Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Tromm washing machine, front load from LG
I have a message error OE meaning ''drain error'' , impossible to open the door. I have tried to put the breaker off to see if it would reset the machine but this did not work. can you help ? my hotmail address is sevy99@hotmail.comLG tromm 2004 OE error won't finish cycle Normal won't start the speed cycle
help
    Sergeant:
    Champion:
  • 219 Answers
Hi, Well i am giving u the link  http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
page 18 and 20 will help u to diagnose the problem.It has diagrams so u will better understand it thats why i m not writing the solution here..
Thanks! Sandy
Posted on May 13, 2009
My LG washing machine is showing OE fault what do it mean ?
OE means uneven load.
If you can open door, put a dry towel in with the washing and try spinning again ...
Nov 20, 2017 | LG Washing Machines
What is an "OE" error message on an LG Tromm clothes washer?
OE means Water may not drain properly
This causes:
Your pump is clogged.
Your pump is not connected.
Make sure your pump is repaired, and try again.
Jul 28, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a problem with my LG Tromm front load washer. It will wash seemingly normally up to the point it gets to the spin cycle. Then a motor comes on and the machine does not spin or drain. The display...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Sep 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
What does oe mean on the front loader lg tromm and how do I fix it?
Not sure what the OE is, but I;ve been having the same letters flashing on my washer this week. I checked the filter at the bottom and it was totally plugged up ! I would check your filter.
Jun 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washer isn't drying anything very well. getting a oe message lg tromm wm2277hm
the OE message means that the machine has not fully drained out all the water. you can try to re set on drain or you may need a service call. hope this helps.
Oct 15, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm WM2277HW OE error message
unit not drainning..in the but front left hand corner ,,there a panel,,open panel and clean your filter...onthejob...
Jan 25, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My front load Tromm LG washer flashes OE message, won't drain or finish wash. Door does open
oe is an error code for pump problem disconnect power cord open small door on lower front of cabinet pull little tube out and plug from tube and drain water in to bucket after water is drained unscrew cap of pump to clear out any obstructions reinstall the cap and plug and give a test run
Dec 20, 2008 | LG WM-2277HW Front Load Washer
Peace,
ngafm at your service!
Lets try this first!
Did you try to open the door when the breaker was off or only when you turned it back on??
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Sep 03, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
170 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
