Question about Panasonic DVDS97S DVD Player
Won't power up. Disk stuck inside. Can i open that tray to rescue my rental?
DVD player is dead. won't power up. Rental disk stuck inside. Any simple way to get that tray open?
  • 3 Answers
Take a small flat head and pry the door open if not the only other way is to unscrew cover and manually push tray open
Posted on May 13, 2009
How to remove stuck dvd from lg blu ray
sounds like the disk may be sticky on top and is now stuck to the chucking clamp. Try to cut power as the door tries to open, then open the door as much as it will aloow and you should be able to fish the disk out. If it is stuck, you may have to push down the disk with a screwdriver to release it.
Jul 28, 2014 | LG Televison & Video
Marantz DV4001 DVD player suddenly won't power up. Rental DVD stuck in player. Besides the lack of power issue - is there way to open the DVD player manually?
YES, UNPLUG, REMOVE SCREWS @ BACK & SIDES, CHANGE FUSE ON POWER BOARD,OR YOU CAN TRY & RELEASE THE TRAY BY WINDING THE COGS BACKWARDS. CHECK YOUR PLUG FUSE FIRST.
Oct 10, 2013 | Audio Players & Recorders
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
I have a GPX D200B DVD Player and cant get the Disk Tray to open.
unplugged the dvd player and then re plugged, power on then press the eject button. if still the loading tray won't open, at this time you will need to remove the cover of the player to access the loading tray mechanical assembly. then check for an stuck up or broken rail plastic loading assembly it was installed drive by the loading motor.if ok, check the limit switch might not get contact which the processor not turn on the supply for the motor.
Nov 15, 2012 | Televison & Video
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Aug 23, 2011 | ESA E4000 DVD Player/VCR
My Samsung BD-P1600 will play a SD disc but the rental Bluray discs won't play. Is there any way to reset the player? THX.
It is not the player you need to reset, it is the rental DVD's. They are encrypted with a code to limit the amount of time they can be watched, thereby protecting them from being stolen or not returned. Send them back to the rental company and rent the same movies again. That is your only solution. Your player will play whatever is put into it. I hope this helps.
May 22, 2011 | Samsung BD-P1600 Blu-ray Disc Player
JVC Dvd video recorder & video cassette recorder (DR-MV1S) Why do I get "disk erroe" on some rental disks? How do I fix this problem?
are these discs very scratched up??
they usually are from the rental places
you cant fix anything if you are getting scratched discs
you might be able to open your player and very carefully clean the 'eye' of the player with a qtip and rubbing alcohol this might help so the laser has more strength
but it is more than likely the quality of the rentals you are getting
good luck - hope this helps a bit
Mar 28, 2011 | Televison & Video
Whenever I load a rental dvd, I get "Disk Error",
This unit has had problems playing dual layered dvds and since most newer are Dl try a older rental Movie and see if that works
Mar 28, 2011 | JVC DR-MV1S DVD Recorder/VCR
Panasonic DVDS97S DVD Player Logo
651 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
