Question about Whirlpool LSR6332K Top Load Washer
Cleaning the drum of the Whirlpool 3 LSR 6233 EQO (get it out)
How do i get the drum out ?
  • 2 more comments
  • deklerkclan May 13, 2009
    thank you so far,but how do i get the agitetor out,?do i need i special tool for this?
    all out ,just the spanner nut?cant get it loose,do i need special tool for that?
  • deklerkclan May 14, 2009
    i CANNOT LOOSEN THE SPANNER NUT
  • deklerkclan May 15, 2009
    Thankyou very much
    President:
  • 3,113 Answers
Remove two screws that hold the control panel,pull forward and lift ,tilt back. Unplug door switch and remove the gold clips that hold the back to the top of washer cabinet. Lean cabinet towards front and remove. Unsnap tub ring at top from outer tub. Remove fabric softener dispenser cup at top of agitator. Remove snapped in plastic cover and seal underneath. Remove bolt under the cover. Remove agitator. Remove spanner nut that holds drum in and remove drum.
Posted on May 13, 2009
  • honeymokey
    honeymokey May 15, 2009
    Yes you will need a spanner wrench. Try your local appliance parts company.
Whirlpool heavy duty super capacity plus LSR 7233 EZO
Most likely, the legs on the machine aren't level, causing it to move during operation.
Jun 12, 2012 | Frigidaire Washing Machines
MSI 875P Neo-LSR (MS-6758) sound drivers
Download here at msi:
http://www.msi.com/product/mb/875P-Neo-LSR--FIS2R.html#/?div=Driver&os=All
Select first your windows 32 or 64 bit.
Download your files and unzip before you install.
Good luck
Sep 19, 2011 | MSI 875P Neo-LSR (MS-6758-010) Motherboard
Spins on one cycle, but not the other
sounds like timer is loosing contacts and time to replace.
Jul 21, 2010 | Whirlpool LSR7333 Top Load Washer
Have a whirlpool model.# LSR 8444LQ0 Balance problem anyone know what maybe the cause and a fix it for it?
Check your machine standing level. Adjust it with it's adjustable screw legs.
Check the set of springs or hydraulic shock obsorbers ( depending on mododels) that supends the water drum assembley set.
Check drive belt tension. during high speed spin might slip intermittently.
Finally your loading material!
Apr 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My top load washer's drum came loose during the
probably a simple drive coupling replacement job. Check out these repair pix with manual:
DIRECT DRIVE REPAIR
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 23, 2009 | Washing Machines
Cleaning the outside of washer Drum
hi there,
this is quite common for all front loading washers. the best way to clean is to use either Affresh or Washerfresh tables. you can purchase them at any appliance parts supplier.
Oct 11, 2008 | Whirlpool Washing Machines
Rust in tub
Unfortunatly, this happens every now and agian. Sometimes a button or something will pop a piece out of the porcelain, then you have rust. The problem is, the companies will tell you (which you have probably heard a hundred times already) that if its out of warranty, its not their problem. Other than that. Unfortunatly, out of the few we have delt with, most of our customers either try to find a lawyer or replace the drum. Havent heard anyone being successful in getting satisfaction from a lawyer. Sorry, believe you me I know how you feel. The old saying "They Dont Build Them Like They Used To" really does work now-a-days. Good Luck to you. Jim
Sep 07, 2007 | Whirlpool LSR7333 Top Load Washer
Whirlpool LSR6332K Top Load Washer Logo
495 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
