Question about Apple iPhone Smartphone
Slider on my iphone 2g wont work
Some times the slider works. Also some times my apps wont work when i click on them.
    President:
  • Apple Master
  • 688 Answers
Your LCD assembly is going bad.
or has gone bad.
Is your phone unlocked?
if so some unlockers will also cause this malfunction.
But most likely the digitizer in the lcd assembly is bad.
if it is a 3G you can replace the outer glass and digitizer for around 40.00 for the part and 35.00 labor.
good luck
Posted on May 13, 2009
I just jailbroke my iphone and now the slider wont slide to get into my apps. I got a app resprung and now i cant slide my slider
Is there a small spinning wheel?
Did you do a tethered jail break? Or an untethered? If you had to have it plugged into your computer, the problem is you need to boot it while plugged in. Depending on which program you used, there is a just boot option in it somewhere. Plug your phone in, choose just boot, and follow the on screen instructions. (it's usually in the "extras" options in most programs)
Mar 15, 2012 | Apple iPhone 4 Black Smartphone
I reseted my i phone 3gs to factory setting, now it wont come on. when i try to restore it through itunes, an error (1013) is popping up.
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Dec 14, 2010 | Apple iPhone Smartphone
My i phone wont turn on i try to restarted now it wont turn on i try to hold the home button and the power button a pineapple apears and it just stays like thet
This may not fix it if you "jail broke"it:::
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Nov 30, 2010 | Apple iPhone Smartphone
My phone is locked up and wont turn off. how do i turn it off to reset?
If something isn't working right, restarting, force quitting an application, or resetting
iPhone will likely solve the problem.
Restart iPhone: Press and hold the Sleep/Wake button until the red slider appears.
Slide your finger across the slider to turn off iPhone. To turn iPhone back on, press and
hold the Sleep/Wake until the Apple logo appears.
If you can't turn off iPhone or if the problem continues, you may need to reset. A reset
should be done only if turning iPhone off and on doesn't resolve the problem.
Force quit an application: Press and hold the Sleep/Wake button on top of iPhone
for a few seconds until a red slider appears, and then press and hold the Home button
until the application quits.
Reset iPhone: Press and hold the Sleep/Wake button and the Home button at the
same time for at least ten seconds, until the Apple logo appears.
Oct 05, 2010 | Apple iPhone 3G
Hi, my iphone 3gs has frozen on me. I can't get the slider to work to open the phone to see the apps. What can i do to fix this? regards phil
Press and hold both the POWER and the HOME buttons together until your iPhone restarts (around 5 to 10 seconds) or until you see the Apple logo..
For more iPhone / iPod touch tips like jailbreaking and unlocking, click here.
Aug 11, 2010 | Apple iPhone 3G
Iphone 3gs wont work. white flashlight screen?? please help
If iPhone doesn't appear in iTunes or you can't sync iPhone
  1. The iPhone battery might need to be recharged. For information about charging iPhone, see "Charging the Battery" in the iPhone User's Guide.
  2. If that doesn't work, disconnect other USB devices from your computer and connect iPhone to a different USB 2.0 port on your computer (not on your keyboard).
  3. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
    Note: If you enter the SIM PIN incorrectly three times, you may need to contact your carrier for a Personal Unlocking Key (PUK) to enable your SIM card again.
  4. If that doesn't work, restart your computer and reconnect iPhone to your computer.
  5. If that doesn't work, download and install (or reinstall) the latest version of iTunes.
If you can't make or receive calls, send or receive text messages, or access email or the web
  1. Check the cell signal indicator in the status bar at the top of the screen. If there are no bars, or if it says "No service," try moving to a different location. If you're indoors, try going outdoors or moving closer to a window.
  2. Check to make sure you’re in an area with network coverage. Go to your carrier's website to see network coverage areas.
  3. Make sure airplane mode isn't on. From the Home screen choose Settings, then turn Airplane Mode off.
  4. If that doesn't work, turn airplane mode on, wait 15 seconds, then turn airplane mode off again.
  5. Make sure to include an area code for every phone number in your contacts list that you use to send or receive text messages.
  6. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  7. If that doesn't work, there may be an issue with your wireless service. Call your carrier or go to your carrier's website.
  8. If that doesn't work, restore the iPhone software. See Backing up, updating, and restoring your iPhone and iPod touch software or see "Updating and Restoring iPhone Software" in the iPhone User's Guide.
MMS: Original iPhone does not support MMS. MMS is available on iPhone 3G and iPhone 3GS if it is supported by the wireless carrier. For more information, please see iPhone: System requirements for MMS.
If iPhone won't turn on, or the display freezes or doesn't respond See iPhone and iPod touch: Frozen and unresponsive for information on addressing these symptoms.
  1. iPhone OS 2.x and earlier: Press and hold the Home button until the application quits.
    iPhone OS 3.x and later: Press and hold the Sleep/Wake button until the red slider appears, then press and hold the Home button until the application quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
If iPhone continues to freeze or not respond after you reset it
  1. Reset iPhone settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but no data or media is deleted.
  2. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears restore the iPhone software. See Backing up, updating and restoring your iPhone and iPod touch software.
Jun 28, 2010 | Apple iPhone Smartphone
Frozen jailbroken iphone 3g
I'll recommend you re-break your phone and if you are willing to perform the task in a more simple yet time-saving manner, follow the step by step guide from this website: iphoneunlockeasily.com
Jul 24, 2009 | Apple iPhone 3G
Touch screen inoperative, buttons work
Hello
I have the same problems on my iTouch as well, here is what i do:
  • Restart the app
  • Reinstall it
  • Search for a newer version
Make sure u have the latest ipod touch firmware ;)
Feb 12, 2009 | Apple iPhone Smartphone
Problem with bottom half of screen
have to tried to update it to the current firmware
Dec 13, 2008 | Apple iPhone Smartphone
Iphone screen wont turn on
Nov 19, 2008 | Apple iPhone 3G
Apple iPhone Smartphone Logo
103 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
