Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
White permanent lines on Mits 55
These have probably occurred from 4X3 format pillar box which I had in black instead of gray.  Is there anything I can do get rid of them.  I reset factory convergence and adjusted color settings but no help.  They are most prominent when the picture is brighter.  Please help.  Thanks
    Problem Solver:
  • 11 Answers
If you have had the pillar box on for a long time and now you are viewing wide screen format the crt's have had more or the phosphorus worn on the 4x3 portion of the crt's witch will give you a different shade where the pillars were the only cure is to replace the crt's
Posted on Oct 16, 2007
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
White Band On Screen - Remove It!
if a white band is seen---go to a blank or unused video input and examine the screen---both sides---if it is seen on both (even if more so on one side) you may have burned the screen by using the 4x3 format.
If this it is permanent damage.
Mar 31, 2012 | Mitsubishi LT-46133 46 in. HDTV-Ready LCD...
I am trying to install a Panasonic stereo to a mitsubishi mirage 1996, trying to find wire diagram for vehicle, the one I found on net was completely different from wiring colours in vehicle.
Constant 12V+ Red/Black Switched 12V+ Blue Ground Chassis Illumination Green/White Dimmer Black/Yellow Antenna Driver's Pillar Front Speakers 4" Dash Left Front (+) White/Blue Left Front (-) Black/Blue Right Front (+) White/Red Right Front (-) Black/Red Rear Speakers 6" x 9" Rear Deck Left Rear (+) Yellow/Blue Left Rear (-) Gray/Blue Right Rear (+) Yellow/Red Right Rear (-) Gray/Red
May 14, 2011 | Mitsubishi Mirage Cars & Trucks
What is the color code for wiring of 1999 honda civic
Honda Civic Stereo Information Constant 12V Blue/White Switched 12V Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Driver's Pillar Front Speakers 6 1/2" Doors Left Front ( ) Blue Left Front (-) Gray/Black Right Front ( ) Red/Green Right Front (-) Brown/Black Rear Speakers 6" x 9" Rear Deck Left Rear ( ) Blue/Yellow Left Rear (-) Gray/White Right Rear ( ) Red/Yellow Right Rear (-) Brown/White
Mar 07, 2011 | 1999 Honda Civic
Hi, I have a Macbook running Tiger 10.4.11. I have yet to figure out a way to print in black and white from safari. HELP!
When you go to print (apple/p) and the dialog box comes up (lists printer, presets, copies, etc)
There should be a gray horizontal line across the middle of this dialog box. Note the drop down box that is on this gray line ... this is an important drop down box. When you select different items in this box, all the options underneath the gray line change.
The selection in this box is probably "Layout" by default. Change it to look at the different options, but as things change below the gray line don't get confused about which is the "main" selector drop down for changing all the options .. it's the one on the gray line ....
I'm using an HP printer, and when I select "Paper Type/Quality" in this drop down, I get an option under the gray line that says "color" -- the options in that box include the option for "Grayscale"
If I were to select Grayscale, then the printer will print only in black and white and shades of gray.
That's the easiest way to do what you want, and it will apply to any program you are printing from, since you are selecting "Grayscale" from the print dialog.
Look through all the different variables in the print dialog to become familiar with them.
If you often use one particular setting and don't want to have to go through the sometimes confusing search through the drop downs, since they change back to their defaults each time you print, then you can set a "Preset" - this will remember your settings and allow you to get to them easily ...
To do this, first select all the options the way you like them, for example you might select Grayscale under the Color option under the Print Quality section. Then, before you actually print anything, go the the top where it says "Presets" and do a "Save As" and choose a Preset name that will be meaningful to you ... like "grayscale" -
Next time you print, keep an eye on the preset - it may NOT go back to the default of "Standard." It may stay on the last-used Preset ... so keep an eye on it before hitting the print button.
Hope this helps!
For help with Public Address system feedback, and great AA speaker tapes and MP3 downloads, my website at rexark.com is a great resource!
Feb 08, 2010 | HP Photosmart C6280 Printer
Have a gray bar on the side of screen do not know how to get rid of them
If you have a gray band left and right on the screen--in the background----It is a burn on ALL THREE OF THE PICTURE TUBES THIS SET USES.
What happens here is if Contrast (picture) is set all the way up and the set used in the 4X3 mode---it will burn a permanent mark into all three tubes.
If this is the case you may just want to live with it as all three tubes would have to be replaced--over 800 dollars parts and labor depending on where purchased.
I saw a lot of these with this problem when they were fairly new---the DEFAULT setting on these sets is contrast all the way up and this is what burns the image of the 4X3 into the tubes.
Let me know if you have questions. I know this is not good news, but based on your description I think it is what has happened.
If this information told you something you did not know, rate this solution as I do this here for FREE.
SD TECH
Nov 19, 2009 | Mitsubishi WS-55908 55" Rear Projection...
Picture is too big for screen
You will have a button on the _original_ remote that says Format, Aspect Ratio, Zoom, Size or just AR. It will cycle through Normal, Stretch, Partial Zoom, Zoom, Gray Bar, or the like. You are not in Normal but in one of the Zooms. Stretch is used to make 4x3 movies fill a 16x9 screen, may not be desirable. Zoom is used to fill the 16x9 screen with movies that have been letter boxed. Gray Bar fills the sides of a 4x3 picture on a 16x9 set with gray to "avoid" burn in. Use normal except zoom on LB. -Ken
Oct 04, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
Dvd's aren't fitting my screen, the sides and top/bottom is being cut of. I've tried the display menu, zoom, and making it widescreen, and it doesn't work.
Are you playing wide-screen movies on a 4x3=1.33:1 (standard=SD) TV? DVD output by default is SD. Even 16x9=1.78:1 (HD) movies with have top and bottom bars. Many "wide-screen" DVDs are squeezed horizontally so that you have to stretch them. Many theatrical releases are up to 2.7:1 or so. Side bars indicate you have the DVD output set for 4x3 and your TV is HD-like. There are usually controls for the screen format on HD TVs--no controls on SD TV. Hey, early movies were 1:1--take them side bars. More on aspect ratio (AR) in Wiki, I bet. With letterbox of SD you can get "pillar box" with black on all 4 side. Get a better source and/or choose a different AR. -Ken
Jul 15, 2009 | Pioneer DV-400V DVD Player
Vertical lines in the picture on light background only
It sounds like you have Image burn in on your crt's. This happens when you watch programs in 4X3 mode. (The sides are blacked or grayed out and the picture is centered in the screen). The only way to fix this is to replace the crt's. I wish I had better news. Let me know if I can be of further assistance
Jan 28, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Baseball fan
Here's the wiring: black from box to black from fan; red from box to black with white line from fan; copper from box to green from fan; white from box to white AND gray from fan. Hope this helps.
Jan 17, 2009 | Hunter (25417) Ceiling Fan
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
