Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
Connecting my external 320 to my laptop but its just flashes
It is just flashes and not reading on my macbook
  • 19,396 Answers
Try a replacement USB cable first, and test the MyBook on a different computer, to ensure the fault is on the external storage unit.
There are two possibilities:
The Mybook USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. WD Mybooks are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be WD .
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
Posted on May 21, 2009
My Pleomax external hard drive stopped working on my MacBook (OS Maverick). It worked for one day and that was it. It flashes green and red when connected.
Probably not an issue with the MacBook but with the Pleomax drive. Be sure the drive is getting enough power to begin with. If it came with a 2 headed USB cable be sure to connect BOTH USB connectors to the Mac. You may also want to try the drive while your COMPUTER is plugged in and charging. Laptops and external drives don't always get along due to power differences and specifically laptops who do not want to waste their battery power on an external drive. If all else fails, try the drive on another computer just to make sure it is a drive problem and then contact the manufacturer for a repalcement drive.
Dec 11, 2013 | Samsung Pleomax 120GB External - USB 2.0,...
Want to format my seagate freeagent go 320 gb external hard drive to a macbook laptop want it to be compatiable to the mac?
Format the external hard drive to a exFAT (OSX snow leopard or later), or FAT32 (all versions of OSX). It can be read and written for both mac and windows.
Nov 02, 2012 | Computers & Internet
Hello, my macbook moise will not let me click anything. I am able to move the mouse anywhere on the screen but when I go to click it will not let me press on anything. I was wondering what the cause of...
An external mouse will work fine just plug it into one of the usb ports and you should be up and running. If your macbook is still under warranty take it into the apple store and they should replace the trackpad without too much fuss.
According to what I have read this happens quite a lot on some models of macbooks.
If it is out of warranty someone made the following comment on one of the websites I looked at "Simply push ******* the trackpad and apply pressure across the whole surface." But I would recommend not to push too hard as you could totally damage the macbook.
There is a video on youtube at http://www.youtube.com/watch?v=IuYO0I-DY84&feature=results_video&playnext=1&list=PL0437205F5525C959 which shows you how to repair a trackpad
Hope one of these suggestions help you.
Sep 06, 2011 | Apple aluminum 13-inch MacBook laptop-...
I have a Hitachi Simple Drive Mini x 320 GB that I've been using as an external for my macbook pro. I have been using it without problems for over a month now, but last week it didn't eject properly from...
does the usb cable you are using have 2 usb plugs so you can plug it into 2 usb ports at the same time.
If not, you could try using one, sometimes my external HD will not work on some pc's if i just plug it into 1 port
Sep 10, 2010 | Hitachi 120GB Hi-Speed Mobile Disk USB 2.0...
External Disk WD Elements problem
did u format the wd 320 gb already
you have to format it first to work from it
Apr 06, 2010 | Western Digital Elements powered by WD 320...
Macbook pro will not read dvds
If it reads CDs but not DVDs, the optical drive is faulty. You can get it replaced by an Apple tech, or you can invest in an external optical drive.
Mar 31, 2010 | Apple MacBook Pro Laptop Computer with...
Can't read/write to the drive. Two Flashing lights
is there any knocking from the drive , please hear it and hold yourself very close to hear a regular or iregular clicking sound
most likely
1) head crash head zeo and one
2) firmware cannot be remapped on head
30 SPINDLE IC TOO HOT.(LOCATED ON THE PCB.
IT IS NOT A MBR PROBLEM nor a lost partition problem precisely
Sep 17, 2009 | Western Digital Elements powered by WD 320...
I have just hooked up an external monitor (LG Flatron) to my macbook--no problem with web pages, but I am unable to see my desktop or any word files. When I boot up, it says analog in the upper right...
  1. When you connect an external monitor to your MacBook (or PowerBook, for that matter), you can combine your MacBook's LCD and your external monitor to create one big monitor. That means when your mouse pointer goes off the edge of one, it will appear on the other. Open the Displays Preference Pane to configure the resolution and orientation of the two monitors. This type of configuration works well when you want to keep your main work on your larger external display, but still keep things like IM, iTunes, and email constantly visible on the smaller laptop LCD.
