Question about HP Pavilion dv7-1137us NoteBook Intel Core 2 Duo T5800 17.0' Wide XGA+ 4GB Memory 250GB HDD...
Need to remove keyboard
How to remove hp dv7 keyboard
4 Suggested Answers
rulds2008
  • 3866 Answers
SOURCE: how to put hp pavilion dv7-1245dx key back on the
They just snap back on but notice if the key is broken then what you need to do at this point is by a replacment key or buy a replcement keyboard.
Posted on Jul 31, 2009
laptopwill
  • 115 Answers
SOURCE: Some keys are not working
While the model is not the same, the method is the same. The key board procedure begins on page 61. If it becomes necessary to pry on the plastics, use a guitar pick or some other hard plastic item to pry not medal. I use a pot scraping tool found at kitchen supply stores for about a dollar. Good luck.
http://h10032.www1.hp.com/ctg/Manual/c01951704.pdf
Posted on Apr 07, 2011
bendarden
  • 984 Answers
SOURCE: where is the keyboard light button on HP Pavilion dv7-1245dx
To turn on and off keyboard lights,press Fn key + space bar once at same time.
Posted on Jun 12, 2012
How do i re-attach the up arrow key on my hp pavilion dv7-6143cl? It has come loose but all of the parts are still intact.
Hello thf you look closely at the place where the key fits examine it and look to see if there are any broken tabs if not the key should simply press back in it does take some pressure and you should feel a snap when it is locked in place
Now if it does not then the key itself may be faulty which means you can get a another key from a old key board or just replace the keyboard itself they really are not too expensive ok
Hop this helps
Best regards Michael
May 18, 2014 | LotFancy Black keyboard for HP Pavilion...
Where is the keyboard light button on HP Pavilion dv7-1245dx
Jun 12, 2012 | HP Pavilion dv7-1245dx Notebook
How do I remove/replace the keyboard from a HP Pavillion dv7-2277cl
1. Remove 6 screws from the bottom of the case (as shown). These screws hold the accessory cover.
2. Remove one screw securing the CD/DVD drive. Slide the CD/DVD drive to the left to disconnect it from the motherboard. Remove the CD/DVD drive.
3. Remove all marked screws from the bottom of the notebook.
The yellow circled screws secure the keyboard cover, and the green one secures the HP Pavilion DV7 keyboard.
4. Turn the computer display-side up and open it as far as possible. Insert a guitar pick or small flat screwdriver between the keyboard cover and case and slowly move along the side.
5. Lift the keyboard cover. Be careful, it's still connected to the motherboard. Release the zero insertion force (ZIF) connector and disconnect the cable from the LED board. Remove the keyboard cover.
6. Remove the four screws that secure the HP Pavilion DV7 keyboard.
7. Lift the rear edge of the HP Pavilion DV7 keyboard until it rests at an angle. Slide the keyboard back to disengage the tabs on the front edge of the keyboard from the top cover and rest it on the display.
8. Release the ZIF connector to which the keyboard cable is attached and disconnect the keyboard cable. Remove the HP Pavilion DV7 keyboard.
You can refer to the complete article via the link below:
http://laptoppartstore.weebly.com/replace--remove-hp-pavilion-dv7-keyboard.html
Apr 08, 2012 | HP Pavilion dv7 Keyboard (483275-001)
Need directions on replacing keyboard, already have new one
Carefully remove the cover from the top edge of the keyboard, prise it off from one corner carefully, it's held in by little tabs that click into place. you can then do the rest easily.
Thanks
Adam
please leave me some feedback
Feb 18, 2011 | HP Pavilion dv7 Keyboard (483275-001)
My esc key popped off of my pavilion dv7. do you
you can search ebay
or
http://www.individualkeys.com/servlet/the-14355/HP-DV7-Laptop-Keys/Detail
Jan 14, 2010 | HP Pavilion Laptop dv7-1025nr
I have an HP pavilian dv7 laptop and i keep hearing a rattling noise -possible screw in fan or broken fan because it overheats and rattles when i move the computer, i cant figure out how to open the back...
Hi!
I couldn't find a disassembly guide for the DV7 but I did find one for a DV9.
http://www.insidemylaptop.com/remove-hard-drive-memory-wireless-card-keyboard-hp-pavilion-dv9000/
This might help give you an idea on what needs to be done. Essentially there's a few components you need to remove first before you can undo the main case screws to pull apart the case.
Also worth mentioning is the fact that you'll likely have to go in through the top as opposed to looking at the fan from the back. This means taking out the keyboard etc.
Hpoe this helps
Nov 21, 2009 | HP Pavilion dv7-1132nr Notebook PC
How to put hp pavilion dv7-1245dx key back on the
Jul 31, 2009 | HP Pavilion dv7-1240us Notebook
Hp dv7 keyboard issue
Hey guys, I just had this problem, I have alot of problems with my DV7 laptop, top panel started malfunctioning, then it thought i was turning the volume up and down by myself, also my g h ' and backspace stopped working along with other problems that I don't want to bore you guys with, whats the answer? Remove the battery for 10-15 seconds and clean the connectors and this has ALWAYS fixed all my problems. Hope this helps.
May 27, 2009 | HP Pavilion dv7-1020us Notebook
HP Pavilion dv7-1137us NoteBook Intel Core 2 Duo T5800 17.0' Wide XGA+ 4GB Memory 250GB HDD... Logo
122 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
