Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
SCREEN SAYS OUT OF RANGE
DVI INPUT SAYS OUT OF RANGE hooked up to my computer and the screen says out of range i am using a cheap video card if that makes a difference
  • 55 Answers
I assume that you are using a DVI to VGA connection since this TV dose not have a DVI connection.
Make sure that the resolution are set to the following supported resolution:
1280 x 1024 @ 60 Hz
1024 x 768 @ 60, 75 Hz
800 x 600 @ 60, 75 Hz
640 x 480 @ 60, 75 Hz
Or just make sure its set to 1366x768 @ 60Hz
Posted on May 14, 2009
Well i thinking about hooking my t.v. to computer with out unhooking computer screen. i need to know were to plug in the t.v.
This will only work if you have a graphics card with two outputs; if you do, they will be right next to eachother, and will be a s-video (small round) VGA (blue) DVI (white) or HDMI (trapezoid).
Mar 02, 2011 | Computers & Internet
Emerson 42 inch television flat screen HDTV: i connected a DVI to HDMI cable to dell computer screen to television in order to display computer screen to it but the signal isn't working, how do i...
Your Dell Monitor does not have a video output. The DVI/HDMI cable needs to run from the DVI-Out of you computer tower directly to the TVs HDMI input, ideally one with a red/white analog audio input next to it, because that cable only provides a video signal. If you don't have a DVI out on your computer, perhaps your TV has a VGA input. If your computer/video card only has one monitor connector, then you can only connect the Monitor OR the TV.
Dec 27, 2010 | Emerson Televison & Video
I have a syncmaster 400p i need a new graphic processor can u reccomend a compatible one
Good day,
If your screen has a VGA, DVI, or HDMI port, most of the new graphics cards will be compatible with your screen. Most graphics cards come standard with DVI ports and include a vga adapter for the screen cable. Some of the new graphics cards come with HDMI and DVI ports or a HDMI converter if you want to use HDMI.
I would recommend a Nvidia graphics card. Depending on what your primary use is going to be they have an extensive range to cater for your requirements and price range.
Hope this helps!
Regards
Nov 28, 2010 | Samsung SyncMaster 400 T 40 in. Flat Panel...
Input not supported message comes on HP W19 monitor. Computer had been sent in for repair.
It sounds like the repair shop set the video resolution too high for this monitor to display, you need to set the PC resolution to 1440 x 900 @60Hz.
Boot up in safe mode (hit f8 while booting up), then select VGA support, reset the video reolution to 1440 x 900 @60 Hz, reboot. Hope they did install correct video driver for your PC.
http://s807.photobucket.com/home/budm/allalbums
May 03, 2010 | HP W19b LCD Monitor
Input signal out of range
Did you mean "out of range". Try reloading video drivers. If that doesn't work, perhaps screen cannot use that resolution.
Jun 28, 2009 | HP Pavilion F1523 15" LCD Monitor
Esa 42 in plasma.....out of range?
i have a plasma tv (china brand) when i start the TV the remote control for other devices are not working, only working if the remote is too close to the sevices or by reducing the brightness to its minimum level (zero level..no brightnesss)
i need help strange fault
May 05, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
DVI Digital out of range
The incoming signal standard is not supported by the projector. If you are using a computer, set it to a common video standard
Jan 02, 2018 | Televison & Video
Chimei CMV 938D 'Out of range' error message only when using DVI Connector on specific resolution and color depth
I know this sounds obvious but- I had the same problem, and turns out the cord want plugged in quite properly at the back of the monitor. This may not fix every problem, but, I suggest you check the cord pligged in at the back of the monitor is firmly in there and restart, then if you still get the problem, contact the company.
Jul 21, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Hooking up a HP L1755 17
What is the way to get the very best picture quality when hooking up my new HP L 1755 Flat Screen Monitor to my E-Machine W3052 which is about 3 years old.First would it be compatible or the best idea to hook up VGA to VGA.DVI to DVI which means buying a new Video card for my Computer so the DVI could be hooked up to my computer, or hook up the DVI to VGA Connector ? Would a DVI Video card be worth the extra costs if I went that route ?This HP L 1755 only has a response time of 25 ms, is that good enough to watch Music Videos or not ? I do not do any gaming.Can you tell me the best detailed step by step way to hook up this monitor to my E-Machine W3052 Computer and which Connector to use ? If I need a DVI Card what would be the Part number or Card I would need to get ? Sorry about all the questions.Any guidance and input would be greatly appreciated since I have a disability and need some help and to be honest I do not have 50.00 for a DVI Video card. Sincerely & God Bless ! Thanks,Diehard16
Feb 18, 2008 | Computers & Internet
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
651 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
