The main difference in the series is the dropping of the Australian-made V8 engine, which has been replaced by an American-built Generation III 5.7-litre alloy V8. The American-built engine has more power and torque.
<img src="itunes-u-on-ipad-2.jpg" />
I've got a bunch of YouTube videos and stored them on my PC. Some of
them are FLV formats, and some are MP4 formats with higher resolution.
All of these YouTube videos couldn't be played back on my new iPad. Now
I'm looking for a good ipad video converter that converts YouTube to
iPad supported video formats.<br />
Finally I picked a YouTube to iPad converter tool called <a href="http://www.freedvdripper.org/dvdvideoconverter/ipad-video-converter.html">iPad video converter</a>
software. This software is a free trial application that accomplishes
this task quickly and easily. It just takes a few mouse clicks to
convert YouTube to MP4 files using this YouTube to iPad Converter
software.<br />
Here I'll show you how to <a href="http://www.freedvdripper.org/dvdvideoguide/load-youtube-videos-to-ipad.html">convert youtube videos to ipad</a> step-by-step easily.<br />
Step 1: Download & install <a href="http://www.freedvdripper.org/freeresource/free-ipad-video-converters.html">free ipad video converter</a>.
We'll be using the very nice YouTube to iPad video converter software
called iPad video converter for converting YouTube to iPad compatible
video format. Next step is to install this YouTube to iPad Converter
software.<br />
Step 2: Run iPad video converter and add YouTube videos<br />
Now run iPad video converter and click the big button "Add..." to add
YouTube flv/mp4 videos from your hard disk, you may add as many YouTube
videos as you want to convert to iPad H.264 videos for watching on iPad.
Only the titles you checked will be converted.<br />
Step 3: Edit & merge YouTube videos: trim, crop, add effect, add watermark<br />
Wanna edit your YouTube videos to make it more personalized? You may add
a watermark in iPad video converter. Just select the title you'd like
to add watermark, then click the button 'Edit' to launch video editing
window. If you want to crop video or add some special effects, click the
first two tabs.<br />
Step 4: Change the output settings to convert YouTube to iPad<br />
You'll find a wide range of preset video setting options avaiable for
Apple iPad. You may select "iPad MPEG-4 (640*480) Video(*.mp4)" for
converting YouTube videos to iPad supported videos. Remember that the
output file size and converting speed mostly depends on the Bitrate you
set. Larger Bitrate, larger file size and longer convertion time.<br />
Step 5: Start converting YouTube to iPad video format<br />
Now you may click the big button "Start" to begin converting YouTube to
iPad compatible video files. Once the convert is complete, iPad video
converter will place on your Desktop a new iPad format version of your
video that will play on the iPad. Double-click the new file and play it
to make sure it looks as you expect.<br />
Step 6: Transfer/Sync video to the iPad<br />
To get the movie onto your iPad, launch iTunes. Drag your new converted
movie file into your iTunes library in the folder or playlist of your
choosing. Attach your iPad to your computer and sync the iPad with
iTunes. Check the option "Automatically sync songs and videos to my
iPad" so your music and video from the iTunes library will automatically
snyc to your iPad. The sync may take a few minutes. When syncing is
done, eject your iPad and take your movies with you.<br />
Related Topic: <a href="http://www.freedvdripper.org/dvdvideoguide/converting-videos-for-ipad.html">converting videos for ipad</a>, <a href="http://www.freedvdripper.org/">free dvd ripper</a>.<br />
Fron first principles, the reverse movement of the motor is caused by reversing power polarity to the motor. If he motor runs in one direction and not the other then it isthe switch. It is not conecting power to the reverse contact. Check.replace switch.
this could be a variety of problems, but from my experience, if there is no short in the power supply cord, or you have a good battery and power brick, the only other problem that i have ran into on this subject, is where you plug in the power cord to the pc, behind that plug on the mother board, there is a connection which may have become loose, all you have to do is resolder that connection and you should get power. hope this was helpful, a pain to do
You don't mention a make or model, so I can only give you general solutions. If the radio has a drop-in charger there may be a light to indicate charging. If the light comes on when the radio is in the charger, it's getting a charge. If you have a multimeter, DVM, or DC voltmeter you can check the battery voltage (charge) both before and after a charging cycle. You can also use the meter to confirm the output from the charger. If possible, replace the batteries with standard alkaline types and see if the radio works. I hope this info helps.
