Question about Kenmore 53542 / 53544 Side by Side Refrigerator
Model 53544300 power module on compressor sparking and smoking. Can this be changed out and how? Or does the whole compressor need to be replaced?
  • 286 Answers
If your compressor is grounded then you need the compressor. You can try to replace the overload and relay first.
Posted on May 13, 2009
Ford Escape 3.0 no power to #4 coil
Need to change the coil. Is likely the problem. Sometimes that means replacing the whole coil pack.
Apr 10, 2014 | 2005 Ford Escape
2002 Isuzu Axiom ,3.5 V-6, 2wd....A/C quit working, making noises,glowing red,smoking on front of compressor. How hard to replace A/C clutch bearing(20$) instead of whole compressor(400$) ????
you need tools to replace the clutch some auto parts stores rent them and if it got that hot the front seal of the compressor could have been weak try pricing a used one
Aug 17, 2012 | 2002 Isuzu Axiom
We just replace the radiator, fan, belts, water pump and pulley in my ford f250. It runs fine w/o a/c. When I turn the a/c on it makes alot of noise and smoke comes out of the compressor unit under the...
The smoke is probably coming from the Serpentine belt. Flip the belt and see if it is now starting to be SHINY. The belt is going faster than the Compressor has the ability to turn. More than likely, the Compressor is partially seized and needs to be replaced.
May 26, 2011 | Ford F-250 Cars & Trucks
I saw a cloud of smoke come out of the back an now no picture but I do have sound.Its model TDA03211C 32 " dvd combo.
The smoke may have come from the main power supply. You can buy the whole module from Polaroid which includes, the power supply and the signal board all in one piece. I am not sure if this model has the inverters on the side or embedded with the panel. It may also be the inverter.
Best of luck.
Nour Sabre
Nov 03, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
The module on the side of the compressor is smoking
You need a new relay. You can purchase an entire kit which would be your best and easiest replacement. It is part number URCO410. The instructions will come in the kit. Its fairly inexpensive and will get you up and running for a few more years unless your compressor was damaged. Just read the instructions carefully and make sure your wiring is right because if you wire it wrong you will burn up your compressor windings.
Hope this helps _MJ_
Feb 07, 2010 | Refrigerators
Smoke from compressor
That is your start relay. Some of the Whirlpools and Maytags use a relay that can burn up like you mentioned. Buy a new start relay and replace that old one.
Sep 08, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
A/C smelled like smoke then blew 30A fuse - Silverado 1500 2004
You may want to change the blower motor as a precaution.
Do all the fan speeds work?
If not .....change the fan resistor board which is right beside the fan at the same time you change the blower fan motor.
Aug 26, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
Sparks shooting from my 1994 f150 air compressor
the ac compressor is seized up, replace it./
Jul 14, 2009 | 2004 Ford F150
Need to remove the on/off switch to change pressure diaphragm.
it's a module...cannot be replaced without replacing the whole box...contact Lowe's or is it Home Depot's tool dept and order a new one.
$60?
Jun 15, 2009 | Stanley Bostitch CWC200ST 3HP Oil Lube...
Smoke around belt
the smoke is coming from the belt because a part has stopped turning ...you need to check which one it is... it could be the water pump...alternator ..a/c compressor...... power steering pump or the belt tensioner.... and your going to need a new belt
Dec 10, 2008 | 1999 Chevrolet Suburban
Kenmore 53542 / 53544 Side by Side Refrigerator Logo
85 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
