Question about Garden
Runs but will not go
I have a 25hp 48" cut craftsman lawn tractor. while mowing today, started smoking real bad between bottom of tractor and top od mowing deck. I stopped blades and cleaned out grass on top of deck. started bac up and drive belt came off, now it will not run forward or reverse. Makes a grinding noise when pressing down the pedal to run. Appreiciate any response to repair or what it might be. thanks Brooks
  • gimmeamassag May 16, 2009
    i have the same problem, but no grinding. got off the mower to empty bags and when i got back on it would not go forward or back. everything else seems fine. it did smoke a bit when i went forward, but doesn't now. cheryl
  • 246 Answers
Hello brookspiercy:
From your Description it Sounds like a New Belt is Required and Possibly a New Clutch Idler Arm or Idler Pulley. The Grinding Sound like it May be the Bearings of the Clutch Idler Pulley.
>>For Better Assistance,
>>Send me the Model Numbers Off the Mower, Please. With these I can Locate the Proper Manual and Better Assist you. The Model Numbers are Usually Located Under the Seat on a Sticker or Tag on the Body.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
Craftsman tractor 917.273241 25hp Kohler, 48" cut. The clutch return spring will not hold tension more than a few hours of cutting. The temper in the spring end near the exhaust pipe from the engine to...
I'd be tempted to shield the spring from the heat of the exhaust - is there any way to pop rivet on a piece of aluminium sheet and bend it to not impede the operation of the clutch?
Aug 08, 2013 | Craftsman Garden
Throttle adjustment on lawn tractor
look at the bottom of the bowl on the carb, on the newer mowers, companies have installed a thing called the "fuel shut of solenoid" and on the end of it..there's either a short rod that comes to a point..or it could be perfectly round and flat, unscrew the solenoid and try cutting the tip of that rod off a little bit. and screw the solenoid back in. that should solve your problem. those solenoids aren't really needed, they were just put on to help stop the engines from backfiring. and when they go bad, problems like yours happen. it happened to my lawn mower, one day it was running just fine, than the next day it wasnt wanting to start, and if it did..it'd sputter and die.
Jul 09, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna YTH2348 just quits while mowing...
check the coil on it,not a fuel problem if the coil gets hot it will shut down and when cool cranks back up,my dad is a lawnmower mechanic!!!
May 14, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
White smoke coming out of mower
It sounds as though you are losing power (electrical power); see if charging the battery fully allows it to run longer or if charging the battery helps.
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Runs 5 mins. and quits seems to be out of gas. cuts out until it
Sounds like you have a stuck float in the carburetor. Sometimes a piece of grit will get in there. You can remove the float bowel location bottom of carburetor , turn off fuel first or pinch line shut needle nose vise grips do a good job for this. First lightly tap the float and blow though fuel line. If it sat a long time might just be a little varnish from old fuel. If still can not blow though line remove float and if need replace needle and seat.
May 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My lawn tractor is losing power. its smoking black smoke and the smoke burns your eyes. its did it off n on the last few cuttings. today i had to stop mowing. it almost completely quite running.
First thing to do is change the oil. This should help but does sound like the mower is burning oil do to worn oil piston rings
Jul 10, 2009 | Garden
Husqvarna YTH1848XP Riding Mover stalls with throttle increase.
Check your Vacuum line going into the back of your air intake box.
Jul 06, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
128 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
