Question about Philips DVDR 3355 DVD Recorder
Displaying Blocked even after taking out the DVD disk.
The problem happens on the DVDR3355 after an unsuccessful programmed recording. Noticing it was not recording I pressed the record button, then a "Blocked" message appears. I managed to take the blank DVD out using the plastic lever underneath. But... now when I switch on the DVDR the after the "Startup" message the "Blocked" displays again. I tried switching on and off but it did not work. The firmware was updated in January 2007 to version BT5_6, Drive 43.03.11.
  • vhcasanova May 13, 2009
    Thanks Masteria but I knew about that releasing door plastic lever a year ago when I had to take a DVD disk out. I already tried the suggestion that appears in the FixYa site. It did not work. And I do not think it is a cleaning problem.
    The problem seems different, on the TV screen the 'loading' or 'dots' symbol appears continuously with the display showing first 'Startup' and the 'Blocked'. Pressing by chance the 'record button', a short duration message appears saying 'door open' even being it closed without a disk. It should say 'no disk' as usual. It seems that a disk sensor could be faulty or maybe the plastic lever must be in certain position.
    The DVD recorder is between a set top box (Satellite TV decoder) and the TV set. I am able to watch TV, the DVDR remote control works changing the record source, etc.
  • 355 Answers
First, make sure the DVD Recorder is completely disconnected from the main power supply.
Turn it over and look at the base of the unit, (just underneath the front of the Disc Insert/Eject Tray). There is a small slot (approx 25mm x 8mm) in which you can see a small, white plastic lever, probably situated near the right-hand side of the slot.
Moved this white lever gently to the left, and the tray should open by itself.
Remove the disc, and the recorder will no longer be blocked.
Posted on May 13, 2009
  • Rohit  Asthana
    Rohit Asthana May 13, 2009
    or you can try this one
    I eventually managed to get the drawer
    open after continuously trying the open/close button. Once it was
    opened, I gave the drawer a good clean and used compressed air to blow
    out any debris/dust inside. I inserted a disc and worked it open/closed
    a few times. I still get a blocked message when there is no disc
    inserted, so I leave a disc in at all times and every couple of days I
    work the drawer open/closed a couple of times.
  • Rohit  Asthana
    well vhcasanova
    After investigate your problem... I found this issue is related to your faulty lense of DVD... If this DVD is in warrenty period you can change the lense of this DVD....Or you can try a look into ur problem in here(www.scribd.com/doc/4741793/PHILIPS-L04 - 740k )...actually I am in hurry ...So need to go ..will solve ur problem after some time..
    thanks for your patience.
The disc is block inside
Try unplugging and when you plug in again press stop at the same time.
Feb 25, 2010 | Philips DVDR 3355 DVD Recorder
I have a dvdr3355.It has a rewritable dvd in it thatI have been using and has recorded programmes on it.I am trying to remove it but the window just says blocked and I cannot find a way to release it.Could...
If you cannot get the disk to eject, power the device off and insert a paper-clip into the emergency-eject hole in the front of the device. It should be located just under the disk tray.
Feb 27, 2008 | Televison & Video
Need A Users Manuel For My Dvd Recorder DVDR3355/37
To view your owner's manual in PDF format, click here: DVDR3355/37
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks.
Feb 06, 2010 | Audio Players & Recorders
Recently, i;ve been trying to record tv programs on my Panasonic DVD Video Recorder DMR-E50, as i have done so for many years. However, lately, whenever i program it to record a tv program using the timer...
Hi Leah,
Good description and good job in narrowing down the problem. The lens is the remaining common denominator.
You need to get a CD/DVD lens cleaner. It should have a disk and a bottle of cleaning solution. They are available in the electronics dept of most chain stores.
A couple drops of cleaning solution on the feathery cleaning element attached to the disk, insert the disk into the machine and hit play. Takes just a couple seconds.
Best regards
Mike
Aug 17, 2009 | Panasonic DMR-E50 DVD Recorder
DVD recorder continually stuck on a loop trying to read disk.
Hi again
I am so pleased to hear that you have restored the DMR E55 and for taking the trouble to let me know. It's always satisfying to achieve something like that and I guess you'll get even more pleasure from using it now than you did before. They are good machines and well worth the effort to keep them going.
Thanks again and kind regards
Dec 28, 2008 | Panasonic DMR-E55 DVD Recorder
Only reads some disks.
Hi, if the PC's are older than 3 years or the cdrom drives are near it's end of life, it will make problems to read some CDR's. If you recorded the CD's you are trying to read, try recording at less than 4X speed.
Sometimes, even "original" or "silver" CD's will make problems because they are not recorded correctly at the factory.
If the problem is with a CDRW drive, it applies the same theory, the recording laser is damaged or used up. It will not record a legible CD or DVD even if the software says that the record operation ended successfully.
Feb 09, 2008 | HP Pavilion dv6000z Notebook
Playback of recorded programs
try formatting the disc. it will erase everything on the disc and you can start fresh. try this with all the discs.if the problem keeps happening, try new discs.
wg
Feb 03, 2008 | Panasonic DMR-ES20EG DVD Recorder
D-KR2 writes bad disks
you are having problem with your lens and the microchip.you will need to replace them soon. the malfunction is a warning that a repair will have to take place.the problem is intermittent at this time.soon you will have no function.good luck
Jun 08, 2007 | Toshiba DRW2 DVD Recorder
Programming errors
Several things to check 1) Your time - set it manually and remove the automatic time set 2) Try manually recording even a few min of anything (just put on channel to record, press DVD button and DVD Record button) - does it give you an error message on that disk? If so it might be because you are using 16x and machine sometimes gets messed up and won't record on those speed disks - same with +R sometimes does this - try recording on 8x -R ones. Hopefully this helps - if not try unplugging unit from wallsocket and leave off about 30min then try setting program again etc (plus current local time) and use a new disk and see if problem still occurs - sometimes just unplugging it "resets" everything and then starts working again.
Jan 28, 2007 | Emerson EWR20V4 DVD Recorder/VCR
JVC DR-M100S
I have a JVC DR-MH50 DVD/HD recorder and it will only record on DVD-R or DVD-RW not DVD+R or +RW. so check your format of disk you are trying to record on it may be as simple as that.
Sep 04, 2006 | JVC DR-M100S
Philips DVDR 3355 DVD Recorder Logo
318 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
