Question about Refrigerators
Suddenly stopped cooling. Fan runs compressor doesn't.
Kitchenaid KSRP25QDWH00, side-by-side, no-frost refrigerator mfd 04/95. Suddenly stopped cooling. Fan runs, compressor does not run. No previous history of any other problem since new. Is this problem likely due to relay (part # 2154697) or capacitor (#2169137)? Any other suggestions or diagnostic tricks? Thanks for your help. donaldsass@ihtw.com
  • donaldsass May 13, 2009
    No, the compressor does not click on at all. To me that indicates a faulty relay. I tried to remove the overload/relay assembly but don't see a way to remove the cover. Is there a trick to removing the cover box? Thanks again for your help.
    Thanks. I was afraid I might break the cover by prying. I thought there might be an easy way to get the cover off but apparently not. You've given me courage to keep going. Thanks again.
    President:
  • 1,136 Answers
Hi, If fans are running, most likely relay and/or capacitor. Do you here the compressor try to click on at all?
Posted on May 13, 2009
  • Victor
    Victor May 13, 2009
    If the fan in the freezer is running then there shouyld be power to compressor. If that fan does run, I believe this cover has a wire or strap wrapped around it. Just use a flat screwdriver and release the clamp. If it does not have a clamp, use the screw dirver bad pry between the compressor and cover. The cover should come lose, it might take a little pressure. Sounds like you are going the right direction.
I have a Hotpoint HSS25GFPEWW side by side.....initially the ice maker stopped crushing and dispensing ice....then the freezer started to warm. I cleaned the condenser coils and confirmed the condenser...
dead if the compressor is running and theres no cooling or frost on the evaporator you have leaked out all your freon only way to fix is call a pro about 600$ to fix
Aug 15, 2012 | Hotpoint HSS25GFP Side by Side...
I have an amana side by side ars2364aw thet suddenly stopped cooling both sides.The compressor and compressor fan opperate, but the evaporator fan by the coils inside doesn't. I tried replacing both...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 03, 2011 | Refrigerators
I have a KitchenAid KSCS25FKSS00 side-by-side refrigerator. Freezer suddenly began warming and noticed divider between freezer and fridge very hot. Removed back panel and noticed condensor fan was not...
Yes, you need to replace that fan...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 01, 2010 | KitchenAid Superba Architect KSCS25INSS...
Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2010 | Jenn-Air JCD2389G Side by Side...
My freezer is not freezing and now the fridge is not cooling. Is is worth fixing?
Good day,
If the compressor has failed, then replacement of the machine might make sense, but a refrigerator is a complex device with many components, that can be replaced at nominal cost.
1. The defrost system failed. Usually shows up as frost building up on the rear panel of the freezer compartment. Consists of 3 parts.
2. Circulating fan motor in freezer compartment failed.
3. Condenser cooling fan motor located in the bottom rear of the machine behind the rear cover near the compressor.
4. Compressor not running because the start components failed.
These are mounted to the side of the compressor and consist of
the overload, start relay, and on some models a start/run capacitor.
5. Defective thermostat, not running the machine or not running it enough.
Once these basic items are checked, your question can be answered.
Nov 28, 2009 | KitchenAid KSRG25FKSS Side by Side...
SAMSUNG FRIDGE FROSTING
some heat is normal on the outsides and center divider. how to muche will usually mean the the condesor fan may have stopped working and is unable to cool the condensor coils and compressor.this could cause it to run longer and build up frost
Sep 16, 2009 | Samsung RS2630SH Side by Side Refrigerator
Freezer side of side by side stopped working suddenly
YOU NEED TO SEE IF THE EVAPORATOR IS ALL FROSTED UP IF IT IS THEN YOU MOST LIKELY NEED TO DEFROST YOUR FREEZER LET IT ALL MELT DOWN ABOUT 3-4 DAYS
THEN YOU HAVE TO CHANGE YOU DEFROST LIMIT OR BI-METAL BUT IF YOUR NOT FROSTED UP HAVE TO FIND OUT IF THE COMPRESSOR IS WORKING TO DO THAT YOU HAVE TO TAKE OFF THE BACK PANEL CHECK THE HIGH SIDE SO TO SEE HOT LINE LOW SIDE SHOULD BE COOLIF NONE OF THIS THAN YOU MIGHT HAVE A BAD COMPRESSOR OK GEORGE
Apr 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba compressor
The compressor relay is located on the compressor under a cover. Before you go to the compressor I would check for other problems that you can see and hear. If the compressor is running there is nothing wrong with its relay.
1. Check the condenser and make sure it is clear and free of dust.
2. If the compressor is cool or cold check for a bad temperature control.
3. Check the freezer compartment for frost on back wall.
May 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kenmore refrigerator not cooling or freezing
my refrigerator suddenly stop cooling all the fans run normal. It makes a click Noyce.
Jan 11, 2008 | Refrigerators
Failure
compressor is hot but is it running. one likely thing i would check is the start relay on the compressor.
Dec 09, 2007 | KitchenAid KSRS25IL Side by Side...
Refrigerators Logo
245 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
