Question about Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX Zoom Nikkor Lens
I have a Nikon 18-70 DX kit lens as well and it cannot focus either. It will quickly hunts from infinity to close range while making screaching sound. I found that if I point the focus point at a lamp, the lens will slowly move to perfect focus.
  • cktruong May 17, 2009
    Thanks for your input. I'll see if I can get spare parts and repair it if possible.
  • anshuman karak May 11, 2010
    what are you trying to mean
    New Friend:
  • 28 Answers
HI I AM SAGHA FROM MUMBAI I AM A REPAIRER AND I THINK UR PROBLEM IS NOT SOLVABLE BY YOURSELF YOU HAVE TO TAKE THE LENS TO EXPERT THERE YOU HAVE TO GET THE AF SENSOR CHANGED.THIS WILL SOLVE YOUR PROBLEM DON'T TRY ANY MORE ADJUSTMENTS WITH CAMERA IT MAY CONFUSE YOU MORE.
Posted on May 17, 2009
Hi, I have a Nikon d5000. Love it. Lately, when I put on the zoom lens--Nikon DX AF-S Nikkor 55-200mm 1:4-5 6G ED, and try to take a picture it will not let me. I have it on auto-focus, zoom out
Hi Anna,
In order for your Nikon to auto focus correctly, you need to have several things:
First - focus indicator. In your viewfinder, locate it on the bottom row of the status information bar; you should see a small, green circle in the left-most position. This will BLINK when you partially depress the shutter release (or back button focus - depending how you focus your D5000) whenever the subject is OUT of focus. It will switch to "STEADY ON" when the subject is IN focus. Please note that you will not be able to release the shutter any time it is blinking unless you make a change to the setting that will allow you to release the shutter when the camera is out of focus (not recommended).
Second - light. You must have enough light entering the camera for it to detect areas of different contrast on the selected focus point. If there is not enough light there is too little contrast for the camera to autofocus and no matter how close or how far (and everywhere between) the focus is set resulting in the camera "hunting" near and far to find it. The green circle will not stop blinking. Have you tried in a well lit room or outdoors in daylight?
Third - minimum focus distance. All lenses have a minimum focus distance. Acording to Nikon, yours is rated at 3.6' (1.1m) (see: http://www.nikonusa.com/en/Nikon-Products/Product/Camera-Lenses/AF-S-DX-VR-Zoom-Nikkor-55-200mm-f%252F4-5.6G-IF-ED.html for full specs on this lens). This means your subject needs to be at least 3.6' away to be able to focus on it - manually or aut0matically - it makes no difference. There are lenses that do "very close" focussing that are called "Macro" (but curiously Nikon branded versions of these lenses are called "Micro"), that are also telephoto lenses. Your lens is not a macro/micro type.
Lastly - operational equipment. It is possible that there is an issue with the D5000 camera body or lens (or even both). Try another lens to see it it works as expected. No other lens? Go to camera store with your camera and lens and "shop" for a new lens. Ask to try it out in the store and see if it it works. Maybe the counterperson will identify another issue with your set up.
I hope this helps & good luck!
Oct 05, 2014 | Nikon D5000 Digital Camera
My AF 28-105mm f/3.5-4.5D IF lens does not achieve infinity focus anymorw and wanna repair. How is that done?
You can't do it yourself. You will only do additional damage and add to the cost of repair. You need special training and expensive specialized equipment to repair and align a lens. I suggest that you go on the Nikon USA website and find the closest Nikon Repair Depot. They will give you a repair estimate.
Feb 21, 2012 | Nikon 28-105mm F3.5-4.5 D-AF Lens
I have a nikon d3000 whith an 18-200mm tamron lens now here is the problem sometimes when its all ready to make pic focus everything works i halfpress the button and it wont lock or let me make a pic...
This problems sounds like you are trying to take pictures too close to your snakes. These lenses do have a limitation and usually you need to stand at least about 6 feet away from your subjects. If you are using a Macro lens then you can be closer; but the lens must be set to macro or have this feature. If you think you maybe having some type of focusing issue then I suggest you contact Photo Tech at www.phototech.com because they are the authorized Nikon service facility.
Good Luck
Paul
Jun 30, 2011 | Nikon D3000 10.2 Megapixels SLR Digital...
Which size of adapter to use to fit it to Nikon D300?
Nikon bodies are thicker than Olympus bodies, thus while Nikon lenses can be made to focus to infinity when mounted onto an Olympus body, an Olympus lens will not focus to infinity were it mounted onto a Nikon body. Thus, no one makes an adapter to fit an Olympus lens onto a Nikon body.
Jul 01, 2010 | Olympus Normal Zuiko 50mm f/1.2 Manual...
Nikon D50 with Nikon DX 18-55 lens will not focus
Sorry to hear about your lens. If you are able to autofocus and take pictures with any other lens, then it means that your problem lies with the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning. I had the same thing happen to my 50mm 1.4 lens.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
Apr 16, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
AF-S DX VR Zoom NIkkor 55-200mm f/4-5.6G is not focusing
Your motor may have gone bad. Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Mar 29, 2010 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
Dear expert have following problem, by puting focus distance to infinity the sharpness of far object is very bad, camera can not catch the focus. Before it wasn't
Check to make sure the lens is attached properly. Remove the lens by rotating it clockwise. Reattach the lens by aligning up the mounting indexes (white dots) and turning counter-clockwise until you hear a click.
Also, try increasing your aperture value to more than f/22
Dec 13, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Lens for Nikon D60
I will try to help you, but please understand that my experience is with Nikon film cameras. Assuming that the D60 works in a manner similar to a Nikon 35 mm body and that Sigma macro lens work like Nikon macro lens, you should be able to determine the usable subject to lens distance by experimentation. First, make sure the lens is in the macro mode. To do this you must set the auto-focus mode control to the manual focus mode (see your manual). On Nikon lenses, you must first set the focus ring to infinity, then move slider switch, which has two positions marked; "normal" and "macro., to the macro position. You should now be able to rotate the focus ring to the macro range. Use the zoom ring to zoom in and out and focus with the focus ring. The the range over which the lens to subject to lens distance will yield an in focus image will be rather limited and in the range of an inch or so to 6 or 8 inches.
Dec 09, 2008 | Cameras
Nikon D80 Autofocus problem
sir, replace ur lens image reading sensor
Apr 06, 2008 | Nikon D50 Digital Camera
Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX Zoom Nikkor Lens Logo
643 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
