Question about Troy Bilt 5.5hp Self Propelled Mower
Snapper riding lawn mower won't start
I just replaced my motor on my lawn mower ( briggs and straton 17 hsp overhead) and now it won't crank. It was clicking and I thought that it was the selinoid switch but, once I replaced that it won't even click now. The starter has no fire and the engine won't start.The battery has plenty fire I tried to jump it off but, no luck. The flywheel works fine. I put the hot jumper cable on the starter bolt and no fire.This motor used to work by getting jumped off by my car.could it be the starter? Or do I have something wired wrong?Thanks for any advice.
    Problem Solver:
My snapper riding mower will spin but will not start. It was o.k. when I parked it a week ago. Now it won't start 28115BV
Posted on Nov 26, 2010
    Sergeant:
  • 201 Answers
If you put hot lead from battery jumper cables on starter post and ground jumper cable to motor frame and got no reaction your starter is bad.
Posted on May 13, 2009
  • 31 Answers
Sounds like you have two problems. If the solenoid does not click, either is it not working, or the low current circuit (small wire(s) to the solenoid) are open somewhere, assuming the battery is good. This could be a safety switch or loose wire. If you connect battery voltage directly to the bolt on the starter (for example with a jumper cable) and it does not turn, the starter is not working. If there is no spark on the starter bolt, it most likely is the brushes in the starter. They could be stuck in the holders or worn out. Replacing the brushes is much less expensive than replacing the starter. Remove the end plate on the starter that is closest to the wire bolt to inspect. If there is spark on the starter bolt but it does not turn, the shaft may be frozen (especially if you haven't used it for a while). This can be fixed by removing the starter end plates and putting a drop or two of engine oil on the shaft after cleaning up any rust or corrosion.
Snapper rear engine mower wont go forward or reverse
the drive system on that mower is a rubber friction wheel after time the rubber become brittle and falls apart and also wears it you tighten the vent on the fuel cap and stand it up on the rear bars you can see it it rides on a alum wheel held in by 3 or 4 bolts easy to change if it has electric start you need to remove the battery if you leave it up on it back for more the 30min
Jun 13, 2012 | Garden
I have a snapper 28 hi vac riding mower that won't
first try and start it with carb cleaner or starting fluid with the air filter out if it fires then its a carb/fuel problem if not it could be a spark problem remove the plug connect hte wire back up and crank the engine over while looking for spark if no spark disconnect the kill switch wires from the side of the engine should be a single wire near the throttle cable if spark with that off the problem is in the wiring or safety switch if still no spark its the coil
Apr 23, 2012 | Briggs & Stratton Garden
Just replaced head gasket, now has to much compression and won`t wind over fast enough to start. have had starter checked and seems ok .10.5 hp briggs and stratton motor in a murray 32 inch ride on lawn...
A head gasket will not greatly increase the compression in a a Briggs motor.
My question is Why did it need a head gasket to begin with?
Will bet it was not running...
A more likely cause if not a fuel problem is to check engine oil if that is good remove the wire from the low oil sensor and see it it will start up for you.
r/
David
Jan 23, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Lawn mower will not stay cranked unless you keep pouring gas into
common problems to all older lawnmower, lots of dirt and dust the mower goes through and ages. I would first start by taking the carb apart and clean the filter with soap and water, allow it to air dry. also carburetor prob need rebuilding or replacing. Pick up some Carburetor cleaner at any auto part store and spay it down the carb, dont be afraid to spray allot in there and let it dry for 1/2 and hours. carb tend wear and parts need replacing just like any engines. 99% of the time lawn mower carb goes out before the engine will and common problems with all lawn mower. If you not mechanical incline or dont want to rebuilt it, just buy the whole new carb and replace it, fairly cheap easy to replace and will last you another 10 + years or more. www.briggsandstratton.com
Sep 01, 2009 | Omega Rear Drive Wheel Snapper Mowers
MTD lawn tractor. 16 hp twin briggs straton
THIS SOUNDS LIKE A THROTTLE CABLE LINKAGE PROBLEM.WITH THE HOOD OPEN AND MOTOR RUNNING RUN YOUR THOTTLE UP AND DOWN WHILE LOOKING @ THE LEFT SIDE OF THE MOTOR TO SEE IF THE CABLE IS FROZEN IN PLACE OR BROKE OR DISCONNECTED .HOPE THIS HELPS
Jul 15, 2009 | Mtd Garden
Troy Bilt 5.5hp Self Propelled Mower Logo
3,007 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
