Question about Electrical Supplies
Digital inverter generator needs retiming
Is of chinese manufacture,2600w.popular on ebay,only id is xg-sf3000.i cleaned and polished valves and reset gap and lost timing.can you assist.
  • monjohn8 May 13, 2009
    request timing procedure for digital inverter generator.
  • 5,807 Answers
Can your motor run even for a while? or it is not totally running? please try to check the electrical wiring of the cdi there might be a loose in the connection. without this cdi running, it wont start properly. check or replace spark plug if necessary. it might be corroded or wet with oil , the gap should not be more than the thickness of a metal saw blade. hope this help
Posted on May 13, 2009
  • 433 Answers
How do I reset my apple id password and name
To change your Apple ID, and for any other issues relating to your Apple ID, check out Apple's support page on it here:
Apple ID Changing your Apple ID
Sep 16, 2014 | Apple iPod 5th Generation
XG-SF3000 has flat battery
There is NO battery on this generator! It is pull started by a handle that is built in to the machine.
Jan 12, 2013 | Cars & Trucks
Digital Inverter Generator XG-SF3600 running but no current
i have the same problem. I have AC from the windings but nothing leaving the inverter module..Its a sealed unit. There is virtually no parts back up service & if you can track down parts, they are quoting from $ 400 to $ 700 for replacement..If you expect this gen set to last like a honda or yamaha your mistaken..Dont buy chinese unless your short of folding stuff or you only use your gen set occasionally & for those that have had no trouble with theirs, its only a matter of time. trust me, they are a disposable item..
Sep 06, 2010 | Electrical Supplies
Listening to sirius satellite radio and "reset 8" message flashed
The Sirius tuner is bad. 1000's were sold and 1000's have been replaced! The new model will work with your unit and does not fail, it's manufactured by DEI not Audiovox. Or, you can check Ebay for a rebuilt tuner for around 40-50 that has the problem fixed and corrected. Hope this helps.
Sep 26, 2009 | JVC KD-G230 CD Player
I need the screws to mount my monitor to its
You can get them from the manufactures website or also check ebay.
Aug 14, 2009 | Computers & Internet
I have a xerox XG-91D and when i power it up there is no picture and the green light flashes. how do i fix this?
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's the problem. You can confirm that it's the monitor and not your computer or the cable by plugging in another monitor if you have one to try.
If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
Jun 05, 2009 | Xerox XG-91D 19" LCD Monitor
Generator hard to start. Kick back
This sounds like the timing is off. Remove the spark plug and pull the cord to see if there is less tension. If there is less tension then you know that the pull cord is fine. Do a compression check on the cylinder, it should be around 100psi. Remove the valve cover and check to see if valves are moving when your pulling the cord. The valves could have came off the rockers.
May 19, 2009 | Electrical Supplies
Logic board for xg-91d serial number E98Z5501032U
I can repair your Main logic board. I do repair work on ebay. my I.D. ecking767. Or search for Xerox under Computer and Networking
Nov 12, 2007 | Xerox XG-91D 19" LCD Monitor
Electrical Supplies Logo
157 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
