Question about GE 25GT240 25" TV
Antenna connector broken off on tv
How to repair the connector on a tv for cable hookup
  • 3 Answers
Re connect piece or new piece with soidering iron done it many times for friends
Posted on May 13, 2009
I moved and cant figure out how to hook my 4030 channel master antenna up again. I have a converter box and hd toshiba tv
INSTALLATION
Channel Master by PCT indoor antennas are designed to provide optimum reception of
UHF / VHF and FM signals. These antennas have 75 ohm outputs, which allow simple,
hassle-free connections to today's newer TV sets that have 75 ohm F type connector
inputs.
Simply attach one end of the supplied 6' cable with F connectors to the output of the
antenna (Fig.1). Attach the other end of the cable to the input of the TV set or VCR
(Fig. 2). Some adjustment of the antenna might be necessary for optimum viewing.
Model CM-4030 includes a built-in amplifier and separate power supply.
1. Follow the same steps as above for antenna to TV / VCR hookup. Note : Model
CM-4030 also allows for two set / VCR hookups with its unique dual output feature.
2. Insert the power injector into the back of the antenna (Fig. 3). Plug in the power
transformer to the closest electrical outlet (Fig. 4).
Google 4030 Channel Master Instruction Sheet for the PDF File with the diagram.
Fig 2a
Fig 3 Fig 4
prohibido por ley.
TV
Fig 1 VCR
Fig 2
Fig 2a
Fig 3 Fig 4
Jan 10, 2014 | Channel Master 4030 Amplified indoor HDTV...
Hello, my 25" Magnovox (#mt2501c)
Tv fell off about 3 feets or more?Yes,turn on the tv see if u getting any power to the unit?Might have broken main PCB board too.If unit still have power,check see if tv get statics screen have colors shaded in red or mutiples colors,mean the tv CRT(tv tube) yoke is dead and damages scrambles radiation.Or the tv getting power but have high pitch sqeeling noises or rattles noises,tv have the CRT-(tv tube) is crack by the neck or broken totally.CRT have damages problems or dead tv is worthless,beacause of CRT(tv tube) is dead,not fixable even that antena connector input is replaced.
Feb 17, 2011 | Philips Magnavox MT2501C 25" TV
The cable hookup has fallen out of the panel in
You need to find someone to reinstall the connector. If I was closer it might be a simple repair. Email me at.... poikaa@yahoo.com
Feb 15, 2010 | Vizio VW42LF 42 in. LCD HDTV
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
We are trying to hookup to cable. The TV screen
TV is in antenna mode, enter the setup menus and put in cable mode.
Oct 08, 2009 | Zenith B27A11Z 27" TV
Cable hookup broken
Sometimes you can replace the rf connector by resoldering it with a replacement rf. You will have to remove the tuner to do this. The big question is did you crack the tuner board or the board the tuner is connected to. You will really have to examine these. In most of my cases a successful replacement rf connector will fix.
Aug 24, 2009 | Sharp 27N-S300 TV
Where is the cable or antenna hookup located
The only cable or antenna hookup on any tv is the f-81 connector on the back or side. Its silver and you screw the cable on. Alot of new tv's dont have them especially the ones that are considered monitors. If that is the case you can get a reasonably priced rca adapter from and electronic store. What it does is the cable goes into to it and the red white and yellow cables will run to your tv.
Aug 22, 2009 | Televison & Video
Digital to analog converter box hookup
You will have to go to Radio Shack or Wall Mart, maybe Home Depot and get a matching transformer. That will have spade terminals on one end to connect to your tv and a round (75ohm male thread) to hook to your converter box.
Jan 08, 2009 | Televison & Video
Cable connector broken
You can buy replacement antenna jacks for this. What you have to do is remove the tuner and it's shields, then unsolder the little tab off the board of the tuner which is what remains when they break off. Then you can resolder the new jack in place and the center pin back to the board of the tuner.
Mar 28, 2008 | RCA HD52W59 HDTV Projection Television
1996 32 inch Panasonic TV
What you are calling the "antenna module" is actually the tuner. The connector that pulled out is called the F connector. The F connector can be soldered back onto the tuner but this is a very delicate procedure and is especially difficult if any of the coils in the area of the F connector have been bent, altered or moved. The tuner itself is not too expensive and is much easier to replace than trying to replace the F connector, especially if you have never done one before. If you use this set with a cable box then simply connect AV cables from the cable box to the TV set the TV to VIDEO.
Jun 27, 2007 | Panasonic CT-32G23 32" TV
GE 25GT240 25" TV Logo
447 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
