also. I took the following steps to get it running again.
(1) Remove plastic box from around unit. Carefully stick a screwdrive in the case division and pry it apart. It is not easy, but do will finally come apart.
(2) inside you will find a perforated metal box. There are two screw on each side of the box. Remove and separate the two halves.
(3) there you will discover that inside is just an ordinary Maxtor hard drive like you would buy in the electronics store. Attached to the HD is a PC board. There are 3 screws holding the PC board down. Remove the screws and carefully remove the HD and PC board.
(4) unplug the powere plug and the IDE interface from the HD. Now you have a HD that you can install in your own case (as long as you have a desktop unit and not a laptop).
(5) I installed the HD in an empty slot, connected the IDE cable that was already there (between the CD and IDE interface), plugged in the power plug, fired 'er up, and voila, works like a champ.
I suspect that the problem is in the interface (PC board), since the only thing I did was remove that from the equation. Hope this helps
Kudos! Thanks!
09-09-2008 09:36 AM
Dec 31, 2008 | Maxtor BASICS Personal Storage 3200...
Problems reading data
sounds like a shorted drive or controller board inside the case.
try direct plug to pc ide cable with cable select on its own ide .. take cdrom off and put it on that cable.
Jul 09, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200 harddrive broken
First thing First, detect and isolate the problem:
take the HD and connect it to the computer (DATA AND POWER CABLES right connected) and see if Operative System detects it and you can partition, format and write and move data to and inside it without problems.
If you can and the system works OK with that... your HD is working so take a breath. If not... you HD is down and well... there is not much to do without expending money.
If you succeed, just try powering your case without the HD and of course with the right power supply... the one that comes with the case. if the case can be powered for a few hours with no problems nor rare noises... connect the HD to it and try.
The info you are giving is very incomplete, I don`t know what you did, what system are you operating, Do not know what you know about computers, so I do not know what to explain and what you know already.
Good Luck
Feb 29, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
5,435 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
