Question about Mach Speed VENOM V2DP Motherboard
Searching for engine manual for a dynamite 12 SPD engine, to do some general maintenance.
  • Micheal Spiers
    Micheal Spiers May 11, 2010
    this is wrong area .. this is for pc's
    Scholar:
  • 56 Answers
Http://www.dynamiterc.com/ProdInfo/Files/DYNP5200-DPS-12HiRes-Manual.pdf
Posted on Sep 16, 2009
What is the recourse when someone uses dynamite in a residental area. do they have to inform residence about their activities?
You should check with the city office for local ordinances related to sound levels and hours of operation.
Oct 25, 2013 | 2050 Hand Carry 12-Volt Dynamite Tire...
How many qts of oil do i need
Depends on your engine.
1980 JEEP CJ-7 2.5L 4-cyl Engine Code [B]
CAPACITIES
Engine, GM without filter..........2.4 quarts[1]
Wix Filter ........ 51040
Cooling System, Initial Fill..........8.0 quarts
Automatic Transmission, A904, 30RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, A999, 32RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, Total Fill
3 speed A999, 32RH..........8.4 quarts
3 speed A904, 30RH..........7.0 quarts
Manual Transmission, 4-SPD, SR-4..........3.0 pints
Manual Transmission, 4-SPD, T176..........3.6 pints
Differential, Front..........2.5 pints[3]
Differential, Rear..........4.9 pints
Transfer Case,..........4.0 pints
1. Add extra oil when replacing filter. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all gears.
Check fluid level in NEUTRAL and add fluid as needed.
3. 1984-1992 Models with command-Track, add 5 oz of 75W-90 GL-5 to shift motor housing opening.
TORQUES
Oil Drain Plug.....25 ft-lbs
Manual Transmission T176
Fill Plug.....15 ft-lbs
Drain Plug.....15 ft-lbs
Manual Transmission SR4
Fill Plug.....20 ft-lbs
1980 JEEP CJ-7 4.2L 6-cyl Engine Code [C]
CAPACITIES
Engine, without filter..........5.0 quarts[1]
Wix Filter..... 51522
Cooling System, Initial Fill..........11.0 quarts
TORQUES
Oil Drain Plug.....30 ft-lbs
1980 JEEP CJ-7 5.0L 8-cyl Engine Code [H]
CAPACITIES
Engine, without filter..........4.0 quarts[1]
Wix Filter..... 51258
Cooling System, Initial Fill..........13.0 quarts
TORQUES
Oilman
Feb 02, 2013 | 1984 Jeep CJ7
Igt dynamite slot machine manual
Do you know how to lower the valume on the IGT dynamite slot machine
Aug 31, 2012 | Toys
Roland spd 20 analog test error+reason
The adaptor for the SPD-20 is not 12 V ac (Altern Current) the SPD-20 need only Altern current (12V AC)
if the adaptor is 12 v cc, the internal circuits can not made +5v , 0, -5v
for simetrical operactional supply.
And Spd 20 show "Analog test err" and "batery low"
Jan 08, 2012 | Roland Spd-S Sampling Percussion Pad...
