Question about Kenwood KDC-322 CD Player
Blows Fuses When I press the SRC button, it blows the ignition illumination fuse; the battery fuse remains OK.
    Sniper:
  • 61 Answers
You should check ignition live to see if wired correctly. sounds like its getting a earth somewhere.
Posted on May 15, 2009
I have a 2003 Suzuki Volusia that blows the 15 amp ignition fuse randomly.Can go weeks without a problem then it will blow. I replace it and it is fine or other times it blows repeatedly.
Wendy, Check the starters wiring circuit for a pinched/bare/damaged wire. Check the attached links,instruction and guides,good info. to trouble shoot your problem. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Electrical troubleshooting and maintenance for the VL800 Suzuki Volusia...
keep blowing fuses Fixed
Blowing ignition fuse
Faulty Ignition Switch 2003 Volusia Suzuki
Jun 24, 2016 | 2003 Suzuki VL 800 Volusia
2005 Honda VTX 1300 R keeps blowing tail light fuse
Hi, Anonymous before diagnosing your blown fuse issue, check the bottom of your seat, if it's metal and comes in close proximity to the positive battery post you need to take the necessary steps to ensure there is no contact (electrical tape, thick rubber insulation, hammer a dent in the seat bottom etc.) You are going to need a wiring diagram from your service manual, a test light, an ohmmeter and plenty of extra fuses.
If you turn on your ignition switch and immediately blow a fuse you have a hard/dead short and is usually easy to find. With a test light connected to the hot side of the blown fuse holder start stabbing the wire/s that leads away from the fuse holder and towards the ignition switch, you test light will illuminate validating the short. When the test light fails to illuminate you have passed the short and need to back up until the test light illuminates, then look in the immediate area for the short.
If you driving down the road for 30 minutes or 15 miles and blow a fuse you have soft/flying short and may take some time and patience to find.
If the main fuse/circuit breaker constantly blows/trips while riding you probably have a faulty battery terminal connection. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary. Any other fuses that constantly keep blowing while riding are usually caused by a loose or corroded ground wire in the circuit, which means you have to check, inspect, test each and everyone with an ohm meter set on a low ohm scale 100 ohms or less . Simply touch one lead to the ground source and the other lead to the battery negative terminal, a reading of zero indicates a clean solid ground. Any number reading or infinity indicates a poor ground and needs to be repaired. Poor or weak grounds require excessive additional amperage to complete the circuit which in turn blows the small amperage fuse.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Speedo Tail Light fuse keeps blowing Any ideas
tail light and instrument cluster fuse keeps blowing Honda Tech Honda...
Honda VTX1300S Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VTX1300C VTX 2004 Owner Manual
Jul 05, 2014 | 2005 Honda VTX 1300 R
2005 Triumph Daytona 650 blowing ignition fuse
Hi, Mani before diagnosing your blown fuse issue, check the bottom of your seat, if its metal and comes in close proximity to the positive battery post you need to take the necessary steps to ensure there is no contact (electrical tape, thick rubber insulation, hammer a dent in the seat bottom etc.) You are going to need a wiring diagram from your service manual, a test light, an ohmmeter and plenty of extra fuses.
Fuse 7 Blows When Ignition is Turned On
ignition fuse keeps blowing popping 06 triumph 675 BAR Bay Area Riders...
Triumph Daytona 1997 2005 Repair Manuals
https://www.bikebandit.com/oem-parts/2005-triumph-daytona-600-650-sump/o/m17663sch569813
Triumph DAYTONA 650 Manual
Nov 25, 2017 | 2005 Triumph Daytona 650
2012 Kawasaki ZZR 1400 ABS fuse keeps blowing
Hi, Anonymous before diagnosing your blown fuse issue, check the bottom of your seat, if its metal and comes in close proximity to the positive battery post you need to take the necessary steps to ensure there is no contact (electrical tape, thick rubber insulation, hammer a dent in the seat bottom etc.) You are going to need a wiring diagram from your service manual, a test light, an ohmmeter and plenty of extra fuses.
Help fuse blows bike dies bad CDI
Kawasaki ZZR1400 ABS Service Manual
OEM Parts for Kawasaki
Kawasaki ZZR1400 Owner Manual
Apr 24, 2014 | 2011 kawasaki ZZR 1400
Error code 46
Hi, Anonymous before diagnosing your blown fuse issue check the bottom of your seat if it's metal and comes in close proximity to the positive battery post you need to take the necessary steps to ensure there is no contact (electrical tape, thick rubber insulation, hammer a dent in the seat bottom etc.) also you are going to need a wiring from your service manual a test light, an ohmmeter and plenty of extra fuses. If you turn on your ignition switch and immediately blow a fuse you have a hard/dead short and is usually easy to find. With a test light connected to the hot side of the blown fuse holder start stabbing the wire/s that leads away from the fuse holder and towards the ignition switch, you test light will illuminate validating the short. When the test light fails to illuminate you have passed the short and need to back up until the test light illuminates, then look in the immediate area for the short.
