DeLonghi 6507L Oil Filled Radiator Heater Logo
Suzanna McMahan Posted on Dec 11, 2013
Ew6507l - nowhere near warm enough - DeLonghi 6507L Oil Filled Radiator Heater
cawilcox8470
Level 1:
New Friend:
  • Contributor 38 Answers
  • Posted on Dec 13, 2013
cawilcox8470
Contributor
Level 1:
New Friend:
Answers
38
Questions
0
Helped
16659
Points
38
Only made for 400 to 600 sq feet try Eden pure heater 1500 watts than cover 1000 sq feet the oil fill heater might have a switch 600 to 1500 watt there r usually a high and low to them good luck
I got a nextbook for xmas and its saying i need a activation code i dont have tge reciet
Sorry! Nowhere NEAR enough information... only 100 models to choose from.
My blood pressure reading is 108/73 Is that low or high bp
Its slightly lower than nominal, but nowhere near low enough that it should cause discomfort.
It wont start
Please add all the detail you can and repost the query, this is nowhere near enough
Kitchenaid mixer goes to high speed but then slows
Nowhere near enough information but check the carbon brushes for a start.
Sep 26, 2014 • Food Mixers
The top volume on my ASUS windows RT tablet is nowhere near loud enough to hear above the car noises. Any way to make the volume control louder?
No unless you use the headphones output plug and use the line in input on the car stereo ( if it has one )
The main oven gets warm but nowhere near hot enough to cook anything. Could it be the element? And if I replace it myself, what is the pen like object attached to a wire at the rear of the oven? Many...
if it gets hot but not hot enough its proberly your thermostat and the pen like thing over the wire is just a cover to insolate the bear spade connection
2helpful
My toyota avensis d4d 2003 heating problems,it blows cold air on drivers side but nowhere near warm as it should be,any suggestions
My Toyota is a 2007,avensis T180,a got problem with the heating,takes time till is warming up,so i have to drive the car for 2-3 miles to be able to use the heating,which i think is not common,also when i want to increase heating between that time to 22 or more degrees,then acceleration goes up it self with out to touch pedal with the foot.Please any help from somebody who know something about this.
1helpful
SMEG Dishwasher - Water fill level is too low
Hi, I found your problem stuck here from one year ago.
I will post my solution the same, as reference for you and more users with same problem, apologies.
Re: smeg dishwasher fails to fill with enough water to sucessfully wash. It does put some water in.. but nowhere near enough.
Before checking parts inside the machine, ensure that water is coming from the faucet at the back with regular pressure.
To start check the water level sensor.
This is usually a floater sensor located on a side inside the dishwasher.
Check if water level is working properly, if the floater is getting stuck then that is the problem.
If the water level is OK, then the responsible is usually the inlet valve, or clogged inlet lines.
From description it looks more like a faulty water level.
Top DeLonghi Heating & Cooling Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
