Question about Canon Office Equipment & Supplies
E711 code I have a Canon NP6025 with a E711 code
  • 40 Answers
...error code E711...mainboard malfunction...error in the mainboard...and see also the power supply mainboard...and check if the output voltage that came out from is working fine...to do this you must have a multitester to check the voltage...
Posted on Jul 10, 2009
Does the Canon NP6025 contain a hard drive? If so where would I find it? Thank you.
i dont think so .analog with a hard drive . try to check the ip board at the back of the machine
May 25, 2011 | Canon NP 6551 Black and White Copier
Tip
ERROR codes Canon 6150
Canon 6150 E000 Thermistor E001 SSR E002 Thermistor, ht. Lamp thermal fuse or SSR E003 Thermistor, ht. Lamp thermal fuse or SSR E005 Fuser cleaning belt E010 Main drive problem E020 Toner motor, toner level sensor, toner hopper sensor E030 Counter E050 Duplex problem E203 Scan home problem E210 Lens home sensor E401 Document feeder paper pickup motor E402 Document feeder belt clock pulse problem E403 Document feeder main motor clock pulse problem E411 Document feeder sensor problem E500 Sorter/copier interface problem E510 Sorter motor drive E530 Sorter home sensor E531 Stapler swing sensor E540 Sorter lead cam home sensor E541 Sorter lead cam home sensor E710 DC controller board E711 DC controller board E712 Document feeder problem
on Jan 19, 2010 | Office Equipment & Supplies
Getting e711 error message, requires restart and still gets same error
There is a communication error between the machine and one of the accessories.
Turn the copier off, disconnect all accessories (sorter, feeder) and try again.
You may want to reconnect them one at a time to see which one is bad.
Nov 12, 2009 | Canon NP 6230 Copier
Canon np6025 error code e004
This is a fuser problem. It will need to be replace or rebiult depending on what is wrong with it. It could be the fuser heat lamp, or thermistor.
Oct 29, 2009 | Canon NP 6551 Black and White Copier
What does error message E711 mean on a Canon Copier NP6230?
E711 on the NP6230 points to a DC controller fault. Unless you can get the part literally free, it's not worth replacing - something else could be damaged along with the DC controller and you will not know until you've replaced it. Walk away
May 28, 2009 | Canon NP 6230 Copier
System error E000 how do I fix it. I tried what it said in the instructions to turn it off for a while then turn it back on that didn't help. Canon NP6025 copy machine.
To delay the 3 second shut down and enable the technician to access service mode; open the front door and pull out the transport unit. Do not actuate front door microswitch. Press the service mode button, enter " * 4 * ", scroll to error clear and clear error code. Machine will automatically turn off power after clear. Power up machine and test.
If the power shuts down after error code has been cleared, the cause of the error has not been corrected. Correct cause of error code and clear error in service mode.
May 07, 2009 | Canon Office Equipment & Supplies
Error message on canon np6025
LOL.... I just kept wiggling wires and connectors and all of the sudden it worked.... not real sure what I did .
Apr 09, 2009 | Canon Office Equipment & Supplies
Canon NP6025 Service/Repair Help
yes I can go there for to see , but I need to now whats this machine have
Dec 12, 2008 | Canon NP 6551 Black and White Copier
Cannon NP6035
check here for the code: just look for the code, doesn't matter what machine type, they use the same code for different types of models
http://www.copier-help.com/copier-help/ecs/canon/eccgp200.html
Jul 23, 2008 | Canon NP 6035 Copier
204 people viewed this question
old marine
old marine
