Question about Maytag Dryers
How do I open the dryer to get to the area around the tub
The dryer smelled hot when I turned it on, so I want to vacuume around the tub area. I clean the lint catcher out EVERY time, but I can't figure out how to get the dryer opened, apart? to clean that area..
Model # LDE9801AOW
SN A5107309
  • 460 Answers
I hope this works for U
http://repair2000.com/dryer.html
Was this helpful?
Posted on May 13, 2009
I have a walk-in jacuzzi-type bathroom tub. When the automatic blower comes on it sends out a mildew smell. How can I get rid of it?
First of all, after each use, refill the tub with warm water and run the jets for about 10 minutes to clear out any excess debris etc.
To eliminate the smell/mildew/mold. :
-Fill the tub to above the jet level with HOT (over 140deg.) water
-Add two tablespoons of low sudsing dishwasher detergent and five cups of distilled white vinegar
-Run the jets for 20 minutes
-Drain the tub and use a tooth brush or any small brush to gently clean inside and around all of the jets and nozzles, remove all foreign material you can from the areas inside (disassemble the outter rings to do so) and around the outlets. Be as thorough as possible.
-Rinse and refill the tub with CLEAN COLD water and run the jets for another 20 minutes.
-Drain the water and the smell and mildew should be eliminated.
To prevent future mildew build up/odors once a month fill the tub with HOT water (again) and four to five cups of vinegar (no detergent) and run the jets for 20 minutes. Drain and fill with clean cold water running jets another 20 minutes. If the tub is used very often you can increase the scheduled flushing of the system to every two to three weeks. The mildew/mold flourishes in the warm wet areas inside the jet tubing and nozzles. Diligent maitenance is the best way to make sure you're not bathing with any unwanted guests in your bathwater!
-Take care
Mar 01, 2012 | Washing Machines
LG TROMM -WM1814CW I bought the washer and dryer
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@(((
Aug 09, 2010 | LG WM1814CW Front Load Washer
Neptune MLG2000A doesn't drain completely and has moldy smell
You need to clean the stationary "brush" that collects lint and debris from the water during the cycle. The brush can be seen around the tub directly touching it along the bottom/front of the device. Right were I pour my detergent in, after the cloths are in there. To remove the debris I use a bottle brush. You can expect to use trial and error for your attempts. As far as the water being left.... My device has always left water in the bowl. I periodically just run a cycle with no cloths and bleach...HOT.....Mine is not spinning at the moment...again....I think its another call to the local dealer....AGAIN....
Jun 11, 2010 | Maytag Neptune MLG2000A Front Load Stacked...
Ge DRYER dpgt750EC2PL back wall of drum gets very hot. Occassional smell as if something starting to burn. How do I open the top lid to get inside to find out problem
This may sound a bit over simplified but when a dryer starts to get hot inside it is a sign of an airflow problem.
Start with the outside vent flapper. Check to see if there is lint build up on the flapper / louvers.
Pull off the vent hose and check for lint build up. If the vent hose is a flexible plastic hose they have a tendancy to clog with lint in the sprials and then the lint contines to build up until airflow is restricted.
After checking external vents and ducts next remove the lint filter. If you use dryer sheets wash the filter with white vinegar to remove the build up. It may appear clean but the material from the dryer sheets clogs the filters.
In the area around the lint filter check the ducting / air passages for lint build up and clean it.
In the process of all the cleaning do NOT use anything sharp. A vacuum crevice tool and a Looped metal coat hanger do wonders for cleaning assistance.
Before you reconnect the dryer vent try running the dryer with a light load of anything wet to see if it drys properly with the vent disconnected. After that reconnect the vent and repeat the same drying test to see if the drying times are close to the same.
This should solve your hot dryer problem.. If it does not then respond here and we can talk about taking your dryer apart.
Thanks for using FixYa.
Kelly
the air flow out of the dryer it should be a very high volume.
Mar 15, 2010 | GE Profile Harmony DPGT750EC Electric...
Kenmore Elite HE3 Gas Dryer putting off an odor...smells like something is burning
Jan 18, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
I have a Maytag Neptune dryer and it is only about 2 years old. I have several animals and yesterday, I opened the dryer and smoke started to come out. It was clearly the smell of burning hair and there...
hello mam remove the back cover of the dryer and detect for any rats and cockroaches, clean it and check the thermostat of the dryer.
Oct 02, 2009 | Dryers
Odor around the lint trap, cleaned but persists
The lint trap is an opening into the dryer vent and vent pipe. The dryer needs to be pulled out from the wall, the vent pipe disconnected and then the back of the dryer and the entire pipe cleaned of lint and other debris. this is the only way to get rid of the odor.
May 20, 2009 | Dryers
Nasty mildew smell from washing machine
May 02, 2009 | Washing Machines
Burning smell and not picking up
check for blockabe in bag inlet area, or bottom of unit by intake pivot.
ez check is to feel if bag blows firmly up with air when on, if not, you have a blockage.
Nov 02, 2008 | Oreck XL21 Bagged Upright Vacuum
Dryers Logo
78 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
