Question about Samsung HTQ45 System
Samsung HT-q45 replacement cooling fan (back right corner)
Where can I purchase a replacement fan for my HT-Q45 ?  The existing one is whirring and spinning erratically, I've removed it cleaned it and have decided I need a new one.  Ideas ?
Thanks,
Joel
jcarmichael@rbagroup.com
  • SuperStroke Feb 09, 2008
    Samsung HT-q45 fan motor
    Have done the same thin the other guy did.
    Most of the time when turned on it's very loud
    Have to shut it off and back on again sometimes
    three or four times, then its O.K.
  • Anonymous Sep 21, 2008
    I have the same problem with the whirling noisy cooling fan. Where can I get a new one. I've called samsung and they give you the run around. PLEASE HELP, it happens everytime now!
    Scholar:
  • 103 Answers
Try going to Samsung support at their site. Click below
http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
They should be able to help you out.
HOpe this help, and please rate my advice, good OR bad.
Posted on Feb 04, 2008
  • 298 Answers
NP Q45 Blinking power supply
If it's the right-most status indicator on the laptop (a circle with a line through it), blinking means the computer is in Sleep mode. Just move your mouse or hit the enter key and it should wake up.
Jun 12, 2014 | Samsung Ac Adapter Cord For Np-q40 Np-q45...
I NEED A MOTHERBOARD FOR A SAMSUNG lAPTOP Q45? OR WHERE CAN A DEFECTED MOTHEBOARD GET TESTED. tHANKS
The laptop can be taken to a computer repair shop to get the motherboard checked out, at least this way you can make a better informed decision to have it repaired or possibly replace the existing one.
Mar 08, 2011 | Samsung Q45 Notebook
Samsung q45 keeps switching off
you will need to have it serviced, by removing dust interior and replacing the thermal greace on the cpu and gpu. it is overheating.
Jun 09, 2010 | Samsung Q45 Notebook
Overheating
Hi
Are you loosing coolant ?
You need to pressure test the cooling system first, with a cooling system pump, (available at any good Car Spares Shop) to test for and eliminate any leaks, and go from there !
Also have the head gasket tested, with a Carbon Monoxide gas test, on the cooling system.
Good luck !
John
A FixYa rating would be appreciated thanks !
Feb 12, 2009 | 1997 Infiniti.5 Q45
Loud whirring noise from home theater receiver
Sounds like a cooling fan is worn out. If the warranty has expired, remove the cover and there should be a cooling fan. Remove the fan. Try cleaning it out with a can of compressed air. If this does not work take the fan to best buy or circuit city and buy a replacement. I hopet his solves your problem!
Jan 09, 2009 | Samsung HT-TZ512T Theater System with...
I have a samsung q45 laptop with a problem,when yoiu press the fn key you can control the volume and brightness by pressing the up down left right keys in the right hand corner of the laptop,this was...
Install Easy Display Manager http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=HQ&CttFileID=1547991&CDCttType=SW&ModelType=N&ModelName=NP-Q45&VPath=SW/200707/20070705142636328_Easy_Display_Manager2.1.4.3.zip
Jun 25, 2008 | 2007 Infiniti Q45
1994 Infiniti Q45 fan relay?
Well, first of all that 15V thing you are removing is not a spark plug. It is a fuse. If the fuse versus sparkplug thing is challenging you may need a little help identifying a relay. But, and I am not a mechanic just a average guy, find your fan. Find the wires leading away from the fan going towards your wireharness junction. The relay shold be along the way. It iwll look like a block, pretty small, smaller than your fist, plugging into a connector with wires. Look carefully with a flashlight at the connector and relay. Carefully release the clips holding the relay into the connector. Take a crayon, yellow and make a line from the connector over therelay so you can put it back easily, most only go back one way but you never can be too catreful. Gently twist and pull the relay out of the connector while twisting being careful not to break wires of the connector. When the relay comes free take it away from your Q45 and get some alcohol and some Q-tips. Gently clean the relay prongs, the things that stick out from the relay, metal, and don't use too much alcohol. Let the relay air dry for a minute or two. Put it back together. The TCS module is way over your head. Go to a trusted garage. If the unit is bad surf the net and shop for a new one to make sure you are not getting ripped off on the price of the part. Ask to see the labor hour estimate onb his computer as well. They may charge you a bit to diagnose the problem...sorry but that is life. Love your Q45 and it will love you back. I have a 95 Q45 with 187,000 miles and expect to have it go at least 300,000 miles. Great car.
May 18, 2008 | 2004 Infiniti Q45
Samsung HTQ45 System Logo
3,836 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
