Question about Ionic Pro CA500 Air Purifier
Need to clean blades
I need to clean the blades
    President:
  • 3,433 Answers
They should lift out of housing like a cartridge. wipe down with soap water, dry and reinstall. May have a retainer scre/knob on top or twist off cap good luck
Posted on May 13, 2009
The blue light blinks
I believe that a blue blinking light indicates that the stainless steel collection blades need to be wiped clean. The unit uses these blades instead of a replaceable filter. Simply wipe them clean with a damp cloth and you should be ready to go!
Jun 24, 2010 | Sharper Image Ionic Breeze 3.0 Air...
Do I need a new fan blade if I replace the fan or will the old one go back on fairly easy? Ecoquest fresh air
If you need to replace the fan motor, the fan blade can be removed by grasphing the center hub of the fan and pull the fan straight out of the purifier. I remove it every time I clean my machine, since it easy to clean it once it is removed.
Nov 21, 2009 | Ecoquest Fresh Air Air Purifier
My ionic breeze doesnt seem to blow any air at all cleaning light stays off Is this normal?
best best is to unplug the unit, and clean the blades completely with a damp cloth, then wait a few for the blades to dry and put them back in the unit. usually cleaning these every 2 to 3 weeks and they should be kept clean to be effective at removing the contaminants in the air. theirs alot of controversy over thease untis thease day's butthey do fuction properly if kept in top condition. also note that the blades must be properly seated in the houseing to work. safty feature that if bumped or knocked down it will cause the system to mostlikly stop working till you pull the blades out and put them back inj. i observed this myself with a model and they are failry good quality but a pain to clean. good luck with it.
Aug 22, 2009 | Sharper Image Air Purifiers
I have an ionic breeze quadra aironly one of the blades works the other two are clean when I pull out the baldes to clean them
He gave me a lot of information about cleaning,Which I already have and have done, but did not answer my question about the replacement blades.
Apr 14, 2009 | Sharper Image Ionic Breeze GP (SI730) Air...
RED CLEAN LIGHT
After cleaning the unit, blue light turns on momentarily then red cleaning light comes back on. Have cleaned and dried unit including the contacts on the end (cleaned with alcohol). Sounds like a common problem, any solution?
Bob
Jun 17, 2008 | Ionic Pro 901P2RIP04 Air Purifier
Blades
Does anyone in your house smoke? Could be from cigarettes. I was told by the Ionic Pro Company to clean the blades with rubbing alcohol.
Mar 29, 2008 | Ionic Pro TURBO Air Purifier
Ionic pro turbo
You need to clean all the stainless steel contact points inside the unit, not just the blades. Make sure you unplug the unit before doing this.
Mar 01, 2008 | Ionic Pro TURBO Air Purifier
Excessive noise
I found that the buzzing can be removed by blowing out the unit, cleaning the blades and taking a long cotton swab and alcohol to thoroughly clean the corona wire - carefully - don't break it. The wire should be clean enough that the slider/wiper runs smoothly up and down the wire after cleaning. If it drags or is rough to slide, you will still have noise no matter how many times you clean the blades. The wire gets a "crust" on it.
Oct 26, 2007 | Ionic Pro TURBO Air Purifier
Ionic pro won't turn on
Solution, perhaps...
All electrical contacts can get a film on them. Try cleaning the contacts (at the bottom of the blade unit; you should see the three with the blades out) with an alcohol swab (make sure the contacts are dry before reassembly in this case) or a pencil eraser (vacuum the debris out before attempting to start it again).
If those contacts don't make up properly, the unit will think it needs cleaning, even though it doesn't.
Mar 27, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Ionic Pro CA-500B Power On Instant Clean Light
If the plates are clean, there is nothing wrong with them. They are just 3 strips of metal... they don't even connect to each other unless they are in the unit. NO NEED TO REPLACE THEM.
Sep 13, 2006 | Ionic Pro CA500 Air Purifier
Ionic Pro CA500 Air Purifier Logo
123 people viewed this question
Top Ionic Pro Air Purifiers Experts
Thomas Perkins
Thomas Perkins
Brett Duxbury
Brett Duxbury
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