What automatic transmission was used in the 1992 Ford F-250 Diesel
A.T., 4x4, AOD (5.0L)
EAC}G}}400" type="radio" name="userInterchange" />A.T., 4x2, AOD (5.0L), 11-1/4" ext hsg
EA}}}400" type="radio" name="userInterchange" />M.T., 4 spd (Warner T-18), 4x4
M.T., 5 spd, Mazda/Toyo Kogyo, 4x4
M.T., 5 spd, ZF, 4x4, 8-460 (7.5L)
M.T., 5 spd, ZF, 4x4, 8-445 (7.3L, diesel)
EAA}N}}400" type="radio" name="userInterchange" />A.T., 4x2, AOD (5.0L), 10-1/4" ext hsg
M.T., 4 spd (Warner T-18), 4x2, 12" ext, cable drive speedo
M.T., 4 spd (Warner T-18), 4x2, 12" ext, elec speedo
M.T., 4 spd (Warner T-18), 4x2, 4" ext, cable drive speedo
M.T., 4 spd (Warner T-18), 4x2, 4" ext, elec speedo
F>}A}}400" type="radio" name="userInterchange" />A.T., 4x4, C6, 8-460 (7.5L), (elec speedo), (tag F2TP-YA)
M.T., 5 spd, ZF, 4x2, 6-300 (4.9L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-351 (5.8L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 6-300 (4.9L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-351 (5.8L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-460 (7.5L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-460 (7.5L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-445 (7.3L, diesel), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-445 (7.3L, diesel), elec speedo
M.T., 5 spd, ZF, 4x4, 6-300 (4.9L), ID E9TA-TA & TB
M.T., 5 spd, ZF, 4x4, 8-351 (5.8L), ID E9TA-TA & TB
M.T., 5 spd, ZF, 4x4, 6-300 (4.9L), ID F4TA-BA & BB
M.T., 5 spd, ZF, 4x4, 8-351 (5.8L), ID F4TA-BA & BB
>C}}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, elec speedo
>D}A}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 2.73 ratio
>D}A}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 3.08 ratio
>D}B}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 3.55 ratio
>D}B}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 4.10 ratio
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 6-300 (4.9L), (elec speedo), ID F2TP-BA
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 6-300 (4.9L), (elec speedo), ID F2UP-DA & DC
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-302 (5.0L), (elec speedo), (ID F2TP-DA)
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-351 (5.8L), (elec speedo), ID F2TP-FA
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-351 (5.8L), (elec speedo), ID F2UP-EA, EB & EC
?}}}400" type="radio" name="userInterchange" />A.T., 4x4, E4OD, 8-351 (5.8L), (elec speedo), (ID F2TP-HA)
}}}400" type="radio" name="userInterchange" />A.T., 4x2, C6, 8-460 (7.5L), (elec speedo), ID F2FP-CA & DA
A.T., 4x4, E4OD, 8-460 (7.5L)
E}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-445 (7.3L, diesel)
A.T., 4x2, C6, 6-300 (4.9L), w/o ID F2FP-BA; w/o ID F2UP-CA
A.T., 4x2, C6, 8-351 (5.8L), w/o ID F2UP-CA
A.T., 4x2, C6, 6-300 (4.9L), w/o ID F2FP-BA; ID F2UP-CA
A.T., 4x2, C6, 8-351 (5.8L), ID F2UP-CA
A.T., 4x2, C6, 6-300 (4.9L), ID F2FP-BA
A.T., 4x4, E4OD, 8-445 (7.3L, diesel)
A.T., 4x2, E4OD, 8-460 (7.5L)
A.T., 4x2, C6, 8-445 (7.3L diesel)
EF}D}}400" type="radio" name="userInterchange" />A.T., 4x4, C6, 8-351 (5.8L)
Good luck
Aug 10, 2010 | 1992 Ford F250
91 Ford Ranger XLT, 4 cyl, manual 5 spd. Engine
most likely right on top of steering colum around have way down
Oct 07, 2009 | 1992 Ford Taurus
How much transmission fluid does my 2005 2.0 get.
2.0 Liter , Engine code (E)4G94Automatic Transmission, F4A4B-1 Initial Fill..........5.1 liters Automatic Transmission, Total Fill  4 speed F4A4B-1..........7.7 liters
Manual Transmission, ..........2.2 liters
2.0 Liter turbo, Engine code (D) 4G63 Turbo Manual Transmission, 6 SPD - W6MAA..........2.8 liters
Manual Transmission, 5 SPD - W5M51..........2.2 liters
Transfer Case,..........0.600000023841858 liters
Aug 18, 2009 | 2005 Mitsubishi Lancer
WHAT KG300 SERVICE MANUAL
the manual is available in some of the following sites..:
www.mobiletopsoft.com/devices/spec-lg-kg300.html
www.mouthshut.com/review/LG_KG300_Dynamite-114290-1.html
soumyadipc.blogspot.com/2007/07/review-lg-kg300-dynamite.html
www.nodevice.com/driver/KG300/get41587.html
free-pdf-ebook.net/2007/12/21/lg-kg300-user-guide/
yzoo.co.uk/search/web/lg+kg300+modem+driver.html
www.ipmart.com/main/product/LG,KG300,19757.php?cat=1907&prod=19757
Feb 12, 2008 | Cell Phones
Mach Speed VENOM V2DP Motherboard Logo
179 people viewed this question
Top Mach Speed Computers & Internet Experts
David
David
M_Butkus
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
