Question about Whirlpool Duet GHW9150P Front Load Washer
Rattling sound during spinning - Whirlpool Duet GHW9150P Front Load Washer
  • abeg24 May 13, 2009
    dougstanko
    I thank you for your technical advice. I'll definitely follow it - per your advised.
    Thanks,
    Abe
  • 6 Answers
There is probably a spring that has come loose.
It is tricky... and you need some room to do this.
The white part of the washer is just a fancy cover. If you take it off and set it aside you will probably find your spring and you will figure out where it goes.
I will tell you the springs are very important. They hold the drum so that while it is spinning it stays centered and does not rub the sides. I learned this the hard way. I let my rattling go for a long time. Probably a year. The drum rubbed a hole thru the plastic liner and when my washer got to the spin cycle the centrifuge effect to get the water out of the clothes... got the water to go out the hole on to my floor. The drum was 200 dollars and was a big pain to replace. Not worth the time at all.
So I would not let it go to long if I were you. Wait for a couple days off in a row... or call a tech. The springs are cheap and easy to fix. it might not even be broke. They have a coiled end like a key chain. I might have loosened and fallen off.
Hope this was helpful.
Doug
Posted on May 13, 2009
    Scholar:
  • 84 Answers
Is it pretty new?
new washers have some sort of metalbar...thatkeeps the drum from spining.....
and has to be removed before operating..first time...
2 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Rattling noise during high speed spin
sounds as if you might have a bad rear bearing, real obnoxious almost painful to listen too kinda sounds. big job, but might have some part warrentee depending on age of unit
Posted on Oct 21, 2008
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
Haier hlp23e washer makes a rattling sound during spin that almost sounds like coins being slapped by an impeller. How do I fix?
Here's what I did that seemed to fix it. You know that plastic attachment you screwed onto the bottom? I'm pretty sure the noise is made by the bottom of the machine spinning against it. I thought the noise sounded sort of plastic-y, so I removed the bottom and sure enough, there were circular scratch marks on it. I haven't heard that annoying rattling yet.
May 05, 2012 | Haier HLP23E Top Load Washer
Rattling sound and vibration while spinning
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. The other possibility can be faulty motor causing the bearing to rattle/. Check out both the motor as well as spin bearing. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Samsung SW62ASP Top Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Water leaking and loud noise and rattling on final spin cycle
Turn the drum by hand and if you hear any noises it is the rear bearing. If there is no noise then remove the front bottom panel and take out the coin trap on the pump and check those hoses.
Eric
Aug 27, 2009 | Whirlpool GHW9150 Front Load Washer
Loud Clicking rattle during spin
you may have something stuck in the pump
pull hoses off pump and see if there is anything stuck in it
Jun 13, 2009 | Admiral AW22 Top Load Washer
Squeaking/grinding/rattle noise during wash and spin
That sounds like a clutch problem - probably just worn and need replacement. Will definitely need to pull to find exact fault.
Regards
Nov 16, 2008 | Washing Machines
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Oct 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Thumping/knocking/rattles during wash agitation cycle
Mine is doing the same thing. I opened it up to see what was happening and it was the drive belt tension arm bumping around. Soon, the belt started slipping during the spin cycle. Now it won't spin and the belt starts to smolder from the friction of the drive motor. If you haven't checked your belt, that's a good place to start.
Jun 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
176 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
