Question about Canon FAX-L1000 Plain Paper Laser
SENDING FAX COMING BACK BLANK PAGES .NOT PRINTING ATALL.
  • 28 Answers
If you attempt to print any kind of report from your unit and the pages are still blank there are two posibilities.
#1 The toner cartridge tape was never pulled out correctly/ the toner cartridge might be defective.
#2 A more serious cause fo the same symtom might be a defective hi voltage section in the unit. On a newer product this is not very likely
Posted on Jul 11, 2009
Printing blank pages when receiving fax
Ask if the ones sending are sending legal size, it may be using 2 sheets to get all from a legal size document.
Jul 29, 2009 | Brother MFC-8460N All-In-One Printer
Cannon S200Spx prints blank pages
The problem is likely to come from your printer settings in your printer properties dialog box. Right-click the printer icon and select Properties. You will see within the dialog where to set the printer to print on black only and then appropriate. restart your pc and then try sending to printer again. Good luck
Jun 03, 2009 | Canon S200X Ink-Jet InkJet Printer
It has plenty of ink and the drum is good but it stopped printing
All blank pages could either mean: On the scanner side: * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the scanner side by printing a test page on the printer. If it prints fine, the problem is in the scanning process.
On the printer side: * Dirty connectors between toner/drum unit and machine. Remove the toner/drum package and clean the metallic cylinders on the left and right side of the toner/drum unit, then reinsert package into machine. * Bad toner and/or drum unit. Replace should solve it. * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the printer side by either scanning to a connected PC or sending a fax to someone. If the scanned/faxed page looks fine on the pc/fax that receives the fax, the problem is in the printing process.
Jun 02, 2009 | Brother MFC 9700 All-In-One Laser Printer
Fax 2820 will not print. pages are blank
what do you mean printing stage?for the blank pages,it may only require cleaning.check the toner save setting,make sure it is off.clean the scanner glass of the machine,or you may just need to replace the drum
Nov 15, 2008 | Brother IntelliFax-2820 Laser Fax
Blank pages
remove the cartridge and using a damp cloth wipe the ink openings...this might fix the issue.
Oct 01, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Will not make a copy
If it won't copy, it is unlikely to handle faxes either since those functions use the same scanner. If your received faxes are coming out blank, then it is a problem with the ink system; if you can get faxes printed but not copy a document, the scanner may be at fault.
Have someone send you a fax to check this function (printing) and then try sending one back to check the scanner.
If either one fails, then hyou know where the problem lays.
Jul 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Faxing problems
if you put the document in right direction(face up or face down)-your scanner unit may be out of order or unpluged firmly into the main board socket check it and reinsert scanner unit plug again.
Jan 10, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
Canon FAX-L1000 Plain Paper Laser Logo
149 people viewed this question
old marine
old marine
