Question about GE 84918 Remote Control
How do I program my Toshiba VC-622 VCR/TV remote?
I have an old remote that works for a VCR and I did have it working for the TV but one day someone was playing with buttons and it stopped working. I was wondering how to program my Toshiba vc 260 remote...
Try the following procedure:
1. Make sure there are working batteries in the Toshiba remote control.
2. Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
3. Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
4. Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed.
Feb 28, 2011 | Toshiba Vc-260 Remote Control
How i can program my remote jensen jer 622
Try the following steps. 1. Turn on the tv 2. Press and hold the "tv" button. The light should turn on and stay on. 3. While holding the "tv" button down, press and hold the on/off button. The light should go off, but if you keep holding the buttons, it will turn back on. 4. When the light turns back on, release both keys. 5. Press and release the on/off button repeatedly (while pointing the remote at the tv) until the tv shuts off. 6. As soon as the tv turns off, stop pressing the on/off key and press "stop." This will save the code that controls your tv. 7. If you wish to program your remote to other devices (vcr, dvd, etc.), use the same process described above, except turn on the device you want to control and press the component button that corresponds to the device, rather than "tv." For example, if you want to program your remote to a vcr, you press the "vcr" button instead of the "tv" button, as in the instructions.
I hope this helps! Sincerely, Der Strom
Apr 14, 2010 | Jensen 143307 Remote Control
Need manual for toshiba vc-625 remote control
http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/vcr/w627_ownman.pdf
This remote is covered in the owner's manual for the VCR it came with. Even if your VCR is not the exact same model, the remote is the same.
-Rob
Apr 04, 2010 | Toshiba 13A21 13" TV
Toshiba tv/vcr remote code.
Ok, try using the guide, there you will find the codes, if you dont have one try going to a local store that sells your product.
Dec 10, 2008 | Toshiba CT-90157 Remote Control
Toshiba VC-614S
Try this pdf. I just reprogrammed my Toshiba remote to control my Sony TV.
Good luck.
http://tacpservice.toshiba.com/consumerproductsupport/Manuals/vcr/w614_612.pdf
Dec 07, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Lost remote on toshiba w528
You can select those to record with out the remote by setting the record timer to record. For example, if you want to record from one of those input channels on Friday 1 January 2009 at 9:00 to 11:00, it will allow you to choose that as an input channel in that program menu. If not, you will want to buy a replacement remote. VC-522 is no longer available, but VC-617 and other models are.
Nov 16, 2008 | Toshiba W522 VHS VCR
Toshiba vc-522
www.toshbia.com go web site dl manel shows u codes toward back pages k
Oct 07, 2008 | Toshiba W522 VHS VCR
Lost manual to program remote for Toshiba M-68C VCR
-Push "TV" and release.
-hold prog and enter the two digit code. (Try 10 for a phillips) release the prog button and see if it worked.
If not try experimenting with other two digit codes as I don't think there is an auto search for this remote. At worst it'll take 99 attemts to work ;-)
Feb 03, 2008 | Philips VR330 VHS VCR
Toshiba Vcr 4 head VC-454
I cannot program my Toshiba VC 454 remote control for my tv, could you please help.
thanks
Mar 18, 2007 | Toshiba M635 VHS VCR
GE 84918 Remote Control Logo
355 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
