WILL NOT TURN ON AT ALL THERE IS NO SIGN OF NOISE I HAVE 120 VOLTS AT THE POWER CABLE INTO THE BOARD THERE IS NO POWER AT THE TRANSFORMER COMING OUT NEED HELP THANK YOU
When I initially bough mine, I had the same problem. It wouldn't shut down, but occasional popping sound on the center speaker. Turns out the impedance on the speaker was 4 ohms, not not 8. Replaced center with an o 8ohm speaker. This receiver is not reated to run 4 ohm speakers. If I had problems with 1, I can only imagine what kind of problems could happen if all the speakers were 4-ohms.
Got the same problem. After turning on the receiver it goes into protect mode after 3-5 seconds. Will try to disconnect speakers and see if that helps - a loud pop comes out of one my rear channels.
same here they should of had a recall i think love the amp but this sucks.. woks 4 a few minutes then pop an nothing..
Man... I have the exact same problem. Mine works great most of the time, but at night (usually when I am using it) it starts this super-loud popping sound for a few seconds and then shuts down... Sounds like meteors hitting a tin-roof? What's up with this? Defect?
