Hisense 55inch 4k tv android
If your Hisense 55-inch 4K TV with Android is turning off randomly, and you have found that the power supply board is wet, it is likely that the issue is caused by a problem with the power supply. Replacing the power supply board may resolve the problem, but it's important to consider the following before making a decision:
Safety: If the power supply board is wet, there is a risk of electrical shock, so it is important to make sure that the TV is unplugged and that you take appropriate safety precautions before handling the power supply board.Root cause: The problem could be due to a leak or another issue that caused water damage to the power supply board. If the root cause of the water damage is not addressed, the new power supply board may also be damaged.Difficulty: Replacing the power supply board can be a difficult task, and it requires some technical knowledge and the right tools. It's important to make sure that you are comfortable with the task and that you have the necessary tools before attempting to replace the power supply board.Cost: replacing the power supply board may not be a cheap solution, and it may be more cost-effective to consider a new TV.It's important to have a professional technician to check the TV and confirm if the power supply board is the issue and if it needs to be replaced.
If you're not comfortable with the task of replacing the power supply board, it's best to contact Hisense support for further assistance or have a professional technician to check the TV.
