Question about Thermador UCV36A 36" Universal Cook 'n' Vent Downdraft Kitchen Hood
Where to buy thermador cook n vent downdraft air filter?
It is about 36", has two air mental mesh filters side by side, each about 15"x5". both are old and cracked. where can i buy new air filter for replacement? any information is appreciated! thanks!
  • KEN LaPOINT
    KEN LaPOINT May 11, 2010
    Great source for parts such as this is RepairClinic.com.. be sure to have your model number... Good luck!
4 Suggested Answers
  • 5 Answers
SOURCE: Cook 'n Vent Downdraft Up/Down Mechanism Replacing
just the switch should be replacable. My vent has a screw at each end (philips flatheads - accessible only when vent is up) just under the top cap. Removing the screws and cap should give you access to the switch. Just make sure you cut your breaker off first.
Posted on Jan 07, 2009
  • 5 Answers
SOURCE: Thermador cook top with down draft ventalation
I would think you can. Most of the cooktops are 240v and the vents are 120v, so the vent may be feeding off of one of the cooktop's hot wires. My vent is fed from it's own receptacle but is harnessed along with the cooktop's 240v.
SOURCE: kenmore elite 36" downdraft dimensions
I am using it on an island... it has a 6" high backsplash with a counter on top. How can we make the downdraft work with it?
Posted on May 26, 2010
The vent downdraft keeps going up and down
This means that one of the limit switches by the motor has failed.
Apr 22, 2011 | Thermador UCV36A 36" Universal Cook 'n'...
Thermador cook n vent stuck in the up position. We have a thermador cook n vent. We had it running for about an hour. We turned the fan off but now it is stuck in the up position and will not go down. ...
replace the switch if the switch is going on and up position and not in down position the you should replace the switch for this part you can order it from thermador if they still stock the piece hope this helps
Aug 11, 2010 | Thermador UCV36A 36" Universal Cook 'n'...
Thermador Downdraft blower Fan Not Working
could have serveral problems / if under counter or in back of range . the last two i had the control buttons w wire harness needed replacement /another required the pc board in connevtion box ( under counter in right cornor. also look for poor connections in the power box .
Dec 07, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
The exhaust hood cannot **** out the smoke
Please check that the filters are clean. If they are old then replace with new ones.
Oct 12, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
My thermador stove fan keeps going up and down cvs45r
no
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Mar 07, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
Up & down push button not working
Repaired the same problem several months ago. The up/down control has a very small switch located under the button. The switch is part of the selector switch assembly that costs upwards of $100. However, the switch itself is available from Digi Key electronics part # P12321-SCT-ND at about $1.00 each, plus shipping. If you can handle the unit disassembly, which is extensive in this repair, and can solder very small switches, this is an inexpensive fix. I suggest you buy some spares. I'm looking for a seal replacement for this unit right now. Good luck.
Dec 02, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Nov 15, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Oct 31, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Kitchen Ranges Logo
425 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
