Question about Ruud UBHC Air Conditioner
Guy using weed eater accidentally skinned thermostat wire at ac unit outside.It immediately stopped. I clipped out damaged area, reconnected it with small wire nuts. Red to red white to white. No luck dead in the water. I changed the 2 barrell fuses at unit still nothing. Any suggestions?
  • 1 more comment
  • dlclark101 May 13, 2009
    This may be duplicate reply..hit wrong button. The breaker isn't tripped...I checked all the connections and double..even triple checked...to be sure nothing was pulled loose inside the unit. Could hiting / skining the wire with the weedeater cause the 24 volt transformer to go bad? And were is transformer located?
  • dlclark101 May 14, 2009
    Guy using weed eater accidentally skinned thermostat wire at ac unit outside.It immediately stopped. I clipped out damaged area, reconnected it with small wire nuts. Red to red white to white. No luck dead in the water. I changed the 2 barrell fuses at unit.. Checked breakers..still nothing. Re-checked connections and everything again..still won't come on..nothing. Any suggestions?
  • dlclark101 May 20, 2009
    Thanks for your reply....it turns out...it was a tiny 3amp fuse in the control panel located inside the furnace..part of the thermostat wiring loop for the system.
  • 3,741 Answers
Thank you very much for keeping updated.please do rate the solution.thank you for using fixya.
Posted on May 20, 2009
  • 6,784 Answers
Hi, you will have to run the entire strand with a new set of wires from the outdoor unit to the inside unit. the wire nuts will not work in this situation. i would also check the indoor wall control device for its operational value as well. it may be shorted out.
Posted on May 15, 2009
  • 5,807 Answers
Maybe an electrical problem, you might be needing a vom or a volt-ammeter-tester to eliminate the possibilties. possible that the motor itself is dead, you can short the two leads test with the continuity tester if you can read anything of value tell me, or momentarily plug it on to test it, hope this help
Posted on May 13, 2009
    Top Expert:
  • Ruud Master
  • 78,289 Answers
Are u sure u got the wires connected correctly and that it is good connection, did u use an ohm meter? also how about the 24 volt transformer for thermostat control voltage? is it ok? any of the house circuit breakers tripped?
3 amp fuse blows when ac is switched on. Heater works fine.
There is a short in the low voltage wires somewhere for sure. The most common place is the low voltage on the outside unit, sometimes animals chew through them or they get cut with a weed eater. Just my experience. You basically have to trace it back all the way to the thermostat and heater. The only other thing is the contactor
Jun 30, 2012 | Carrier 38CKC060 Air Conditioner
Furnice air blows, but my ac unit outside want cut on
if the inside unit is running but the outside unit isn't - I would check the fuses or breaker. I suspect you have a blown fuse or a tripped breaker.
What is also possible is that the 'low voltage' thermostat wire (coming from the thermostat inside the house) has been cut - possibly by a lawn mower or weed eater - or chewed into by a dog.
If this is the case - you easily splice (with all power off) the wires back together using the color of the individual wires.
Jun 06, 2011 | Heating & Cooling
I have a LG Artcool LAN121HNP the unit will only ciculate air (not cool) it is only 2 years old. I have had an HVAC guy look at it, he says the compressor is fine. We have put a new board in the outside...
Make sure none of the thermostat wires from the inside unit to the outside unit have come loose or have be cut by a weed eater or such. These units are a little more complex than your average heat pump.
Aug 24, 2010 | LG Art Cool LA181CNW Split System Air...
My unit stays on even after shutting it off or turning it down. I replaced the thermastat and the problem still acurres. HELP!
have you used the weed eater out by the condensing unit could be short in thermostat control wiring to outside unit or a stuck contactor in condenser control circuit try these first then if not there in furnace control circuit at board that jockeys between air and heat remove thermostat wires from board remember thier location bet it stops.
May 12, 2010 | Bryant Heating & Cooling
The outside unit on our Ruud heat pump won't turn on. The inside fan blows but the unit outside sits idle - no fan turning, nothing. It was cooling earlier today, but when I came home from shopping, the...
first look for red button neer the copper line set if has one push it second inspect thermostat wires for weed eater damage check disconnect for fuses check breaker at main panel pull disconect and remove cover check stat wire connections look at the capacitor if swelled up on top bad if all look ok put disconect in using insulated object manually push in contactor if unit comes on check for 24 volt ac on yellow stat wire to common if none stat wire could be loose at indoor unit or stat bad hope this helps you
Jun 05, 2009 | Ruud UPMC036 Air Conditioner
Weed eater pulled out red & white wires from thermostat at a/c unit. Red went to yellow and white to ?. Unit is an intertherm unit, model unknown but schematic #703909b
look on indoor unit to see what they used if only ac unit then only 2 wires needed common usually blue or black and yellow if heat pump then orange for rev valve o term on stat r red y yellow then white or brown for call for elect heat in defrost and blue or black for common also take some 3/8 clear tube to incase the stat wire and zip tie it to top of line set to help stop this
May 07, 2009 | Intertherm P3RA-030K Air Conditioner
White will usually go to white or blue, you can go to your furnace to verify which wire is connect to the common terminal (c)
May 07, 2009 | Heating & Cooling
Condensing unit
Probably one of the wires going to the control board or contactor has been pulled off when this happened. If you feel comfortable trying to reconnect these comment me back and I will try to walk you through it. PLEASE REMEMBER THAT THE CONDENSER HAS HIGH VOLTAGE INSIDE OF IT.
Jun 27, 2008 | Goodman CLQ36AR49 Air Conditioner
Ruud UBHC Air Conditioner Logo
98 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
