Question about Brother MFC 420CN All-In-One InkJet Printer
My Brother MFC 465N keeps turning offline. I can print to it from two other laptops. However, the PC that hooked to the writer where the printer is connected keeps saying it is offline. I reinstalled the printer, the online came on. Then I used the printer to fax something, and then the PC says the printer is offline. How do I turn it to online whithout reinstalling it again.
  • 1 more comment
  • rabah_97 May 13, 2009
    It is plugged via a network cable to a router. My main PC connected to the router says it is offline. However, I can print from it from two other laptops, wirelessly.
    Thanks,
  • rabah_97 May 21, 2009
    I figured the problem. All I had to do was disable my Norton Firewall and the enable it and I could print to it from the PC.
    Thanks,
  • Chris
    Chris May 11, 2010
    Are you plugged into the printer by USB cable, if so are the other laptops networked through a share on your PC or via a network cable connecting the printer to the laptop?
    Chris
Mfc 465 brother unable to print
Posted on May 20, 2009
I cant print any documents my brother MFC-255CW says offline and i cant get it to work
I had the same problem, and couldn't find a solution anywhere. My laptop said the wifi Brother MFC-255CW printer was offline, when the printer was definitely online and connected.
In the end I simply went into Control Panel / Printers, selected the Brother printer, and deleted it off the network. Then I chose "Add a Printer" from the network, and reselected the only printer on my home network - which was the Brother MFC-255CW that I had just deleted. The computer reinstalled the driver, and everything was fine again - haven't had a problem since.
Nov 08, 2010 | Brother MFC 240C All-In-One InkJet Printer
Offline wireless printer
Please make sure that printer is turn on, before doing ensure you do power cycle of printer.
Add printer on Standard TCP/IP port.
Sep 13, 2009 | Brother MFC 490cw Color Inkjet...
Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
Apr 07, 2009 | Brother MFC 490cw Color Inkjet...
MFC 465N - Cannot load the MFC Suite
if you follow the directions closely you should be able to install the mfc suites w/paper port brother tech
Dec 02, 2008 | Brother MFC-465CN InkJet Printer
Brother mfc is offline -
For my MFC, my PC says its ready and working properly. It really only works when I'm not connected to my cable modem. All PCs use it then. It's offline otherwise.
Sep 05, 2008 | Brother MFC-8860DN Printer
Hi i have two computers,an old desk top that prints to my brother printer mfc-465n through a cable no problem,and a new laptop that prints through wifi,but every time i try to print through thr laptop,the...
ok...it may be that your brother is not happy with getting two signals, ja? maybe it's a one or the other issue. try it with only wifi connected and report back, nein?
http://tinyurl.com/6qcpgy
Aug 18, 2008 | Office Equipment & Supplies
My MFC-440CN
Yes, an empty ink cartridge will prevent the printer from functioning.
Not all printers will do this, but the Brother MFC series will not print if any one of the cartridges are empty. Replace the cartridge and all should be fine.
Mar 07, 2008 | Brother MultiFunction Center MFC-440CN...
My printer is "offline"
Try disabling the firewall, printing, re-enabling the firewall. My printer keeps working after re-enabling the firewall (at least for a while). Not ideal, but beats reinstalling the printer.
Mar 01, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MFC 420CN All-In-One InkJet Printer Logo
4,222 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
