Question about Mitsubishi WS-55809 55" Rear Projection Television
Burned CRT Is it worth it to replace a burned CRT? How do I know which one is bad? What should it cost to get it fixed? Is it something I could do myself- I'm a marine mechanic but little elecronics knowledge?
  • teescrevo May 15, 2009
    The tv powers on fine. There are no missing colors. It won't get bright- I have to watch it in a dark room- and there are lines and numbers that seem to be burned in place. Also, there is red foggy stuff on half the screen. Part of the screen is unaffected and works fine. Could it be convergence?
2 Suggested Answers
  • 2336 Answers
SOURCE: my mitsubishi CS-35405
This condition can be easily fix by replacing and IC that is the vertical amplifier.
The number is something like LA7835 or LA7836, this IC is mounted on a heatsink.
Do a search in google for it.
Posted on Mar 01, 2008
My tv has a black screen over picture can i replace picture tube myself
That tv has no tube, and if the screen is bad it will cost more for a new screen than the whole tv cost. Yes you can replace it but it's not worth it, I would have someone look at it as it might just be an inverter problem.
Feb 19, 2015 | Televison & Video
CRT TV with only a horizontal line through the center of screen.
Yeah. Unfortunately you are right. It is normally the ic that controlls power to the gun. And it is expensive.
Your only chance is to find another model of the same TV that some is ready to trash or throw away at low cost and that TV having some other defect. Advertise in the local newspaper or other channels. It is worth a shot.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 23, 2010 | Sanyo Televison & Video
The tv circuitboard has a 1\8 inch hole in it
The board it self is probably toast but if the set is a newer model and expensive then it might be worth fixing with a new board. My rule of thumb is not to spend more then 50% of the replacement cost to repair. Try and get a rough estimate for free and decide if it is worth it. Good Luck
Jul 24, 2009 | Televison & Video
Samsung 56"TV lamp burned out
The lamp replacement is a do it yourself fix.
Feb 24, 2009 | Samsung DLP HL-P5663W 56" TV
Sony kdf-42we655 4 blinking red flashes
This is a problem on the primary power supply board. Cost is around $300 for parts, plus installation
Jan 19, 2009 | Sony KV-36XBR400 36" TV
My mitsubishi CS-35405
Mar 01, 2008 | Mitsubishi CS-35405 TV
Screen
crt burn is common among projection tube tvs. crt burn is just that a burn in the phosper of the crt.. I know of only one solution for this. replacement of the burnt crts. tubes cost on average 250 apeaice and there are 3 then the labor... ussally the cost to do this exceds the value of set. these sets are around 800 to buy new.
Jan 17, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Rca..model f38310
My set just recently went throgh the same problem. I found a bad connection on the power board and a burned diode as well. I repaired the conneciton but have had no luck getting the specs on the burned diode. RCA has been no help.
As for cost of repair, on serviceman quoted $50 just to come take a look.
Dec 09, 2007 | RCA F38310 38" TV
TV Flickers red lines across tv screen
Sounds like you have an intermitant overdrive situation on the red CRT. This could be caused by a bad component on the Red CRT board, an intermittantly shorting CRT or the circuitry in the main board. You should not run it until the problem is resolved as you could damage the CRT if it is not already bad. This is something that unless you are a qualified tech you are not going to have any success resolving. It should not be very hard for a good tech to diagnose the problem. Costs will depend on the part which is bad. If it is the red CRT it probably is not worth fixing, but it could be a 50 cent capacitor. Certainly worth the cost of a service call. Good luck.
Jun 29, 2006 | Samsung HCL4715W 47" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
69 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
