Question about Minn Kota Maxxum 70 Universal Motor/Sonar Combo
Transducer does not work
Universal sonar does not work
For 29.95 Ill tell you
Posted on May 13, 2009
My Mark 4 sometimes shows incorrect depths. The transducer has not moved and no problem with electrical. One point it is working fine, the screen then runs multiple vertical lines and the depth chan
Take note if when the vertical lines appear on the screen if the depth numbers begin to flash. If this is the case then the transducer has lost bottom contact and the unit is trying to reacquire bottom contact. If the transducer is parallel to the bottom of the lake while your boat is not moving then, the next time you have it on the trailer, turn your unit on and go listen and or feel the transducer to see if you can hear and or feel the tick or sonar ping. If you can't your transducer may be faulty. If the loss of bottom contact occurs when you are moving it will happen at a certain speed. This is the result of air bubbles passing under the transducer and disrupting the sonar signal causing loss of bottom contact.
Sep 19, 2014 | Lowrance Mark 4 Chartplotter/fishfinder...
Sonar not Working
Transducer not parallel to bottom - kicked up. Manually set depth to see if the auto depth is the problem.
Aug 12, 2017 | Lowrance Elite-4x DSI Sonar with...
My Structure Scan display is good on the left side and the right side does not fill the screen. My transducer is mounted under my boat on the step. I have a HDS8 and everything is brand new. All other...
verify cable harness integrity at base connection of transducer , replace cable or check settings easy fix would be change display unit if unit under warranty as replacing transducer is not easy and economical
Jan 17, 2018 | Lowrance LSS1 StructureScan Sonar (Lss1...
Lowrance lcx-111c hd, single beam transducer
Hey Tingo,
I have two 113's,, the problem sounds like the transducer is going bad,, Try this.. unplug all your connections,, replug them and see if it helps...
Don't get me started on $$$ updates....
May 15, 2017 | Lowrance Lcx 112c 10.4" Screen Color Gps...
Sonar inop at most times . onec in a while it works fine
(1) bad transducer. (2) bad ground from unit to battery. The cable next to the battery will have no effect.
Sep 05, 2009 | Lowrance Lms 522c Sonar Gps Chartplotter...
Built in transducer is not picking up/transferring depth to graph
I havew a Minn Kota trolling motor on a Z21 Ranger. Minn Kota has a built in (puck type) transducer on the motor. I have a lowrance 135x on the front. The lowrance will read the temp but will blink the depth. I switched out the depth finder with another 135x with the same results. I have a 522c gps unit networked together and mounted on the console that works fine. Any suggestions on the problem with the 135x?
Jul 27, 2009 | Minn Kota Maxxum 70 Universal Motor/Sonar...
Sonar only reading the surface
First, ensure that the transducer face is pointing down when the boat is level in flat water. You may want to do this step like a tv antenna, adjusting the angle of the transducer while watching the screen.
If that doesn't work, then try moving the transducer further into the water and repeat step one.
Sonar systems are (largely) directional, and will work best when parallel with the seabed (or lake bed etc)
Jan 20, 2018 | Lowrance LCX-104C
Mounting a sonor/transducer on a MinnKota Riptide ST
Did the unit come with a strap to mount the transducer to a bow mount electric? Most units do... If not there is probably one available for the unit as an aftermarket accessory or accessory from the manufacturer... Regarding the transducer wire, just wrap and rout this up the front of the bow mount motor shaft so when you pull the motor up and secure it, it is not going to get in the way. You could cable tie the cord down near the bottom of the shaft and one up near the top where they wont interfere with the motor bracket when the motor is positioned up on the boat.
Mar 17, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
GPS Logo
117 people viewed this question
Top Minn Kota GPS Experts
Will Halftowaite
Are you a Minn Kota GPS Expert? Answer questions, earn points and help others
