Question about Homelite 'Yard Broom' Leaf Blower
I have a Homelite Yard Broom gas blower that won't prime/stalls.
I have a Homelite Yard Broom gas blower. I've had problems with lack of power on full acceleration for a long time. I lived with it. I would have to open & close choke a few times while running and warmed up to maintain power. But just recently it will start run at all; starts & stops immediately upon acceleration. Prime bulb draws no fuel into it (bulb compresses but stays compressed for long ttime). Also when I try & start it and open the choke the gas spills into the air filter & drips on the floor. I took off fuel lines, replaced one & checked for blockages; none noted. A neighbor said maybe the diaphragm is torn? What to do? Thanks, Jim Devine - Bethpage NY
  • tadee May 13, 2009
    Will idle but not go to full power. It just dies, looks like fuel starvation of some type.
  • sodevine69 May 14, 2009
    Thank you John for sharing; I am going on vacation Friday for 2 weeks. God willing, when I return I will follow your guidance as best I can. I love taking on stuff like this when I am guided by an expert. Re: cleaning carb please help me understand a few comments you made. (1) What does "a breakdown/IPL" mean" for cleaning a carb? (2) The carburetor on this blower seems very small. Do you mean that I need to buy a 1 Gallon can of Gunk Carb cleaner or get an empty "gallon" can (say coffee/juice etc. ) and put enough Gunk in it to completely immerse the carb? (3) Where can I buy a "kit"? Bless you, Jim
  • 246 Answers
Hello sodevine69:
>>From your Description it Sounds like the Fuel Filter in the Tank Requires Changing, the Carburetor Metering Jet is Stuck, the Carburetor Filter/Screen is Restricted and Requires Cleaning/Replacing or the Carburetor Requires Cleaning.
>>The Following is a Basic Instruction File I made for Replacing the Fuel Lines and the Filter on Chain Saws and Trimmers. Any Input is Appreciated.
>>The Fuel Line is Pushed and Pulled (I Use Long Needle Nose Pliers) Through the Small Hole Until the Hose is Out the Fill Hole about a 1/2".
>>You can Also Use a Coat Hanger with a Small J at the End to Hook the Filter in the Tank and Pull the Filter and Hose (if Detached from the Carburetor) Out the Tank Fill Hole Enough to Replace the Filter.
>>Then Attach the Filter and Pull the Hose Back Until the Filter Lays at the Bottom of the Tank Just Below the Fill Hole (or so it is in the Bottom of the Tank and will Rest in the Fuel Mix when Turned at Common Angles the Unit May be Turned to During Operation.
>>**Hint: Use Plenty of Spray Lubrication at the Small Hole as you are Feeding in the Hose. It Slides Easier.**
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace are the Needle Valve and Metering Pump Diaphram.
>>The Metering Pump Diaphram is Under the Carburetor Plate with 4 Small Screws in it.
>>The Dowl on the Diaphram should Just Touch the Metering Jet Actuator Arm.
>>The Actuator Arm is Adjusted by Carefully Bending the Actuator Arm Up or Down to get the Correct Clearance.
>>If you Order a Kit, then Replace All the Old Components with the New Ones in the Kit even if the Old Parts Look Good.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers.
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine.
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
  • John C Bridgers Sr May 14, 2009
    Hello Jim:
    >>A Breakdown is an Exploded View of the Carburetor that Shows the Carburetor in a Manner that almost Anyone can Disassemble and Assemble the Carburetor with Very Little Chance of Assembling the Carburetor Wrong.
    >>If a Carburetor Breakdown is Not Avaliable with the Breakdown of the Unit (Homelite Site), then I will Require the OEM and Model Numbers Of the Carburetor so I can Direct you to the Correct Site that has the Carburetor Breakdown.
    >>Usually if you can Purchase the Carburetor Cleaner in a Small Enough Amount to Just Cover the Carburetor, then doing so is Fine. Most Times you will have to Purchase a Gallon and Use the Can as I Stated in the Carb Cleaning File I Sent you Earlier.
    >>The CArburetor Cleaner can be Used to Clean Other Parts also, so the Gallon will Not be Wasted if you have to Clean Other Parts Over Time.
    >>A CArburetorKit can be Purchased fro your Local Dealer or from www.outdoordistributors.com @ 877-707-2787.
    >>Have Fun on your Vacation and have a Safe Trip.
    >>Till Next Time. May All Your Mechanical Problems be SMALL ONES and as Always, May the All Mighty Bless You and Yours. Be Safe and Happy.
    Best Wishes and Good Luck
    Respectfully
    jbridger (John)
Need to know the oil and gas mixture for a homelite yard broom II
The manual probably says 40:1 (3.2oz.oil to 1 gal gas) but if you use a good modern 2 cycle oil,50:1(2.6oz .oil to 1 gal gas) will suffice.
Jan 31, 2011 | Homelite 'Yard Broom' Leaf Blower
What fuel does the homelite yard broom 2 take
depends if its 2 or 4 stroke if its 4 stroke the just regular gas if its two stroke then mixed gas and the ratio is 32:1
Jan 20, 2011 | Homelite 'Yard Broom' Leaf Blower
Yard broom leaf blower will not stay running I
It seems that the carb is not getting fuel. It could be a cracked fuel line. The fuel priming bulb could also be cracked/dry rotted. Possibly the fuel pump in the carb is bad. The carb is rather intricate and not something anyone without training should try to repair. The overhaul kit will cost $15 to $20. I suggest you take the blower to a repair shop.
Apr 19, 2010 | Homelite 'Yard Broom' Leaf Blower
I have borrowed a small Homelite leaf blower with
If you go about 32:1 you will be OK. It may be a 40:1 unit, but better safe than sorry if you are not certain.
Mar 07, 2010 | Homelite 'Yard Broom' Leaf Blower
Runs but no power stalls now you give it the gas
fuel problem clean out carb and jets add fuel system cleaner .if no go use easy start
Dec 19, 2009 | Homelite 'Yard Broom' Leaf Blower
Blower stall after few seconds
sounds like you not getting enough gas,or you are getting air in gas line,, check for air bubbles in gas line,, if you dont have any then clean the carb. good,, hope this help you
Aug 29, 2009 | Homelite 'Yard Broom' Leaf Blower
Just bought a used leaf blower, homelite, gas leaks out of the gas tank, where the gas tube fits into it.
"top of the gas tank where the gas tube fits into the tank"
I assume you're describing the gas tank cap. if so, the o-ring is missing from the gas tank cap. You can find those at hardware stores.
May 29, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite yard broom
I have lost my book on the homelite yard broom. can you tell me the ratio of gas and oil?
Aug 31, 2008 | Garden
Homelite 'Yard Broom' Leaf Blower Logo
2,286 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
