I HAVE A 52INCH ZENITH DLP PROJECTION TV AND IT BLINKS GREEN FOR AWHILE THEN TURNS RED THEN BLINKS 8 TIMES THEN STAYS SOLID RED AND NEVER TURNS ON WHAT IS THE PROBLEM ? MODEL NO.Z52SZ80
SOURCE: sharp DLP No picture
i have a 56DR650 and it does them same thing. It is still under warranty but where i bought it, they said they can no longer fix it so they are giving my money back. the problem has to do with the color wheel inside.
Posted on Nov 11, 2007
SOURCE: light blinks 8 times
I did a last minute search to do the repair myself before I called somebody. I found this and figured "This will never work!"
I followed his suggestion and now my TV looks better than it has in months!!! I'M SO RELIEVED!!!! Although I really want to upgrade to a flat screen LCD or PLASMA but I'm not ready for the expensive. I have had this SONY for about 6 years!!
THANKS TVDUDE!!!
Posted on Feb 08, 2008
doin12volt
  • 233 Answers
SOURCE: STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
turn the tv off, hold down device and menu buttons on the front for 5 seconds, you will get a code flashed out through the LED's.. the codes are as follows:
12   No error detected 22   Recovery from momentary Reset 32   Lamp Cover open 33   Air Filter Cover open 34   Lamp abnormality 35   Chassis Fan failure 36   Exhaust (Back Cover) or Lamp Ballast Fan failure 37   Engine (DMD or Lamp) Fan failure 38   Excess Lamp Temperature 39   Excess DMD Temperature 41   Short Detected 44   DVI Cable (between Chassis and Engine) disconnected
Posted on Dec 19, 2008
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Posted on Jan 07, 2009
ladywinn
  • 5138 Answers
SOURCE: zenith 56" DLP Z56DC1D won't turn on
Replace Lamp and CK both Fans to make sure they are running.If Fan behind Lamp does not run TV will not light LAMP.
Posted on Jul 20, 2009
Tv light blinks green then solid then red
Hello:
From the sound of your description of your problem you likely have a defective lamp. Feel free to give us a call at 866-764-5822 and we would be happy to help you troubleshoot the problem over the telephone.
Best Regards
Dan
DLP Lamps Projector Lamps Specialty Lighting
Mar 31, 2014 | Mitsubishi WD Televison & Video
My Zenith plasma TV blinks green 4 times then goes red, No picture. None of the Capasitors are blown.
I had AWFUL customer service. (Sherry is DREADFUL her # is 1-877-543-8325 she is in"executive services". Ask to speak to her directly...if you would like ZERO help.)
They WILL NOT extend the warranty, even though they know there is a defect with this AND other models. Zenith name on the front...LG guts in the inside.
Ours turns on, screen black and then clicks three times and then turns back off.
Jul 13, 2012 | Zenith Z50PX2D 50 in. Plasma HDTV
I have a 2005 zenith 52 inch model# Z52SZ80 heres the problem i replaced the lamp and when you turn it on as soon as the picture comes up the lamp shuts off and the red lamp light blinks 8 times then...
This is a DLP tv wright?Problems with many DLP tvs after changing the tv projection lamp,tvs still have the same problems or make alots of cliking sound too.The board that call the Ballast baord is also is dead.The Ballast board only job is to ignite the tv projection lamp.
Mar 01, 2011 | Zenith Televison & Video
Tv turns on and off 3 times before picture appears
Ballast Board its what turns Lamp on Call Encompass or visit their website. 1-800-638-3328
Dec 14, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Zenith 56" DLP Z56DC1D won't turn on
Jul 20, 2009 | Zenith Z56DC1D 56" Television
Zenith 52'' dlp tv won't turn on
after an hour tv shuts off and you have to wait to turn it back on
Jun 12, 2009 | Zenith Televison & Video
WD-62725 DLP TV Automatically Turns Off
Its usually your DM control board!!! it needs to be replaced!!!
Mar 29, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Temp ted light blinks twice then turns off tv
Your lamp might be bad. Also, it is possible that the lamp door is not closed.
Nov 21, 2007 | Zenith R57W46 57" Rear Projection...
Televison & Video Logo
207 people viewed this question
Top Televison & Video Experts
Electro Med Services...
