Question about Northstar Electric Stationary Air Compressor - 7.5 Hp, 26.2 CFM At 90 Psi, 208 - 230 Volt
Need rotation direction
Hooking up northstar compressor , can't find rotation direction.
  • 530 Answers
Most are counterclockwise rotation. If you have the fly wheel the spokes double as cooling fins for the pump. The rotation will be blowing on the pump regardless which way the wheel is mounted. If you have no fly wheel then all I can say is all the Northstar pumps I've ever seen are counterclockwise rotation.
Posted on May 19, 2009
GASKETS FOR VALVE PLATE WHO IS MFG ?
contact Northern Tool,scroll down the page and you will see parts offered as well as a phone number
FREE SHIPPING NorthStar Air Compressor Pump 2 Stage 3 Cylinder 14 9 CFM 90...
May 04, 2016 | Northstar Air Compressor Pump 569cc, 22.9...
You answered a question about a cadillac surging when it was started back some time ago. I just read it. Would this apply also to a 1993 Fleetwood?
Surging on start up is normal for the Cadillac with a Northstar V-8. The car will feel like it rocks forward and back because the engine is mounted sideways and the rotating mass of the crankshaft rotates front to rear direction.
Oct 29, 2015 | 1993 Cadillac Fleetwood
How do I fix screen on Northstar 951xd?
I have the same problem and am about to buy a display from Mavin.com. This is on the product page for the display:
**Note that this is not a direct replacement for the Northstar,but with some soldering it can be made to work.It is the same screen as used in the NorthStar units, it hasdifferent connectors. What this means to you is that youwill need to solder the connections directly to this board.Once connected, it works just fine.
Aug 13, 2015 | Northstar 951XD GPS Receiver
Does it have any arrow located on the compressor showing its roation
motor rotation is ok but any other options for check this reason ?
Mar 22, 2013 | Ingersoll Rand Tools & Hardware - Others
Serpentine belt broke, and I am told I need a new compressor. We found one but it is from a seville with a northstar engine. Can I use this? Thank you
Hello: All Cadillac Devilles had a Northstar starting in 1996. It will not make any difference if it is a SLS (275 HP) or a STS (300 HP)
Sep 14, 2011 | 1998 Cadillac Seville
What is the toqrque spechs and order for a Northstar 4.6 engin for both head and main & rod barngs. Does the main barnings have a order
If you have to pull a cylinder head on a 1993-1999 4.0L or 4.6L Northstar V8 to replace a gasket or do a valve job, do not reuse the old 11mm head bolts. Also, GM has revised the head bolt torque values and tightening procedure as follows:
  1. In sequence, torque all bolts to 30 ft.-lbs.
  2. In sequence, rotate all bolts an additional 70 degrees.
  3. In sequence, rotate all bolts an additional 60 degrees.
  4. In sequence, rotate all bolts another 60 degrees.
  5. Torque the front three M6 head bolts to 106 in.-lbs.
Dec 09, 2010 | 2003 Cadillac Seville
Charlieskidstrucking@comast.net
Sorry but this compressor will only supply up to a maximum of 130 psi. That is all it will do, so this compressor will not suit your needs of 175 psi. There is no way to make it produce more. You simply need a larger compressor. This Northstar compressor will suit your needs. http://www.northerntool.com/shop/tools/product_290954_290954
Apr 25, 2010 | Northstar Air Compressor Pump 326cc 105...
3 phase air compressor wrong rotation
yes it will you need to make sure you have the proper wires connected to get either clockwise or counter-clockwise rotation.
try changing the hot wires around to correct your problem
Mar 31, 2010 | Air Tools & Compressors
Correct rotation of copressor
Checked all the IR compressors in stock and all turn counter-clockwise facing pulley, however you could check the pump for fan angle on pulley. The fan on the compressor pulley blows air towards the pump. Generally, pumps turn CC because that would allow for the use of gasoline engines which all turn CC. Please email you questions, and Good Luck.
Jan 27, 2009 | Ingersoll Rand 2340/2475 Electric Air...
Northstar Electric Stationary Air Compressor - 7.5 Hp, 26.2 CFM At 90 Psi, 208 - 230 Volt Logo
358 people viewed this question
Top Northstar Air Tools & Compressors Experts
John Trevino
Lawrence Oravetz
Marty Shuman
Marty Shuman
Are you a Northstar Air Tool and Compressor Expert? Answer questions, earn points and help others
