Question about Maytag Appliances Magic Chef 18 cu. ft. Top Mount Refrigerator
Frezer not freezin fridge not cooling
Model # cvtl151gew
fridge stopped workin when on here clicking noise fan runs but compressor is hot
  • 159 Answers
Try to change the clickson and relay on the compressor and if it still doing that there are two problems to look for or a blokage in the system or the compressor are broken
Posted on May 16, 2009
My GE Profile Refrigerator (model PDS20MBSBB) is making a clicking noise. The thermostat display turns off while this happens. When it comes back on the fridge gets really cold and then slowly gets
needs new control board wr55x10942. condensing fan not running or running slow. it get to hot then the compressor relay cut off compressor to protect it once cooled down enough it starts back running.
Oct 09, 2014 | GE Refrigerators
I recently brought this fridge out of storage, it was working perfectly fine before i put it into storage. I plugged it in and the lights are on, i let it run for a few hours but it did not get cold or...
The cooling fans do not run unless the right temperature is reached. The important thing is to find if the compressor is running. If you do not hear a whirring sound when the fridge is powered on, then the compressor has a problem. Generally when you put in storage the refrigent can leak out and needs to be refilled.
If the compressor is running then check the thermostat settings. Might also help if you provide the make and model number of your fridge.
Oct 10, 2011 | Refrigerators
Fridge not cooling, freezer not cold enough, ice maker not workin
is there alot of frost in the rear panel of the freezer if not the compressor is not start or getting hot because fan that cools it has failed is the part between the side/side door extremely hot if so check the cooling fan for the compressor
Aug 19, 2009 | Maytag MZD2766GES Side by Side...
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
FRIDGE THAWING
pull your refrig away from the wall and check to see if your compressor is running i'm willing to bet that the start relay is bad you will here a humming and then clicking noise approx every 3-5  mins. its a very easy repair get part number 8201786 from whirlpool it has detailed instructions and should only cost you 40-60 dollars for part.
Jan 22, 2009 | Whirlpool Refrigerators
Kenmore frig will not cool
if compressor is hot that means comp- is trying to start but the relay /overload is bad allow comp to cool down unplug from wall and replace with exact type 1/2hp 1/4hp 1/3hp etc make sure all wireing is correct and unplug before starting that model may or may not have a run or start capacitor replace it also..
Dec 31, 2007 | Refrigerators
Maytag fridge made some clicking noises and then stopped cooling
For what it is worth. I had this problem twice and both times the compressor ad to be replaced. Ton this day it sounds like a pin pong game whenever it runs. No it is not the fans or the ice maker.
Nov 29, 2007 | Maytag MSD2454G Side by Side Refrigerator
Freezer not working
The compressor does run warm but not hot, if the freezer is not cooling then the comp is faulty, approach local repair agent for cost. Regards The Advisor Smeg Agent
Aug 20, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Fridge/Frezer stop working
Can you tell if the compressor (black soccer ball looking thing in the rear of the unit) is running? Is it really hot? Is the little fan running near it? If the compressor isn't running it won't cool. Also check that the coil in the freezer section isn't frozen solid blocking all air flow inside the unit. The other thing is that the defrost cycle may be "stuck" so it thinks it should be defrosting (therefore not running the compressor, etc.) Lots of things to check but that info will help decide which way to go so post what you find please.
Dec 30, 2006 | Zanussi ZX56 / 4 Bottom Freezer...
Maytag Appliances Magic Chef 18 cu. ft. Top Mount Refrigerator Logo
175 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
