Question about GE JE2160 Microwave Oven
He's Dead, Jim! Died when door opened, but Usual Suspects clear?
After a short cooking run with my 3year old je2160 bf03, when opened to stop cooking the unit died. After reading the standard responses here/elsewhere, I presumed one of the switches was defective and had blown the fuse. Power supply/other outlets are OK.
I opened the case, grounded the HV capacitor and removed the 20A ceramic fuse (blown - infinite resistance per ohmeter to the fuse).
I checked all three switches (alignment/latch function correct), pulled all three (look good - the upper and lower ones #1445, 1446 show full resistance when open, none when switch button pushed closed; the center switch #2010 shows no resistance when open, full resistance hen switch button pushed closed).
Now I'm stuck...
  • 1 more comment
  • lspooz May 13, 2009
    D'Oh!!!!
    The simple solution was overlooked - all the switches and power relay checked out, but I did notice a little looseness at the lower end of the assembly when I took it apart - sure enough, JUST replacing the fuse AND retightening fixed it.... YES.
    Thanks for the advice!!
  • William Miller
    William Miller May 11, 2010
    On the two upper & lower switches, a reading between the common (C) and normally open (NO) terminals should read infinite resistance when the switch is not activated (door open) and zero ohms when the switches are activated (door closed).
    The middle switch's terminals are common (C) and normally closed (NC) and they will read just the opposite when compared to the upper and lower switches..
    Is that what you're getting?
    If so, then you may still have a timing issue when you open or close the door OR one of the switches may be sticking.
    See
    http://www.microwavedisplay.com/doorsw.t...
    Door switch
    or mount trouble is usually caused by slamming the door or by opening
    the
    door while it's cooking without hitting the Stop pad first.
    Let us know how it goes.
  • Jerry Naidoo May 11, 2010
    Did you replace fuse and try again ?
  • GE Master
  • 9,047 Answers
Posted on May 14, 2009
I have a GE model JE2160SF03 1.65 KW. It has no power, I have checked recepticle it has power. No didital display, nothing comes on.
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARRAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 04, 2011 | GE JE2160 Microwave Oven
Microwave runs but doesnt heat
Runs ?? I guess you mean the light comes on and it rotates ??
Make sure its is on high cook mode ( in case someone has it on defrost etc) Try it with a half glass of water - if it does not boil, chances are your microwave unit inside the case has died - not uncommon fault and not worth getting fixed as the replacement part + labor is more than the cost of buying a new one.
Nov 07, 2009 | GE JE2160 Microwave Oven
Model R-1460, when I shut the door it runs but doesn't heat up. What needs to be done to fix it?
Do you mean that when you close the door, the fan comes on? If so, it sounds like a bad door switch. Probably the secondary interlock switch.
This failure is caused by opening the door when the unit is in cook mode. On ALL microwaves, not just one or two brands.......
Be sure to push the stop button before opening the door to add or stir... Or wait for the cook cycle to end. (This is why microwaves have a two step function on the stop/clear button. Hit stop once to stop cook mode and twice to reset timer).
You should use an ohm meter to check all 3 switches. The switch can be either stuck 'closed' or physically closed but not 'making' electrically.
Sep 13, 2009 | Sharp Microwave Ovens
MW8119SB cooks when door is closed regardless of settings
Clear the cook cycle when you remove the food. Some microwaves pick up where they left off, so you don't have to keep pressing buttons.
Aug 07, 2009 | Emerson MW8778 Microwave Oven
GE JVM240 microwave - shut door, fan runs,can't set timer or cook
The "main" relay on the control circuit board is stuck (shorted) and needs to be replaced.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Dec 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Magnetron cooling fan
Are you sure it is the internal blower and not the VENT fan ?
Aug 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Oven JE2160
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 22, 2008 | GE JE2160 Microwave Oven
Sunbeam SMW5500 micro/convection oven shorted out when opening door
You are decribing a typical Door Safety Switch problem. The Door Safety Switches has Failed.The Door Safety Switch is designed to shut down the Micro in the event the Micro is still cooking when the door is being opened. The first "Click" of the switch cuts off the "Cook". If it does not cut off the "Cook", the second "Click" blows the power. Otherwise it would "Cook" with the door open, and I need not to tell you how DANGEROUS that could be. It first Tripped the Circuit Breaker which supplies power to the Microwave. After Re-Setting the Breaker the same thing happened except this time the Micro is DEAD- not even a light working. Yes, there is a line FUSE inside the Micro. You however need to address the Door Switch SHORT before replacing the fuse. If not, it will just Blow The Fuse Again, and Again, until the Short is corrected.
Call around, ask How much to replace a Door Safety Switch.
Good Luck!
Feb 15, 2008 | Microwave Ovens
GE JE2160 Microwave Oven Logo
347 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
