Question about Olevia LT37HVS 37 in. LCD HDTV
Olevia LT23 23in. LCD/TV
My LCD/TV is having some power issue. Power supply is present as the red standby light is on but i just coudn't turn it on by pressing either the remote button or the manual button.
Help needed!
Thim
  • 1 more comment
  • dschof Nov 21, 2007
    Neovia 37 inch with similar problem - was turned off using remote but did not will not turn back on. Standby light on but remote and manual methods do not work. No noises or response at all.
  • Anonymous Apr 01, 2008
    I am having the exact same problem. where you can see the red light for the power supply but when u click the on button (either on the monitor or the remote) the light blinks off for a millisecond then back to red.
  • lusifur May 01, 2008
    i have a lt23hvx with the same prollm. i think its an issue with the power supply board.anyone know where i can find out the part list/description or diagram for the board. i found a part (q4) that apears faulty
  • 20 Answers
I had the same prob, but found out that the problem with the Olevia lcd tv's on most models not powering up is because of failure of capacitors on the power supply board that I do believe is due to excessive heat and lack of ventilation.
I took the tv apart and got access to the main board and just by looking at the capacitors I could tell which one were the bad ones..
I will show some pics that I borrowed during my repair, hope it helps as reference as it did to me.
Olevia LT23 23in. LCD/TV - bb40c58.jpg
I replaced the bad caps with new ones that I bought at a computer parts store.
Now I got my lcd tv back ON but this time I added a internal cooling fan for better air flow that will reduce this malfunction from happening again.
Hope this helps.
Posted on Dec 22, 2009
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
My olevia 42in not getting power is it the power supply thats going out sometime it turns on
Look at the power supply first; look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find
Dec 22, 2009 | Olevia LT42HVi 42 in. LCD Television
My Olevia 27in. LCD Television does not turn on
Well, at least the standby 5vdc circuit is still working but the problem can be in the controller board is not sending the signal to turn on the main power supply sections, or the power supply itself is bad. Look at the power supply first for burnt parts, bad capacitors.
Nov 10, 2009 | Olevia LT27HVX 27 in. LCD Television
Olevia 42 inch Flat Panel has power supply issue... Blue light does not come on and tv does not turn on... I have tried all different things to get tv to work with no positive results
What did you try so far? The main power supply MUST have at least the 5V standby supply section working. This 5v is used by the main control board to send out the command to turn on the main power supply section which will power up the rest of the TV circuits when the power switch is activated either by the power button of remote or on the TV powern button. Look for this 5v first.
Nov 04, 2009 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
I have 19" Olevia LCD TV and the red power light comes on when you plugged it in but the TV DOES NOT power on
You only have 5v standby voltage circuit working. The problem can be i nte main power supply or the main control board that send the signal to the main power supply to turn on. Those are the two place to look for.
Nov 03, 2009 | Olevia LT23HVX 23 in. LCD Television
No red light no power
the probability is you have a bad power supply board. have the set checked. They need to see if the standby b+ is present.
Feb 13, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Power Issues for Olevia LT23 :(
can someone tell me what all the different plugs in the back are for???
Jun 29, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 42"
Olevia LCD 542I - Had the same issue for a week until the tv would not turn on anymore, after several attempts it came back on. A few days later the tv turned off then only the standby light was on, then lost the standby light as well. After researching the problem it could be in two areas, either the power supply or main board. Removed the back and found the power supply had several capacitors that were bulging on the top and appeared the fluid was leaking, all signs of a failed part, removed the PS and replaced four capacitorst that had shown some issues. If you can removed the PS and check for a number on the board, mine was FSP271-4F02, and find someone who has some electronic circuit capablilty, the issue may be resolved at a fraction on the cost of a new power supply.
Apr 13, 2008 | Olevia LT42HVi 42 in. LCD Television
Power issue with Olevia LT23
I think this model has a timer on it, it seems to go when the warranty runs out, not proven but Mine went out about a month ago. My only fix is to plug my tv (via the service port which is COVERED) to the usb port on my computer using my BlackBerry usb cable, in other words the Mini USB. Seemingly I must be logged on to do so and wait for the Chime form my pc, a balloon will pop up for new hardware not recognized (vista) then press the power button and then it turns on, unplug the usb cable and make sure the source is set to tv / video or else it will power back off and you will have to start all over. Theres NOT A PERMANENT fix yet but this is what I do every time I want to use the TV, I have a laptop so I use it as the Monitor just to watch movies. If you have a desktop I recommend keeping the cable handy BUT DO NOT LEAVE THE USB CABLE IN FOR LONG USES. THE SERVICE PORT IS COVERED FOR A REASON!!!
w2power_@_yahoo!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!_._com
Apr 01, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT37HVS 37 in. LCD HDTV Logo
552 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
