Question about Panasonic CQ-C1300U CD Player
My memory wont work after 5 minutes or truck shut off but will after a minute or less
Hey i am having problems with my 2004 panasonic deck. for some reason my memory is not working. me and my friend think it is something in side of the deck but are not sure. i was wondering if you could help me out. every time we shang something (ie: bass to +6) after we turn the truck off and wait 5 min it is erased. but when we turn the truck off for no more then a minute it is fine every thing stays the same. we are sure all of the wires are connected correctly as we have screwed around with it many times so far. please let me know whats wrong and if i need a new deck or if its something that can be fix cheaply :)
    Scholar:
  • 82 Answers
Are you positive that the yellow (memory wire) from the Panasonic (use a test lamp or meter) is continuing to get power after you turn off the truck and wait 5 minutes? And the Black ground is proper ... If so then it will likely cost more to repair the deck than replace it. Or you could wire the red wire to the same place the yellow wire is wired to ... then just remember to shut it off when you leave the car (or suffer a dead battery 12 hours later) ... and it won't cost more that the cost of a couple crimp connectors to do that ... the frugal way.
Posted on May 13, 2009
2004 pontiac bonneville ran for about 5 minutes then shut off. i scanned the computer and it showed a p0230 code.fuel pump primary circuit misfunction.now it wont start at all.battery alittle weak.
check that the pins in the relay socket and the PCM connector are good and make contact youshouldsee12v at pcm... PCM is last resort. Check the fuel relay first for melting or burnt smell.
Mar 09, 2016 | 2004 Pontiac Bonneville
1999 Pontiac grand prix gtp delco radio light wont stay on
Check the dimming wire thats usually it , I always leave them disconnected
Feb 25, 2014 | Pontiac Grand Prix Cars & Trucks
Wiring JVC car deck
Do you have factory infinity sound. If you do you need a another harness or bypass that infinity system. Also What year is the truck. I know for a dodge ram after 02 is a canbus system. When wiring in the harness leave the blue remote wire alone do not connect from radio harness to the harness that connects to factory harness. Unless you are running to an aftermarket amp. There is a brown wire also that you should not connect leave the remote blue and brown wires alone. this is atleast on a 02 dodge 1500 or newer and 03 or newer 2500+. not sure if this will solve your issue but it fixed my buddies.
Apr 29, 2013 | Dodge Cars & Trucks
2004 polaris sportsman 700, shuts off while riding.
I have a 2004 700 carb that shut off while riding and then would start up 3-5 minutes later after many nights working on it Ifinally figured it out no help from any dealer. There are 2 circuit breakers under the front rack mine were very rusted, Replaced both never had the problem again. My situation was always only when the lights were on.
Hope this helps
Aug 07, 2009 | Polaris ATV
Panasonic projector keeps shutting off
http://www.youtube.com/watch?v=6jGwB05_gdk
5 minute fix guaranteed
worked for me
Apr 05, 2009 | Panasonic PT-AX100U-EC DLP Projector
Sony TC-WE475 problem when taping A to B, B is not recording. Heads turn but no sound.
Hey there,
Next time you have a few minutes, open the B side of the tape deck and look at the actual tape head- if it is dirty, you can clean it using cotton swabs and 80% isopropyl alcohol. (Higher than 80% is actually better, because it has less water in it)
Let me know if this helps your problem,
HortonA!
Mar 22, 2009 | Sony Audio Players & Recorders
It shuts off all by its self but not all the time
If I was working on this set I would look for cold solder joints on IC501 Vertical output IC.
Sep 03, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Axim wont automatically shut off
I would guess your light should dim after 5 minutes. But I bet your axim wont shut off for 2,3, or 4 hours. My battery is wonderful so I have it shutting off after 2 hours.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Panasonic CQ-C1300U CD Player Logo
114 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
