Question about Dell XPS M1210 Notebook
My pc isn't recognixing my mp3
I plug in the usb cord that came with my OPAl mp3 player into my windows xp, which is supposed to be compatible, but the computerr will not recognize the device, but it works with vista, which is also compatible.
    Sergeant:
  • 138 Answers
It sounds like you need to install the driver for the mp3 player on that computer.
Posted on May 13, 2009
How do i transfer all my music video's from my music file to my opal rca mp3 player when i plug in my mp3 player.
This unit supports windows xp and vista Just have windows media player locate all your audio and WMA compatable videos. Then use the sync feature at the top of your windows media player to create a sync list on the right hand side by dragging your stuff over to that area .Use start/sync button in the lower right corner this should get you loading your player!!
Jul 02, 2009 | RCA opal MP3 Player
Can't get my mp3 player to charge, or turn on.
look on back or sides their might be a lock button on it and it might be locked soyou cant use it
Dec 16, 2008 | RCA OPAL M4001 MP3 Player
How do i put music,videos and pictures in my opal
Most laptops do not have a USB port that is powerful enough to fuel an mp3 player.
This player is not compatible with Vista or Mac
Make sure the hold/lock key is not engaged
Make sure your laptop USB port is enabled
Make sure you have Windows Media Player 10
Sep 27, 2008 | RCA OPAL M4001 MP3 Player
Windows vista does not acknowledge Opal M4002a
If the player is not recognize try to connect the mp3 player ona different usb port and check if it will be detected if still not detected better connect this mp3 player to another pc and check if it will be detected on that second pc if not detected there's a possibilty that the mp3 usb functions is not working fine.
Jun 20, 2008 | RCA OPAL M4001 MP3 Player
Hung in a transfer loop after being removed from PC
When I (USB) plug in my RCA Opal M4002A mp3 player into my "Office PC" it works fine, but when I plug it into my "Studio PC" the "Opal" screen shows "USB connected" and so does the "PC" with the "Device Connected Sound" but then the "Mouse Pointer" changes to the "Hour Glass" you hear the "System Notification Sound" then the "Mouse Pointer" changes back to the default "Arrow Pointer" and this back and forth action loops endlessly until I unplug it. I've tried everything. Any ideas would be greatly appreciated. Thank You, Quaal
*** ONLY THIS PART OF THE ABOVE MESSAGE IS MINE ***
ALSO I HAVE THE "RCA Opal M4002A" (2GB) mp3 player.
*** After much trial and error this FIXED my problem. ***
1 - First right mouse click on "My Computer".
2 - Left click on "Properties"- Left click on "Hardware"- Left click on "Device Manager".
3 - Now with one end of the USB cable plugged into your mp3 player, plug the other into your USB port. (Now when I did this a new "Portable Device" icon with an "MTP" Driver (sub icon) showed up in the "Devices List". (The "MTP" icon had an "!" on it, telling my it wasn't working properly. I then did this.
4 - Right click on "MTP" driver icon, then ...
5 - Left click on "Update Driver". (I was then given two choices. The top one was the faulty "Portable Device" driver which I had done everything I could to fix, but nothing worked. So I then did this ...
6 - Left click on the "Mass Storage" Driver (the second choice below it in the list), I then clicked "OK". The "Updating Driver" screen showed for a moment. The "Portable Device / MTP Driver(!)" icon vanished from the "Device Manager" devices list, But the looping STOPPED!!! My Opal was working beautifully and showing in my "Root Directory" as Drive j: and in "Device Manager" under "Disk Drives" as "Thomson Opal USB Device".
P.S. For some reason the file transfers are noticeably faster now. Good Luck, Quaal
May 21, 2008 | RCA OPAL M4001 MP3 Player
RCA OPAL M4002 mp3 player
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 20, 2008 | RCA OPAL M4001 MP3 Player
Rca opal m4018a
Hi, you can try to upgrade the player's firmware, you can download it from the RCA Website (moz-screenshot.jpgmoz-screenshot-1.jpghttp://support.rcaaudiovideo.com/downloads.aspx?product=187), the firmware it's the second app listed.
If your computer doesn't recognize the player, you'll have to turn it off and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Feb 02, 2008 | RCA OPAL M4001 MP3 Player
Opal 8gb
Hey, I have the same MP3 and I have Windows 98. I didn't try to install the CD that came with it. All you have to do is plug it into your USB port in the back.
Hope it works,
Shannon
Dec 25, 2007 | RCA OPAL M4001 MP3 Player
Computer won't recognixe
Connect it to pc close the window that pops up go to "my computer" find and right click on the device letter and select format (do a full format not a quick) then when finished select safely remove device and unplug usb then shutdown player and reconnect to pc and see what happens. remember to always safely remove device.
Nov 12, 2007 | SanDisk Sansa e250 MP3 Player
My rca disk they gave me in the package says it wont download
No. Your RCA Opal is a plug and play device 1. Plug USB cord into Headphone Jack (you MUST use the USB that came with the RCA Opal) 2. Plug USB cord into computer 3. Wait... 4. In my computer, it'll say "usb device" or "drive f" or whatever 5. Open "media" folder on that drive 6. And put your Mp3s on there. if you can't do that, than you need to upgrade your computer. Not many MP3 players support ME.
Aug 10, 2007 | RCA OPAL M4001 MP3 Player
Dell XPS M1210 Notebook Logo
26 people viewed this question
Alun Cox