  2. Some windows act like they don't want to be dragged on to your external monitor. If a windows is being stubborn, try dragging it up to the menu bar, and keep dragging, even if stays stuck below the menu bar. Sometimes once you have dragged it far enough that it has room to render the entire window, it will jump to the other monitor (Terminal used to have this problem, but Apple fixed it some time ago). If that doesn't work, try dragging it from a corner of your monitor. My Adium contact list doesn't seem to want to live on my external monitor, but I can coerce it up there by dragging up from either corner.
  3. When your laptop is open, you can't switch to using the full resolution of an external monitor. I have no idea why, but it's a fact of life for MacBook users. You can use both displays in "extended" mode, or you can mirror your MacBook's display (which most likely doesn't use the full resolution of your external monitor), but you can't switch to using only the external monitor. Very strange.
  4. If you close your laptop, you can actually get the full resolution of your external display. Put your MacBook to sleep, connect your external display and an external monitor, and wake the computer up by pressing any key. You will have full use of your external display while your laptop is closed.
  5. If you really want to have your MacBook open while only using an external display, after following the procedure above, you can open your MacBook, and it's screen will remain off, which means you can still use the MacBook's keyboard and trackpad. Why you can't get into this mode using F7, I have no idea. This is a good technique for allowing some heat to dissipate while still using an external display so the lid of your MacBook doesn't melt or warp.
  6. You can boot your computer using just an external display. Just connect your external display, open the lid, hit the power button, and close the lid again immediately.
  7. In order to output only to an external monitor, you have to have the power cable connected. I tried for several minutes yesterday to get my MacBook to wake up with an external keyboard and monitor before unpacking my AC adapter from my backpack, and it wouldn't work. It took me a while to make the connection (no pun intended), but I eventually discovered that with the power cable attached, everything works as expected.
Aug 05, 2009 | Apple Refurbished MacBook 2.4GHz Intel...
Using a MacBook as an external HD
Try reading here: Apple
Even though the article refers to Leopard, it should work for Tiger.
Here is the catch: The iMac needs a FireWire port
Mar 26, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
No screen activity on startup
hi wa_flyboy,
I suggest you first do a test to determine if it is your macbook's screen or graphics processor which is at fault. To do this you need to connect an external display to your macbook.
The macbook has a mini-DVI port for connection to external displays. Depending on the connector of the external display you use to do the test, you are either going to need a mini-DVI to DVI adapter (for a DVI display) or a mini-DVI to VGA adapter (for a VGA display). These adapters are sold separately by Apple, see http://store.apple.com/1-800-MY-APPLE/WebObjects/AppleStore.woa/wa/RSLID?nnmm=browse&mco=669DFFE0&node=home/shop_mac/mac_accessories/displays
If an image is displayed on the external display after you have connected it to your macbook, you know that the screen of your macbook is faulty. In this case it would be an economical option to take the macbook to a repair shop where a technician can determine the faulty component (either one of the following display components of a TFT LCD screen can fail over time; the inverter, the backlight or the cabling). These can be replaced under warranty or they can order new ones if the warranty has expired.
If the external display shows the same symptoms as your macbook's display, it is the macbook's graphics processor which is at fault. I'm sorry to inform you that I think this is the cause of your macbook's display problem. Replacing the graphics processor of your macbook entails replacing the motherboard.
If the macbook is still under warranty I suggest you replace it and let technicians migrate your data from your current macbook's hard disk to your new one.
If the warranty of your macbook has expired, it's a more economical option to buy a new one and migrate your data to the new macbook. This will only cost a few dollars more than the cost of replacing the faulty motherboard (including the service costs of the repair shop to which you take your macbook), but is still more economical seeing as how you get a new machine which has a full warranty.
I hope this is helpful information and thanks for using the FixYa services
Kind Regards
Feb 13, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
277 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
