Question about Samsung ML 2010 Laser Printer
On Line Error
Hi there.  A paper jam made my printer's red "on line/error" button go on, and I am pretty sure I cleared every stuck piece of paper. However, when I turn the printer on, it sounds for a second like it might work, but then it makes a sad little "rrr" and the "on line/error" button goes on again.  I don't know what to do!  Can you advise me?
Thanks,
Troubled in Louisville
  • Anonymous Dec 06, 2007
    I have a Samsung ML-2010. I was trying to print today and my paper stopped even before going far into the printer. I was able to get it out completely clean without a tear. (Nothing stuck inside). I received paper jam error. I opened the door and pulled out the toner cartridge and closed the door back. Then I received a error message of install toner cartridge. I repeated. Now, the red light "On Line Error" is on. I have turned off the machine and even unplugged it. Nothing seems to clear the error.
    Suggestions?
  • 161 Answers
There are 2 possible reasons: (1) the piece of paper is stuck in the fuser unit, which cannot be reached without removing the back cover or (2) your toner cartridge is stuck. Take it out and force it manually by moving the green cylinder (the drum) on one the border gears. DO NOT touch the drum or you will make a permanent mark on it. If the printer works for a while an stops again, change the toner cartridge.
Posted on Oct 20, 2007
Printer show printer error occurred 5100 meaning what
Hi Hemalatha,
This error is a "Jam" error. Look for any objects / pieces of paper that is stuck in the paper feeders (front and back). Secondly there is a timing strip that gets dirty and could also cause this error. Cleaning it could solve this problem. Hereafter, press and hold the "Clear" button for 5 seconds or more to reset the error log.
Here is a tutorial on how to fix this error:
Here is a tutorial to clean the timing strip:
FIXED Canon Printer Error 5100
Dec 28, 2014 | Canon Office Equipment & Supplies
Hi, My printer had a paper Jam and I am pretty sure some paper got stuck however i cant find any when lifting the top up.It now wont work and the alarm light is flashing ThanksJemma
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred. Step2 Turn off the printer. Step3 Remove any paper trays. Inspect them for wrinkled or damaged paper. Step4 Open any other doors that give access to the printer's paper path and to the toner or ink cartridge. Step5 If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it. Step6 266_a1.jpg If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. Step7 266_a2.jpg If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything, though. Step8 Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. Step9 If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
If you still face the problem let me know..
Goodluck..
Jun 03, 2008 | Canon Office Equipment & Supplies
I have a Brother HL-2140 printer and I have a flashing error light. I'm pretty sure that it is the result of a misfed piece of paper but can't figure out how to remove it from where it is stuck. I can only...
Hi there !
Just press the printer off and turn it on to run the roller and eject the paper jammed inside. Just repeat the turning on and off the printer and it will come out for sure.
Good Luck.
Jan 25, 2011 | Office Equipment & Supplies
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Error paper output slot. the paper is jammed clear
Try this...With te printer off line, press the paper feed button making sure thre is paper in both feed trays. Once it print, a blank page go in and change back t your desired papper source. Hope that helps, please let me know.
Ash
Jan 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Samsung ml 2010 r laser printer
Check your manual, there is a solution there or download the user guide from
this site below or read the information below.
http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 17, 2008 | Samsung ML 2010 Laser Printer
Printer ML2010 not responding
On Line/Error LED
lights red
receiving data.
Jul 15, 2008 | Samsung ML 2010 Laser Printer
Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
Samsung ML 2010 Laser Printer Logo
259 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
