Question about HP DeskJet 930c InkJet Printer
Red and yellow light blinking at the same time
Red and yellow light blinking at the same tim. I just changed 2 cartridge of ink.
  • HP Master
  • 4,338 Answers
Here is HP's link on how to fix the blinking lights:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09170&cc=us&lc=en&dlc=en&product=60096
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&product=60096&docname=bpd09142
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 13, 2009
What is alternate red and yellow blinking mean?
According to the manufacturers site the fault is either an incorrect installed cartridge or a paper stuck in the paperpath. 1. Turn off the device. 2. Check that there are no papers stuck in any of the covers. 3. Reinstall the ink cartridges. 4. Contact technical support line if that doesn't help
Jun 19, 2014 | Epson Stylus T10
Red ink light blinking, won't feed paper. Have
this is hp security error, for ink cardtridge,(the ink cartridge has internal/acess counter), you need to try change cartridge, if contuinue send to hp service center
Nov 27, 2009 | HP DeskJet 940c InkJet Printer
The yellow spot is blinking and the black dot is
the solid light means toner is low. Blinking usually means either the cartridge is out of toner or the cartridge is having a technical problem. If you pull the yellow toner cartridge and put it back in with no change in result, you will need to replace the yellow toner cartidge
Nov 19, 2009 | HP LaserJet 1500L Printer
The red light on left is blinking. What does that indicate? I have a deskjet 904C. There are three light The left one is blinking, the middle is okay and the right is the green one, that shows me the...
Hi:
If you open the door on the top of the printer, while it is powered on, the ink cartridges will move to a spot that shows you the status of your ink.. There are little cartoon pictures of the cartridges with smiles or frowns to tell you if you have an empty color or black cartridge.
Nov 04, 2009 | HP DeskJet 940c InkJet Printer
Want print ......
remove the cartridges clean the brown dotted circuit on the cartridges and the same on the printer where you fit the cartridges.with tissue paper.OFF the printer.then ON the printer.then install the cartridges.it will work.but if does not work then any of the one cartridge is faulty.replace.
thanks.
Oct 21, 2008 | HP DeskJet 5150 InkJet Printer
Ink cartridge unit will not move to replace
Printer has pads for excess ink, once pads are full this happens.
Pads will need to be replaced
Jun 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
Installing
not sure w/ this one, but is it blinking too fast on printer, the check color and black ink cartridges? and if yes what is the color of the light, is it yellow or red, and is the on and off lights, flashing?
-black and color blinking fast - install printhead
-black and color blinking slow - no cartridges installed
-on and off blinking black and color steady lights, calibrate
-hope this helps, or else contact kodak
-xoxo
Apr 11, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Need to change cartridge on ip3300
Greetings...
This Canon ip3300 has four ink tanks... PGI-5 Black, CLI-8 Cyan, CLI-8 Magenta, CLI-8 Yellow
Lift the front of the printer while the printer is on and the ink tanks will move to the center... the empty tank will have a blinking red light... the inks that are ok will have a steady red light... press the small tab in front of the ink tank that is blinking and remove... insert and press down the new tank and make sure the red light is on to show you have replace the ink correctly...
This should work, let me know if you have any additional questions...
Ed
Apr 08, 2008 | Office Equipment & Supplies
Will not print at all
You can try restoring the printer to factory settings..and try agian it has worked most of the times for me..Let the catridge be in the printer when you do this..
Oct 27, 2007 | HP DeskJet 960c InkJet Printer
It will not print.
Hi Greenhorn, Your info is slightly conflicting - I think. As I remember the C60 has just 2 LED's: 1 - Green for Power 2 - Red for Error The third button - Cartridge exchange - has no LED Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong. The error codes I remember are: Printer status - Indicators - Priority Power - Error Power ON condition On - Ink sequence Blink - Ink Cartridge change mode Blink - Data processing Blink - Paper Out *1 - On Paper jam condition *1 - On Ink end (Black) *1 - On -> Blink Ink level low (Black) - Blink-> Blink Ink end (Color) *1 - On -> Blink2 Ink level low (Color) - Blink-> Blink2 Ink end (Black and Color) - On -> On No Ink Cartridge (Black or Color) *1 - On Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink Fatal error *1 Off On Special setting Blink2 Blink2
Mar 27, 2007 | Epson Stylus C60 InkJet Printer
HP DeskJet 930c InkJet Printer Logo
238 people viewed this question
Seeker5211
Seeker5211
