Question about Whirlpool ET8WWKXK Top Freezer Refrigerator
Water leaking from top mount freezer
I have a Kenmore refrigerator
Model T21NKXGW02
Serial EJ5115964
Type CZ1TFA99
made 12-99
It has been leaking water from the freezer which is top mount into the rear of the refrigerator and running down in to the crisper area, I have the controls set at mid range I have tried going warmer or cooler but nothing seems to help no mater what. What can I do a bout this cause the refrigerator still works great?
  • josh_bebeau May 13, 2009
    How hard is it to complete such a task, would I be better off hiring a repair man and roughly how much do you thik that would cost
    President:
  • 1,136 Answers
Hi, This is very common for this brand. UNPLUG the refrigerator. You need to remove the bottom and rear panel in the freezer. You should see an ice build up. remove the ice with a hair dryer preferred. Then with warm/hot water, remove the ice built up in the drain hole located below the evaporator coils. You will need to put on an after market drain heat transfer strip kit to keep tjis from reaccuring. I can get the part# for you if this what you find wrong. Please let me knwo if I can assist you fyrther.
Thanks
Vic
Posted on May 13, 2009
  • Victor
    Victor May 13, 2009
    It is very easy. Take you about 45 minutes. Once you get it all cleaned out, the kit comes with instructions. The transfer strip wraps around the defrost heater and has one screw to hold it in place. All you need is a 1/4" nut driver or socket, and flat blade to help losen some of the ice. Really, it is fairly simple.
    I wil help you through it as much as possible.
    Vic
Ireland
Hey friend, thank you for the post!
From my understanding you have water leaking out of the freezer of your Frigidaire refrigerator and onto the floor. I would like to ask you a couple of additional questions. First, do you see where the water is coming from? Secondly, what is the model number of your appliance? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side in a top mount. But on a side by side it can be found on the right hand side. I look forward to hearing back from you. -Matt
Jul 17, 2014 | Frigidaire 20.6 cu. ft. Top Freezer...
Water leaking inside the vegetable drawer
What is your model number? Also what year, series etc.
Apr 30, 2014 | Kenmore 20.6 cu. ft. Top Freezer...
Leaking water inside of refrigerator. Ice maker is off and disconnected from water supply. Seals around doors look fine and seem to close tight, no signs of cracking. No cracks in interior of...
Hello Rick,
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 27, 2011 | Kenmore 21.7 cu. ft. Top Mount...
Water is leaking into teferagerator, seemingly from the freezer compartment. It is a Kenmore Coldspot model 106.72132101 type 21 TFA.
Good luck
I hope this helps
Gene
Aug 01, 2011 | Kenmore 61282 / 61284 / 61289 Top Freezer...
KENMORE ELITE TOP MOUNT #2218591. I have to keep 2 bowls in the back of the refrigerator on the top shelf beacause water is leaking from somewhere. It has an ice maker. Could that be the problem?
this is a a frozen drain . kenmore has a drain heater kit the will correct the problem .. very common with top mount freezers .. .. hope this helps mmm feed back pls /
Jul 09, 2011 | Kenmore Refrigerators
Kenmore Trio Bottom mount Freezer - water inlet
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} PARTS
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
http://www.appliancepartspros.com/partsearch/
http://appliancejunk.com/forums/
model number
Your model number is needed for more information.
It's usually stamped on a small tag in a visible location on your appliance.
http://www.appliancepartspros.com/modelnumber_locator.aspx
Jan 26, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore top freezer leaking water on the inside when defrosting
MAKE SURE THE FAN IN REAR OF FREEZER COMPARTMENT IS RUNNING , SOME TIME YOU MUST DEPRESS THE DOOR SWITCH ON THE FREEZER DOOR TO WATCH FAN IF NOT REPLACE FAN , NOT BAD MOST UNPLUG , IF THIS IS NOT IT YOU COULD HAVE A INTERMITTENT DEFROST TIMER OR A BAD DEFROST HEATER
Feb 24, 2009 | Kenmore 18.9 cu. ft. Top Mount...
Water leaking into the refrigerator from the freezer.
you have to defrost the freezer part and drain tube in the freezer,a hair dryer works well,if after you defrost it and freezes again its your defrost timer,make sure its fully defrosted first before buying the defrost timer
Jul 07, 2008 | Kenmore Refrigerators
Defroster leaks
you have a cloged evap. drain. the rf is defrosting properly but with the drain be clogged the water has to go somewhere which is generally in the crisper draws on top and bottom models. two way to clear up this issue. turn rf OFF for at least 48 to 72 hrs. to allow the drain to de-ice or take matters into your own hands and take the back panel off of the freezer and using boiling hot water pour it down the evap. drain tube until it flows like you just flushed a tiolet
Jun 01, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Whirlpool ET8WWKXK Top Freezer Refrigerator Logo
110 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