If the main fuse/circuit breaker constantly blows/trips while riding you probably have a faulty battery terminal connection. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary. Any other fuses that constantly keep blowing while riding are usually caused by a loose or corroded ground wire in the circuit, which means you have to check, inspect, test each and everyone with and ohm meter set on a low ohm scale 100 ohms or less . Simply touch one lead to the ground source and the other lead to the battery negative terminal, a reading of zero indicates a clean solid ground. Any number reading or infinity indicates a poor ground and needs to be repaired. Poor or weak grounds require excessive additional amperage to complete the circuit which in turn blows the small amperage fuse. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
R6 fault Code 46
http://www.r6messagenet.com/forums/r6-maintenance-technical/71620-help-keep-blowing-ignition-fuse.html
2003 2004 Yamaha YZF R6 Service Manual R6 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Mar 27, 2014 | 2004 Yamaha YZF-R6
2003 Kawasaki VN 1500 Vulcan Classic keeps blowing the ignition fuse
Ignition fuse keeps blowing
VN1500 keeps on blowing fuse
Kawasaki VN1500 MEAN STREAK Service Manual
2003 Kawasaki Vulcan 1500 Classic Owner Manual
Sep 15, 2013 | 2003 kawasaki VN 1500 Vulcan Classic
Hi, Sky before diagnosing your blown fuse issue you are going to need a wiring from your service manual a test light, an ohmmeter and plenty of extra fuses. If you turn on your ignition switch and immediately blow a fuse you have a hard/dead short and is usually easy to find. With a test light connected to the hot side of the blown fuse holder start stabbing the wire/s that leads away from the fuse holder and towards the ignition switch, you test light will illuminate validating the short. When the test light fails to illuminate you have passed the short and need to back up until the test light illuminates, then look in the immediate area for the short.
Re Ignition fuse keeps blowing Road Star Forum Yamaha Road Star
Ignition fuse blows PLEASE HELP
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Jun 17, 2012 | 2005 Yamaha V Star 1100 Classic
Yamaha neos blows main fuse
If the main fuse/circuit breaker constantly blows/trips while riding you probably have a faulty battery terminal connection. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary. Any other fuses that constantly keep blowing while riding are usually caused by a loose or corroded ground wire in the circuit, which means you have to check, inspect, test each and everyone with and ohm meter set on a low ohm scale 100 ohms or less . Simply touch one lead to the ground source and the other lead to the battery negative terminal, a reading of zero indicates a clean solid ground. Any number reading or infinity indicates a poor ground and needs to be repaired. Poor or weak grounds require excessive additional amperage to complete the circuit which in turn blows the small amperage fuse. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
blowing Ignition fuses
Why is my bike blowing its main fuse
https://scootergrisen.dk/scooterhjemmeside/download/yamaha_neos_2t_servicemanual_2.pdf
Yamaha Owner Manuals
Jun 10, 2012 | 2010 Yamaha Neos
I got a 2005 XT660X Motard style. My 10amp fuse, labelled EFI, keeps blowing when I hit the start button. Replaced the 'Rec Def' as someone else recommended and it ran good for a day. Now...
Hi, Carpejugulum before diagnosing your blown fuse issue check the bottom of your seat if it's metal and comes in close proximity to the positive battery post you need to take the necessary steps to ensure there is no contact (electrical tape, thick rubber insulation, hammer a dent in the seat bottom etc.) also you are going to need a wiring diagram from your service manual a test light, an ohmmeter and plenty of extra fuses. If you turn on your ignition switch and immediately blow a fuse you have a hard/dead short and is usually easy to find. With a test light connected to the hot side of the blown fuse holder start stabbing the wire/s that leads away from the fuse holder and towards the ignition switch, you test light will illuminate validating the short. When the test light fails to illuminate you have passed the short and need to back up until the test light illuminates, then look in the immediate area for the short.
keeps blowing fuses
Blown Ignition Fuse
YAMAHA XT660R Service Manual
Yamaha XT660R Owner Manual
Sep 15, 2011 | 2005 Yamaha XT 660 X
20 AMP FUSE BLOWS WHEN IGNITION IS SWITCHED ON IGNITION SWITCH TESTED AND OK
something connected too ignition sdwitch has short to ground. remove all fuses except 20amp that blows turn on ignition see if blows. if not replace one by one till it does to isolate circuit. which fuse is blowing and where is it located.
woodysmechan kiesha76@hotmail.com
Mar 10, 2011 | 1999 Suzuki Vitara
Kenwood KDC-322 CD Player Logo
54 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
