Question about Refrigerators
Ewave EWR121W Refrigerator leaks. The drain is
Ewave EWR121W Refrigerator leaks. The drain is stoped up. Where is the opening where the water should enter the drain from the defrost cycle?
  • dwsmith382 May 13, 2009
    Thanks, Vic for the reply. The drain line is stopped up (I tried
    to blow through it from the bottom of the line). I used a hair
    dryer to defrost the coils at the back of the freezer compartment
    (which is on top), and poured hot water over the coils, but it ends up
    in bottom of refrigerator and drains onto floor. Any other
    ideas?
    Vic, I still cannot find the hole inside the refrigerator where the water is supposed to drain out of the refirgerator into the tube.
    President:
  • 1,136 Answers
THe drain should be in the freezer and it should drain in a pan below the unit. Newer models have the drain pan molded into the frame work around the compressor. If there is no ice build up in the freezer, you might be able to try and blow through the drain line and get it cleared out.
I hope this helps and if I can assist you further, please let me know.
thanks
Vic
Posted on May 13, 2009
  • Victor
    Victor May 13, 2009
    Just keep trying to get the drain all the way open. It is probably still got ice down further. If it was something other then ice, you would be able to dislodge it by blowing on it. If you have a baisting seringe, you can try and blow the warm water down the drain. It might take few tries and few minutes. After using the hot water, Try and rmove most of it before adding more. Please let me know
  • Victor
    Victor May 13, 2009
    The drain hole is located in the freezer section. I am sorry if I wasn't clear on that. I tried loolking up you model and it isn't working with that #.
Why doesn't Ewave refrigerator model EWR121W doesn't get cold?
The cold control (thermostat) may be defective
Apr 10, 2013 | Refrigerators
Ewave model ew121w is leaking at the bottom of the fridge on to the floor. I have the back off and the drain tube seems to be clear but I can't blow air back up to where the water is coming from so...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 05, 2011 | Refrigerators
EWR121W-water accumulates at bottom of fridge.Do I need new seals? thanks
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Jul 30, 2011 | Refrigerators
Have side by side 10 years leaking water on floor in front of refrigerator there is no water connected to refrigerator, cant find an overflow pan under neath...
clogged drain causing the water that cant reach the drain pan underneath to leak on the floor. Unplug fridge and open doors for 24 to melt ice likely clogging up drain. If that doesnt fix, you'll need to call refrigerator repair service
Jul 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a leak inside of the refrigerator. Water
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website). If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction. Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
Mar 20, 2010 | Refrigerators
Roper refrigerator leaks
Good job! most people do not know about the evaporator drain.
I would check the tubing to the icemaker, icemaker inflow valve and, water filter.
Jan 23, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
I have a refrigerator that leaks water inside at the top
flush out drain hose in drip tray in back of ref with hot water line is most likely stoped up
Sep 14, 2009 | GE Refrigerators
Water leaking into the drain pan
if the pan on the compressor on plug unit get a rag and sock up the water i beleave you doors staying open to long
Mar 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
995 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
