Question about BenQ PDP-46W1 46 in. HD-Ready Plasma Television
Hitachi PDP 55HDT79 got no picture
I have a 55HDT79 that have no picture but sound OK. I replaced Power Supply Unit (HA01751). As from basic troubleshooting flow chart, all five LED on Digital Main P.W.B are turned off after program is loaded, that means no error.
Still, there is no Va(60V) and Vs(80V) coming out from the Power Supply Unit (HA01751) to drive the screen. I have the unit just over one year and a half.
  • Wai Chu May 13, 2009
    Thank you for the quick and good response. Actually, I checked the 3 feedback signals from the Main P.W.B. The measurement are correct. I have not check the screen circuit yet. I will follow up on this.
    President:
  • 1,348 Answers
That power supply is a switch mode power supply,which means it looks for an input signal to turn on.
that signal comes from the main pc board.
if there is excessive current draw,it will shut down.
check the input,and the screen circuit it is driving
Posted on May 13, 2009
  • rbarry1068 Dec 02, 2010
    Kirtec, can you give us a little more information? I have the same problem. My 55HDS69 attempts to turn on, I see the Vsago signal go to 3.3 v for about a second, I see 80 V on the output, for about a second, then both go to zero V. So, where would the "excessive current draw" occur? How do you "check the screen circuit"?
    Bob
What board would be needed to repair hitachi 55hdt79 lost picture sound ok?
Good one (great description).
Power-board...!
Those gum-wrapper capacitors they are using can snap when they croak.
Have fun save $$$$
(but take lots of detailed pictures BEFORE you start).
Jan 03, 2016 | Hitachi 55HDT79 55 in. Plasma HDTV
Picture problem
Have you try to unplug the unit for a couple of hour, then plug it again.. thhis is to reset the unit itself..
thank you
May 29, 2008 | Hitachi 55HDT79 55 in. Plasma HDTV
I have a Hitachi plasma model# 55hdt79 that went black out. No display at all. Sound is ok. We checked the power supply unit and found out that 90v output is missing. We changed the power supply unit...
It sounds like the transformer on board has gone out (not the one in the power supply) and is no longer charging the panel. the board internally that holds the transformer will have a model number on it, any decent repair facility should allow you to order the parts if you have the part number already. The transformer will be fairly hard to miss. It is a large block ( a few inches X a few inches ) that if you look at carefully it should look like a large coil of copper wire. Or should look like there is a large coil of copper wire in it.
Mar 10, 2011 | Hitachi 55HDS69 55 in. Plasma Television
Tv won't come on...light in corner just blinks red
OK Its your power supply and it can be fixd for free due to a recall.
PLEASE READ BELOW what I found out.
Here's the whole notice:
Important: Free Power Supply Replacement for Certain Pioneer Plasmas
Pioneer is continuing to offer a free, in-home power supply replacement for certain of its second and third generation plasma models listed below for consumers who experience a problem with the original power supply. If a consumer model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded in your home at no charge.
Consumer Plasma Models (12 listed):
PDP-505HD
PDP-503PU
PDP-5030HD
PDP-5031HD
PDP-433PU
PDP-4300
PDP-4310
PDP-4330HD
PRO-800HD
PRO-800HDI
PRO-1000HD
PRO-1000HDI
The issue with the power supply in the plasmas listed above does not pose any health or safety risk. Pioneer has received reports that the power supply in the affected models may fail. In some cases, a loud popping sound can be heard when a power supply fails. After the power supply fails, the plasma is no longer operable.
We apologize for any inconvenience, and we thank you for your cooperation.
Apr 02, 2010 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Have a Hitachi 55hdt79...no pictures only sounds.
It might be the power supply, check the main power supply. Audio power supply is seperate to main power supply, thats why you have a sound.
Jul 24, 2009 | BenQ PDP-46W1 46 in. HD-Ready Plasma...
With no picture but only sound on my Akai PDP 4294
Try replacing the Y-sustain board. Might have to replace buffers attached to it too. Have you had it diagnosed? My picture went out and I replaced the power supply board. Worked for 2 weeks then acted up again. Got a different power supply board. Same thing 2 weeks later. Was told it now was a bad Y-sustain board. Replaced y-sustain board. Worked OK for about 2 hours then started having picture issues. Not the same issues before power supply or y-sustain problem. Was told that you might have to replace buffers attached to y-sustain when you replace y-sustain. Tired of dealing with it and only watch a couple hours a day, so I don't always have the problem unless I watch the TV for a long time. Will eventually replace buffers to see if that works. I would definitely find a place that gives free estimates or close to free to get a technician diagnosis. Then you can decide if you are able to do the work yourself.
Jun 06, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Screen went black while watching, no sound
Almost for certain your power supply board is bad, Can be repaired at the component level only if you have some electronics savy! Good Luck!
Dec 26, 2008 | Hitachi 55HDT79 55 in. Plasma HDTV
BenQ PDP-46W1 46 in. HD-Ready Plasma Television Logo
1,216 people viewed this question
Top BenQ Televison & Video Experts
Electro Med Services...
Are you a BenQ Televison and Video Expert? Answer questions, earn points and help others
