Question about Philips Magnavox 27MS343S 27" TV
Magnavox TV 25TS52 had power surge not working
The set popped and smelled burt after power surge, need to have a price for my set for insurance purpose and I have lost the paper work on it and when I purchased it. Any help would be appreciated.
Thank you
  • Philips Master
  • 1,212 Answers
If the fuse is burned you will have to change the horizontal output transistor. And replce the following caps. c411 16volt220mf, c42016volt220mf, c41850volt10mf, c555 50volt10mf c508 250volt 1mf {this one caused your tv to short} c525 50volt15mf, c312 25volt47mf. Now replace fuse. install board and it should come back on.
Posted on Jun 30, 2009
    President:
  • 814 Answers
You can call Magnavox customer support at this telephone number. 1-800-705-0000 Tell them the model number of your television and they will be able to help you. I hope this information helps you with your problem.
Posted on Jun 03, 2009
Stopped working after a storm
Did you have a power surge after a loss of power? If so your TV is ruined from the surge. In the future use a surge protector if don't already.
Aug 20, 2016 | Televison & Video
Two vizio TV's with issues
Take them to a TV repair centre as they are complex to repair. You may find that your homeowner insurance will pay for the repairs if you can demonstrate that it was a power surge that damage them.
Feb 29, 2016 | Vizio SV421XVT 42 in. LCD TV
TV hit by power surge. Will not come on. Started trying ( clicking) but then stopped. Cover off. Fuse is OK. No capacitors obviously burnt. What to check next
Contact your homeowners insurance because you need a new television. If this was from lightning then it is badly damaged. You are at least looking at a new control board and there are at least 3 of them and then you may need new power supply, main board and inverter.
Jul 06, 2015 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Buzzing tv after power surge
Get the estimate. When your insurance company sees it, believe me, they won't buck at replacing your TV _especially since the prices of TV's have come down over the years while the quality and resolution has skyrocketed. . .
Jul 28, 2017 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I have a older magnavox model 25ts52 the power in the house went off with the tv on 2hrs later when the power came back on the tv will not turn back on
90% chance if set is opened(follow power cord inside) the line fuse--usually a plug in type around 4 amps (will be marked on fuse and board) is bad.
Nov 05, 2012 | Televison & Video
Panasonic 27 in TV
Power surges will attack every board in the unit, it is possible that they discovered that more boards were affected then could be changed for a reasonable cost. These tv's are not component level repair, but board level repair. There is no easy or good solution when a set has been severely damaged by a power surge. The best answer is usually to replace the tv. Also power surges are covered under most homeowners insurance.
Sep 05, 2009 | Sanyo DP26648 LCD TV
Magnavox 20mt4405/17 piece of junk!
Hello sletak, This problem is actually common. Your degaussing coil has malfunctioned, causing the power supply to become unstable which in trun is effecting the memory settings in the processor. You have threen problems in one so lets start by looking at the overall cause first 1) degaussing coil going bad (shorted then opened) Replace this and the thermistor that is attached to the degaussing circuitry. 2) power supply instability (power surge from the degaussing circuit) replace the damaged components in the power supply section. Troubleshoot this thoroughly. 3) after fixing the power supply and the degaussing components you will need to manually degauss the TV and then use the auto-degaussing function to do the rest. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 10, 2009 | Philips Magnavox 20MS233S 20" TV
Tv wont turn on
Switch off the surge protector for 2-3 minutes then switch back on and TV should work.
Feb 19, 2009 | Philips Magnavox 27MS343S 27" TV
MAGNAVOX TV BURNING SMELL TV WENT POP AND WENT OFF
Well that pop had something to do with the power components inside the TV frying. I would have to say there is nothing you can do to repair it as its dangerous to work on such things.
I wouln't waste my time bringing it to a repair shop they will probably tell you to just buy a new one.
Jan 05, 2009 | LG RU-27FB30C TV
Tv won't turn on
I suggest you unplug the set for about 15 minutes and then plug it in and try again. Sounds like you may have had a power surge/bump in the middle of the night. Althoguh you are using a surge protector, doesn'r mean the devise hooked to it can't lock up during a power surge.( Surge Protectors are an insurance policy only, not a garrentee ). If unplugging the set and waiting doesn't fix it, it will need to have the power supply section of the board repaired. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Protron PLTV-32 Television
Philips Magnavox 27MS343S 27" TV Logo
336 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
